E-Photozine High ISO GX7 vs OMD
Started Aug 12, 2013 | Discussions
MT Senior Member • Posts: 1,924
I do not have a Raw converter so I am looking at the high iso jpegs.
I compared the reposted (manual color balance)3200 and 25600 iso shots of the GX7 and the OMD and the OMD seem noticeable better to me in terms of resolutions (edges of the black text) and less blooming in the extreme high iso of 25600 on the color squares.  I admit I'm not professional and would love to hear others' comments. Also comments on RAW for those of you who process RAW.
Thanks,
MTMT
Panasonic Lumix DMC-GX7
PAUL TILL
PAUL TILL Veteran Member • Posts: 9,285
Re: E-Photozine High ISO GX7 vs OMD
Does it really matter, how often do you shoot at ISO25600?
The 10% Rule:
You Must Be 10% Smarter Than The Equipment You're Operating
Manip16 Contributing Member • Posts: 515
If noise is a low, a lot. If noise is high, rarely. Same as comparing my current SLR on 1600 (which I use a decent amount) and my old SLR on 1600 (which I used rarely).
dougjgreen1 Senior Member • Posts: 2,317
Are the OM-D's JPEGS from Pre-production firmware?
Thanks,
MTMT
Because the ones from the GX7 certainly are. I wouldn't put too much stock in any of these images for determining the final IQ of the camera until they are using production firmware. Anything prior to that ought to be considered a worst case scenario - as you really don't know how much better the production images are going to be.
I might add that the situation with respect to RAW images at this early date is even worse, because the only RAW converters that currently work with GX7 files are hacked ones who's support for the GX7 currently is, at best, incomplete, and certainly not tuned to extract the most quality from the GX7 files.
 dougjgreen1's gear list:dougjgreen1's gear list
Olympus Stylus XZ-10 Olympus PEN E-PL5 Nikon 1 V2 Olympus E-M1 Panasonic Lumix G X Vario PZ 45-175mm F4.0-5.6 ASPH OIS +11 more
GingerBread Regular Member • Posts: 384
While I'm not one to ever compare at anything beyond 6400, and usually not beyond 3200, I don't think you can gain much from comparing high contrast edges like black lettering at any ISO.  Even the old 12 megapixel Oly Pens had nice looking edges on black lettering at fairly high ISO's in JPEG's, but that seemed to have more to do with high default contrast than with the noise properties of the sensor.
Ging
 GingerBread's gear list:GingerBread's gear list
Sony RX100 Panasonic Lumix DMC-LX7 Olympus OM-D E-M5 Panasonic Lumix DMC-GX1 Nikon D700 +3 more
Jorginho Forum Pro • Posts: 10,329
Techradar has the RAw files
Oly files ae useles,omehow techradar has used the JPGs s RAWs there...However, the GH3 has the very same Sony sensor and its files are visibly RAW. Based on that comparison to my eyes the GX7 seems to be just slightly better, but its very close.
 Jorginho's gear list:Jorginho's gear list
Panasonic Lumix DMC-G1 Panasonic Lumix DMC-GH2 Olympus PEN E-PL5 Panasonic Lumix DMC-GH4 Panasonic 12-35mm F2.8 +9 more
peppermonkey Veteran Member • Posts: 3,748
Oly's jpg seems more digital?
Frankly, between jpgs and missing RAW converters for the GX7, there just isn't much to go on at this time. So any analysis is well, incomplete.
But from the jpg's provided, the only thing I can tell is that Oly's photos are slightly brighter and for some reason seem a little digitized...processed, like a little more sharpening and contrast was added.
Again, this doesn't mean much till we get to properly analyze RAW files.
What I can say is that whatever is the final result with proper RAW file converters, the GX7 files are comparable to Oly's and doubt very much that there will be too much differences, nothing of real importance anyhow (well, other than to pixel peepers).
Hubert
My non-digital gear: Agfa Isolette, Fed 2, Konica Auto S2, K1000, Yashica Electro 35 GX, Recesky
http://farm3.static.flickr.com/2034/2457111090_00eafbf8a4_m.jpg
http://www.flickr.com/photos/peppermonkey/
 peppermonkey's gear list:peppermonkey's gear list
Panasonic Lumix DMC-TZ3 Sony RX100 II Sigma DP2 Pentax K110D Panasonic Lumix DMC-GF1 +11 more
Dr_Jon Senior Member • Posts: 2,789
I's nearly impossible to see pics without noise reduction, which makes the noise look better but the detail look worse. Comparing noise without detail is usually not a good idea...
 Dr_Jon's gear list:Dr_Jon's gear list
Sony RX100 Fujifilm FinePix Real 3D W3 Panasonic Lumix DMC-GH4 Canon EOS 5DS R Panasonic Lumix G 20mm F1.7 ASPH +23 more
FrankS009
FrankS009 Veteran Member • Posts: 3,718
Re: Techradar has the RAw files
My reading of the techradar review is that they are still showing pre-production shots.
Its tough waiting for the real thing, and not to compare prematurely.
F.
 FrankS009's gear list:FrankS009's gear list
Nemo0815 Regular Member • Posts: 425
The ephotozine RAWs (and also Jpegs) look one stop better in the GX7 compared to E-P5 at 25600!
There is much less color noise in these Pana shots.
 Nemo0815's gear list:Nemo0815's gear list
Panasonic Lumix DMC-GX7 Panasonic Lumix DMC-GM1
SkiHound Senior Member • Posts: 2,060
My take on trying to compare out of camera jpegs is that you are comparing a whole bunch of variables. Indeed, if the images aren't shot with a common lens then any differences to either the jpeg or raw files may be due to differences in lens quality. With jpegs the sharpening may be increased or decreased, noise reduction increased or decreased, etc. An image with a bit more apparent detail and a bit more noise may simply be a reflection of the jpeg engine applying different amounts of noise reduction.
sigala1 Senior Member • Posts: 3,634
Thanks,
MTMT
In that case, buying Lightroom may do more for your high-ISO photos than buying a new camera.
