The new Nikon W1: just tested it
Started Jul 31, 2013 | Discussions
Pangloss
Senior MemberPosts: 2,298Gear list
Jul 31, 2013
Hi everybody,
Well, finally, here it is: the new Nikon W1. Just took my first sample shots with it, have to postprocess them though, but I am sure you are curious about this new Nikon 1 camera.
The $2 remote is used to trigger the shutter simultaneously on both V1's.
The metal bracket is screwed to the quick release plate of the tripod. Both V1's are set at an angle so that their respective fov's slightly overlap.
The Nikon W1 on my lightweight Manfrotto tripod.
On to the posprocessing now!
I am sure there are many interesting thing to do with this setup, like 8K movies - limited to 2s - or 3D shots. Do you girls and guys have any ideas?
Andrew
Novice photographer
 Pangloss's gear list:Pangloss's gear list
Panasonic Lumix DMC-LX3 Nikon D200 Ricoh GXR A12 50mm F2.5 Macro Ricoh GXR GR Lens A12 28mm F2.5 Nikon 1 V1 +4 more
Nikon 1 V1
A. Westreich
Senior MemberPosts: 1,195Gear list
Re: The new Nikon W1: just tested it
In reply to Pangloss, Jul 31, 2013
Ummm. . .  it only comes in white?
Whatever you do, don't turn it around and shoot a brick wall.
 A. Westreich's gear list:A. Westreich's gear list
Nikon D7100 Nikon AF Nikkor 35mm f/2D Nikon AF-S DX Micro Nikkor 40mm F2.8 Nikon AF-S Nikkor 80-400mm f/4.5-5.6G ED VR
Mahmoud Mousef
Senior MemberPosts: 2,525
Clever title
Those two look unusually good together.
Could be a real time-saver if your work demands shots from 2 angles, and not necessarily mounted on the same tripod, but further apart too.
rb0321
Senior MemberPosts: 1,251Gear list
Interesting setup. You should certainly be able to get some ultra-wide panos with that.
 rb0321's gear list:rb0321's gear list
Nikon D7000 Nikon 1 V1 Nikon D750 Nikon AF-S DX Nikkor 16-85mm f/3.5-5.6G ED VR Nikon AF-S DX Nikkor 35mm f/1.8G +8 more
Daisy AU
Senior MemberPosts: 1,564Gear list
... Big Brother "Andrew" is watching
Thanks,
Daisy AU - Brisbane
( Nikon D7000 and V1 )
http://www.flickr.com/photos/ney_images/
 Daisy AU's gear list:Daisy AU's gear list
Nikon D7000 Nikon 1 V1 Nikon AF-S DX Nikkor 16-85mm f/3.5-5.6G ED VR Nikon AF-S DX Nikkor 35mm f/1.8G Nikon AF-S Nikkor 70-300mm f/4.5-5.6G VR +8 more
