Want to buy a phone for camera..
Started Aug 8, 2013 | Questions
Jeff Peterman
Jeff Peterman MOD Forum Pro • Posts: 11,788
Re: iPhone and file formats
Alupang wrote:
With the Nok 808, it automatically "saves as" upon every edit so your original full res JPG is perserved. So no need for TIFF, even when doing multiple edits in-cam.
But that doesn't help! If you save the original JPG (call it File 1), then later open it, edit it and save it (File 2), that second file will have worse JPG artifacts than the first. If you then open the second file, make additional edits and save it (File 3) the JPG artifacts can be a real problem - especially if the software doesn't give you any control over the compression settings. If you save the second, and subsequent, files as a TIF file (or some other loss less format), the JPG artifacts never get worse than those in the original image.
Jeff Peterman, Moderator 7D and Phone/Tablet forums.
Not a staff member, or paid employee, of DPReview.
Any insults, implied anger, bad grammar and bad spelling, are entirely unintentionalal. Sorry.
www.pbase.com/jeffp25
www.jeffp25.smugmug.com
 Jeff Peterman's gear list:Jeff Peterman's gear list
Panasonic Lumix DMC-FZ40 Canon PowerShot S110 Canon EOS 7D Canon EF-S 10-22mm f/3.5-4.5 USM Canon EF-S 17-55mm f/2.8 IS USM +18 more
Jeff Peterman
That's why the only time I edit on the phone is if I want to do a quick correction before I post an image on Facebook. Otherwise, I wait until I can pull the original into my PC and go from there.
Alupang
Alupang Senior Member • Posts: 2,819
I dont save file 1, the camera does when i press shutter. So does iphone or any other cam without raw capability. So tiff just preserves that JPG.
Any further PP eventually requires one more save into JPG for final product. Unless of course you wish to share tiffs...not practicable.
Alupang
bigley Ling wrote:
Agree TIFF is preferable for rediting an image without lossy compression each time. B aware though the majority of iPhone photo editing apps will not necessarily have TIFF abiltiy to load or save. Basically once 645 pro creates the TIFF, it is prob best left for PC or MAC post processing
But 645 creates the tiff from the original iphone jpg so why bother? Unless you plan to PP, save and share tiffs ONLY there is no advantage.
Si14
Si14 OP Junior Member • Posts: 47
Re: (Galaxy S4/iPhone 5) vs (Nokia 808, 1020)
I checked some video samples and it shows the advantage of the Nokia ones over Galaxy S3 or iPhone 5.
Here is a comparison of Nokia Lumia 920 (which is even older than 808/1020) vs iPhone 5:
http://www.youtube.com/watch?v=VXp1EtpxcJ4
This one compares the above Nokia one with Galaxy S3:
http://www.youtube.com/watch?v=5doZi30l6Zk
The difference and image quality is significantly higher in the Nokia one. I assume Nokie 808 and 1020 are even higher than the Nokia 920 which is shown above.
I have two question from the people having 808 or 1020:
1- How is the battery life? If you capture video and shoot image, how the battery consumption changes?
2- Does Nokia 808 have optical image stabilization similar to 920 and 1020?
3- Is Nokia 808 or 1020 capable of:
-creating HDR (without post processing)?
-panorama
-time lapse?
HDR time lapse? (Something similar to the following):
http://www.youtube.com/watch?v=susojbZ2xso
bigley Ling Senior Member • Posts: 2,911
-panorama
-time lapse?
808 battery life is very good, alot better than alot of newer smart phones. Recording video I usually get just over 1 hour before I get the low battery symbol. Shooting images seems much more economical on the power, but using the xenon flash will deplete the battery quicker.
The 808 has no optical stabilization and depends on software stabilization for make videos smooth. Digital stabilization is not only less effective compared to optical stabilization but also the quality is compromised slightly whne it is enabled.
The 808 is capable of creating HDR like images from a single exposure but it requires post processing, you can -1EV an image capture, then recover shadow detail with programs like PhotoFX or Photproc which are 3rd party apps available for the Nokia 808. SO no the 808 cannot do HDR realtime.
Yes the 808 can do panoramas, but depending on the scene, results are not always perfect.
The nokia 808 built in app has an excellent time lapse feature, which most will be extremely satisfied with.
No there is no HDR time lapse for the 808
agree, was just stating the facts. And I believe the TIFF from 645 pro may noy be as mailable as the JPG from the Nokia 808 capturing in Pureview 8mp and no pureview zoom used.
wll Veteran Member • Posts: 4,821
Si14 wrote:
Based on the following photo comparison, you can see here that the difference is not that much significant. If you have a photo comparison that shows the difference in action, that would be interesting to see.
Got to tell you, your wrong .... the image quality of the Nokia 1020 is off the charts, it is greatly better than the S4 or iPhone !
wll
Re: Want to buy a phone for camera..
seeblue wrote:
Which comes first for you, the smartphone or the camera? If it's the smartphone, you need to figure out which ecosystem and operating system you prefer. You'll figure that out by spending a FEW HOURS off and on in the store playing with the phones.
Then to get the best camera for the ecosystem and operating system you prefer, you'll need to buy a near or top-of-the-line model.
