G15: Isn't it time for a 1.1 firmware?
Started Jul 24, 2013 | Discussions
edu T Senior Member • Posts: 1,174
For corrections, comments, and additions, here’s one cursory wishlist…
1 Raw + "Custom JPEG" enabled
That is, allowing for I-contrast, MyColors, etc. on the JPEG side. (After all, WB fine tuning is enabled anyway.)
2 Hand-held HDR
What would be needed is just an aligning algorithm... But wait, it’s already there! (for the "Handheld NightScene" mode.)
3 Movie button can be re-purposed as a 2nd shortcut button.
For example, it would make for a pretty handy AF-lock button, right above the dedicated AE-lock button. (In this case you could spare the original "S" button for, say, drive mode or white balance.) Of course it would duly default to movie when the mode dial is set to video shooting.
4 AE-lock beep volume under control
If I can set independently the volume of the start-up sound, how come the only way to lower the audible AE-lock signal is fully muting all of the sounds?
5 B-time value available
There is already a shutter release jack from which a second actuation could close the shutter.
6 Program shift assignable to the front dial
This is a bit subtle and/or personal. Even though the control dials are quite customizable, I’ve found out that the one combination that to me would be most handy and consistent throughout modes is plainly impossible. (To wit: under Tv and Av respectively, shutter speed and aperture set by the front dial, as it’s the most proeminent and haptic control point; under P mode, program shift up there as well, for the very same reason.)
7 A simple interval timer
In addition to the already well implemented self-timer, it would be convenient to be able to set an interval between the N shots.
8 "FREE THE ISO NOW!"
For exposures longer than 1 sec. (Last but not least...)
PS: I’m aware CHDK deals with a few of the items above and much more, but I reckon this list is not really about adding features and more about simple or trivial revisions/improvements that might well be set in firmware to begin with.
 edu T's gear list:edu T's gear list
Fujifilm FinePix F550 EXR
Canon PowerShot G15
Mark B. Forum Pro • Posts: 19,575
Not really...
With rare exception, Canon doesn't do firmware updates to add features; only to fix problems.
2 Hand-held HDR
edu T OP Senior Member • Posts: 1,174
Re: Not really...
To me the 3 items above, I mean, the lack thereof, areproblems.
Not huge ones, sure, else I wouldn't have bought a G15. Anyway, more specifically, 4 looks like a simple oversight and 1 & 8 are arguably crippling-by-design symptoms.
Re: Not really...
Nope, those are features, sorry   If the manual indicated you could do any one of these, and it wasn't working as described then it would be addressed.
RedFox88 Forum Pro • Posts: 24,872
Re: G15: Isn't it time for a 1.1 firmware?
Manufacturers generally issue a firmware update to FIX problems, not add new features.  The idea product never needs an update because they got it right from the start.  The most popular "fix" i see listed in camera firmware announcements?  Menu system:Typos, etc.
Canon added functionality to the 7D and 5D2, but those are $1800 and $2700 camera they knew they'd be selling for 3+ years.  A $500 camera like the G15 is one they want to not work on after it starts its production run.
2 Hand-held HDR
What each mode is doing is probably rather different.  The HDR exposing for the shadows will probably be a longer exposure than what the night scene does since it isn't exposing the shadows just trying to not get a blurry photo.
No thanks.  It is unwise to add options that are not in the user manual.  I want the video button to always be record video.  I don't even use the shortcut button.  No need.
Canon doesn't have this on their dSLRs, they certainly wouldn't put it in a $500 P&S.
ncsakany
ncsakany Senior Member • Posts: 1,661
This is a feature their P&S used to have up until some 5 years ago; the last model that I'm aware having it was the SD-880IS.
 ncsakany's gear list:ncsakany's gear list
Olympus Tough TG-4 Sony Cyber-shot DSC-RX10 III
waterwingz
waterwingz Regular Member • Posts: 233
CHDK will cover a big part of your list for you.
 waterwingz's gear list:waterwingz's gear list
Canon PowerShot G10 Canon PowerShot A1200 Canon PowerShot S100 Canon PowerShot SX50 HS Canon PowerShot N +1 more
