Is this dust on the sensor or problem with the lens
Started Aug 10, 2013 | Questions
techmine
techmine Forum Member • Posts: 63
Folks, I just received my NX1000 (sale on woot). I fixed up the lens and everything was OK. Just when I started to play around more, I notice a black dot(on the right) appearing on my photos. I think its dust on the sensor. Its barely noticeable when lens is wide open like f3.5 but super black when closed at f22. Could this be a lens issue, by any chance?
Enjoying Digital age!
 techmine's gear list:techmine's gear list
Canon PowerShot SX10 IS Nikon Coolpix P300 Fujifilm X10 Nikon D40 Nikon D300S +8 more
Samsung NX1000
nx200USER1
nx200USER1 Senior Member • Posts: 1,097
Re: Is this dust on the sensor or problem with the lens
what you described being noticable at f22 and not wide open aperture is symptomatic of dust on the sensor. Another indicator is if the spot is at the same location in every shot.
Photographers will often say how they were unable to clean their sensor whilst travelling abroad and they were restricted to shooting closer to wide open and smaller dof.
Try using a blower of some kind, not your breath, not canned air and hopefully it will remove the contamination. Also try facing the sensor pointing down when you do it. Blow the chamber as well.
If that doesnt work then a wet solution is required.
Timmbits
Timmbits Contributing Member • Posts: 588
that would be step 2.
try step one first: in-camera sensor cleaning - you'll find it in the menu
 Timmbits's gear list:Timmbits's gear list
Panasonic Lumix DMC-TS3 Samsung NX20 Samsung NX 30mm F2 Pancake Samsung NX 45mm F1.8 +4 more
techmine
techmine OP Forum Member • Posts: 63
Tried in-camera sensor cleaning multiple times but no use.
I will try a blower. Since I have not used the camera for even a week and exposed the sensor only once (first time when putting the kit lens), in my home, I have a feeling that this dust particle arrived with the camera. Unfortunately I can't prove it and so the bitter pill.
Thanks.
nx200USER1
i have read many peoples experience online that they observe sensor contamination even as a brand new boxed, unopened product. Its not uncommon and seems to be the luck of the draw.
techmine
So in that case, is it worth calling the Samsung Support?
techmine
After careful examination of the photos, I saw multiple stains on the sensor. There is no freakin way I could have caused this. Problem is, I bought it from Woot, who consider this as buyer's remorse and won't accept returns and Samsung will take weeks to repair this.
Called Samsung support and the rep asked me to reset the camera and asked me to give them a call later if the issue is not fixed. God.... I am in a deep ****.
Gesture
Gesture Veteran Member • Posts: 3,787
The first thing I do is take a good look at the sensor (naked eye or under magnifying lens) and see if I can spot the debris.  It should be inverse to how it appears in your trial photos.  Lots of good tutorials on the web; some are more comfortable than others with do-it-yourself.  Hopefully, Samsung will do a sensor clean gratis.
This is where the underdog companies (Samsung, Pentax, Sigma) can choose to excel-service and warranty work.
Good luck.
William Hubert
William Hubert Contributing Member • Posts: 855
I really don t understand so much fuss obverse cleaning the sensor . With many of my DSLR s it was routine clean the sensor. The method I used involved using Bausch and Lomb lens craning tissue which come moistened in a foil pack. That  is wrapped around a plastic tool and wiped in one direction across the sensor. Much harder to do than an the NX because the mirror was in the way and it was deeper in the body.
Also IF  you have photos itch spots Lightroom can help . Show it the spots and will fix a series of photos.
Bill
As with many things in life a great photograph has strong appeal for what is NOT in the picture.
 William Hubert's gear list:William Hubert's gear list
Samsung NV11 Samsung TL500 Canon EOS 10D Canon EOS 20D Canon EOS 40D +23 more
techmine
Bill
Yes if you get the dust on these sensors after months of usage on the field. I am not complaining about the dust or methods of cleaning but the fact that my camera came with contaminated sensor.
techmine
For those who are interested: After my initial talk with Samsung, I got a surprise followup call from them, asking if the problem still exists. I told them "YES" and there are several stains on the sensor. So they created a service request and now my brand new camera is going for a factory service.
Let's hope it does not turn out to be a lemon!