I prefer iOS and an iPhone. As far as the camera (I've got a 4S), it's quite controlled and competent. Out of the box, images are conservatively sharpened, colors are moderate and accurate, noise is moderate in good light. In regular use, it's predictable and repeatable. I get consistent results. In that sense, you get a feel for it's strengths and weaknesses and compensate accordingly. Images look similar on my phone and desktop monitor. Images need little to no "work" unless you want to.
As noted earlier above, the photography software catalog in the App Store is endless.
No cameraphones is a substitute for a real camera, IMO. If the camera is first, buy a real camera. Smartphone cameras fill a niche by their convenience/immediacy, portability, and ease of use (up/downloading/posting/processing).
I too have a 4s and it does a good job on the photographic side (although not as good as the iPhone 5 and not even close to the 808 or 1020).
I have the iPhone because of its stability and great apps as my phone is my business tool.
On the other hand, the 1020 camera is fantastic and the windows platform is getting more mature and feature rich as time goes on. My contract is over in a year and at that time i will decide on what to do, I'm sure the 1020 will have an upgrade as will the iPhone, so we are in for some exciting times photographically speaking !
wll
Stevan G Regular Member • Posts: 423
-panorama
-time lapse?
there is a HDR app for 808...
http://asf-mobiles.net/hdrapp-the-application-for-hdr-available-for-nokia-808-pureview-beta/
also you can stabilise 808 video in postprocessing
StevenG I know of this app, and actually have it installed. It works real good, but you must capture 3 bracketed exposures and then "post process" to get a resultant HDR. Because of the Post processing, it is considered at not real time like what the iphone can do.
ah OK
Menneisyys Senior Member • Posts: 1,429
Well, actually, the "realtime" HDR of the iPhone isn't true HDR. It's only capable of extending the DR with about 1 EV but no more, while with the traditional two bracketed shot approach you can easily achieve even more than 8 EV's.
I've published several shots proving this - see for example the HDR images in section " 2.1 The stock Camera client" linked from my latest iOS bracketing / exp. comp. article at http://forums.macrumors.com/showthread.php?t=1621351 (and will also thoroughly elaborate on it in my future HDR bible.)
An example:
HDR from two shots with 8 EV difference, in-camera stitching via Top Camera:
(full version: http://www.flickr.com/photos/33448355@N07/9365924661/in/set-72157634791582799 )
When exposed for the darkest area, the HDR of iOS produces much worse results:
http://www.flickr.com/photos/33448355@N07/9365925353/in/set-72157634791582799
and, when metering the brightest area, the results are also very bad:
http://www.flickr.com/photos/33448355@N07/9365924279/in/set-72157634791582799
Re: Wait for LG G2?
New G2 test images, directly comparing it to the iPhone 5, Galaxy S4, One and Lumia 1020, are at
http://www.phonearena.com/news/First-camera-samples-from-the-LG-G2---compared-to-the-iPhone-5-Galaxy-S4-One-and-Lumia-1020_id46175#5-Nokia-Lumia-1020
All I can say is wow! While it definitely has lower DR than the Lumia, it's pretty much on par with it in most shots and is MUCH better than the iPhone 5 / HTC One and definitely better than the S4!
Hope Europe gets the G2 soon - I really want it!
if the iPhone HDR is from a single image, how come with faster moving subjects captured with HDR on, the image has ghosting where the subject was moving? I think it does take a multi exposure shot, but the processing has to be quick, so it does not necessarily do a full hdr, plus iPhone HDR is just for visual improvement of dynamic range, and not to make the image look unrealistic and surreal.
Basically, the stock Camera app - unlike with third-party ones - has access to the hardware. This is why it can sample the sensor twice in a row, with minimal time difference, all during the same exposure (during while the shutter is open).
Sampling twice during while the shutter is open also means the sensor can't be exposed with different shutter speeds; this is why the additional dynamic range is around 1 EV only, unlike with traditional (and very slow - shutter speed + ISO changing + opening/closing the shutter again generally takes a second; this is why the built-in HDR mode doesn't use this approach) approach.
BTW, I've made some shots where the HDR version of an image had more unrealistic colors (because of the different clipping of the separate RGB channels) than the non-HDR version. Of course, this has to do with clipping and not with the "plastic" colors of traditional large-EV  HDR methods.
Re: Wait for LG G2?
A (hopefully) genuine LG G2 video, demonstrating OIS, gain control and audio. The latter is stereo!!! At last a decent non-Symbian / WP smartphone with stereo video recording!
http://www.youtube.com/watch?v=1h80nt8XGWE&feature=player_embedded
Re: Wait for LG G2?
Now the question is does it have the same HAAC mics the Nokia uses on their phones?? These mics not only record stereo, but they seem to have impressive dynamic range recording capabilities, as well as being able to handle very high volume concerts without distortion or clipping
Re: Wait for LG G2?
HAAC is Nokia exclusive so I guess not
btw finally a decent Android camera
Re: Wait for LG G2?
Does the HTC One not record in stereo for video, and image stabilized?
Also I heard that the HTC one does have HAAC mics, just not the same ones as Nokia, as they had to recall that
