D4 Sensor spot
Started Jul 24, 2013 | Questions
Mike Chen Forum Member • Posts: 69
D4 Sensor spot
Is it possible to have a dust particle in-between the sensor and the ir filter ?
 Mike Chen's gear list:Mike Chen's gear list
Nikon D4
Nikon D4
eNo
eNo Forum Pro • Posts: 11,744
Re: D4 Sensor spot
Possible but unlikely.
http://imagesbyeduardo.com/
Los Angeles wedding photography that seeks the heart and spirit in each image
snellius Contributing Member • Posts: 584
Re: D4 Sensor spot
Do you have a problem or is it curiosity?
Mike Chen OP Forum Member • Posts: 69
Re: D4 Sensor spot
YES I do have a spot that will not go away
Nikon D4
reginalddwight Senior Member • Posts: 2,003
Re: D4 Sensor spot
This cannot possibly be true. I heard that only D600 bodies had dusty sensors.
romfordbluenose Senior Member • Posts: 2,080
Re: D4 Sensor spot
Very very unlikely as the combination is made in a clean environment. I had a spot on a D300 filter that just wouldn't go away whatever I did eventually I ignored it.
 romfordbluenose's gear list:romfordbluenose's gear list
Nikon D800 Nikon D5300 Nikon AF-S Nikkor 70-300mm f/4.5-5.6G VR Nikon AF-S Micro-Nikkor 105mm f/2.8G IF-ED VR Nikon AF-S Nikkor 50mm f/1.8G +8 more
Oscar Rico
Oscar Rico Senior Member • Posts: 2,235
Re: D4 Sensor spot
Mike: Maybe an old dry oil spot, try to remove it with Smear Cleaning solution and finish it with Eclipse solution. Regards: Oscar
Re: D4 Sensor spot
I tried that cleaned more time than I should it is not moving
Nikon D4
Re: D4 Sensor spot
I have a D300 never seen this on its sensor
but D4 Hmm, the tech at the Nikon AUTH. repair service said it could happen
Nikon D4
Oscar Rico
Re: D4 Sensor spot
Then that is your answer.
mikemsphoto Senior Member • Posts: 1,500
Re: D4 Sensor spot
I suppose one option for a dust spot that you can't get at would be to use the "Dust Off reference photo" feature. (on page 346 of your manual.) I've never actually used it but has been on Nikon bodies at least since the D2x. It lets Capture NX2 know where the spot is on all your shots and it automatically gets cloned out during raw processing. Must admit that I've never actually tried it though.
Michael Sherman
http://www.msphoto.ca
Ferguson
Ferguson Contributing Member • Posts: 775
Re: D4 Sensor spot
It's actually quite easy to tell if it's on the sensor (under the AA filter) or on the top of the AA filter.
A spot on the AA filter seen against an unfocused bright background (e.g. sky) will appear at high (small) apertures, and (mostly) vanish wide open as the light will some in from all around it.
A spot on the sensor itself as opposed to on top of the AA filter will always be present, as there's very little (if any) space between it and the photosite.
So shoot against an unfocused bright background at F16, and at F2.8 (or whatever is wide open), and if it's almost the same, it's on the sensor -- if at F2.8 it mostly disappears it's a normal spot on the AA filter.
Comments welcomed on photos: http://www.captivephotons.com
Re: D4 Sensor spot
I know of the dust reference feature in Capture NX
it would not help in any other software
however I use Lightroom and Aperture (sometimes)
Nikon D4
Re: D4 Sensor spot
I have cleaned more times than I can recall
all other spots are moved except this one
so I can only think that this is on the sensor itself
so it is off to the nikon repair service centre
Nikon D4
