XZ1 flat surface
Started Jul 31, 2013 | Discussions
mojorising Regular Member • Posts: 120
XZ1 flat surface
I usually use a flat surface when I want to hold a camera steady for a long exposure or leave it sitting for a timer self portrait.
The XZ-1's tripod socket protrudes from the base by about 1mm which means it does not rest easy on a flat surface. The weight of the extended barrel and glass causes it to lean forwards and point down towards the ground.
Any tricks for getting the XZ-1 to sit flat on a flat surface?
Nikon 1 series - It's not the size of your sensor, it's what you do with it that counts
1000D - S100 - XZ1 - V1 - NEX5 - TG-320
 mojorising's gear list:mojorising's gear list
Canon PowerShot S110 Olympus OM-D E-M5 +3 more
Olympus TG-320 Olympus XZ-1
skeys MOD Veteran Member • Posts: 3,191
Try this...
If you have the XZ-1's strap mounted to the XZ-1, place the wide part of the strap underneath the lens ring, just in front of the XZ-1. It may now point just ever so slightly up but it should not be the problem that pointing down is for you.
Steve
My comments and opinions are my own. I am neither a staff member, nor a paid employee, of DPReview.
joe6pack Senior Member • Posts: 1,570
Re: XZ1 flat surface
You must have some objects with you that can fix it?
A piece of cloth, napkin, cash, coins, key chains, wallet, even the lens cap comes to mind.
socks?
 joe6pack's gear list:joe6pack's gear list
Olympus XZ-1 Sony Alpha NEX-3N Corel Aftershot Pro IrfanView DxO Optics Pro Elite
Aaron Sur Senior Member • Posts: 1,141
A quick release plate from a tripod works a treat, I use a plastic/glassfibre? unit from my Cullman magic tripod. It is very light and one hardly notices it there.You can buy these from many different tripod manufacturers.
For other shots where I want the camera a bit more secure I have this C clamp /mini tripod which fits into a pocket
Sudo Nimh Regular Member • Posts: 281
I've seen small bean bags used for the purpose. They're filled with something much finer-grained than beans, more like sand, to hold the angle you set the camera on.
IcanHazPics Junior Member • Posts: 38
this is what I use : http://joby.com/gorillapod/micro800/
small enough to leave it on the camera most of the time!
 IcanHazPics's gear list:IcanHazPics's gear list
Olympus XZ-1
Ken Gosden Senior Member • Posts: 1,749
Manfrotto has their flat folding pocket series as well.
http://www.manfrotto.us/photo-pockets
 Ken Gosden's gear list:Ken Gosden's gear list
Olympus XZ-2 iHS Olympus Tough TG-3 Olympus E-5 Olympus E-M1 Olympus Zuiko Digital ED 50mm 1:2.0 Macro +16 more
emilio74 Junior Member • Posts: 43
I purchase the xz-1 and got the pocket tripod from link above for free, but
I prefer other ideas rather than carry this in my shirt pocket.
 emilio74's gear list:emilio74's gear list
Canon PowerShot S95 Olympus XZ-1
calterg Regular Member • Posts: 499
I carry coins for the sole purpose of doing adjustments of this kind.
