Fuji 27mm review
Started Jul 23, 2013 | Discussions
baobob
Veteran MemberPosts: 6,973Gear list
Fuji 27mm review
Jul 23, 2013
Fujifilm FinePix X100 Sony RX100 Fujifilm XF 18mm F2 R Fujifilm XF 35mm F1.4 R Fujifilm XF 60mm F2.4 R Macro +7 more
SixDasher
Senior MemberPosts: 1,710
Re: Fuji 27mm review
In reply to baobob, Jul 23, 2013
Why in the heck does he make a lot of those sample shots at high ISOs and insane shutterspeeds of static subjects?!?!?!   f2.8 iso1600 1/1400s for a bicycle rack? These shots look horrible with noise and thus throwing away sharpness and color, kind of impossible to judge the lens with those pics.
Too bad as he seems to have put real effort into it.
FujiFilm X-E1
Samyang 8mm f2.8 Fisheye | Voigtländer 35mm f1.4 Nokton | Super Takumar 50mm f1.4
Nikon Ais: 28mm f2.0, 35mm f1.4, 50mm f1.2, 50mm f2.0 Ai, 85mm f1.4, 105mm f4 micro, 135mm f2.0
MiWo
Contributing MemberPosts: 592Gear list
High ISO or not, the review seems to play along with the samples posted so far, even the official Fuji ones: sharp center, much weaker corners.
I am surprised by his judgement on CA though, as some samples exhibit quite severe fringing...
Oh well, maybe the lens gets better with every production run? I'll wait for X-Mas then
Best,
Mike
______________
'Simplicate, then add light(-ness).' - Colin Chapman
 MiWo's gear list:MiWo's gear list
Fujifilm X-T1 Fujifilm XF 10-24mm F4 R OIS Fujifilm XF 50-140mm F2.8 Fujifilm XF 35mm F2 R WR Adobe Photoshop Lightroom 5 +4 more
geejay101
Regular MemberPosts: 184Gear list
In reply to baobob, Jul 24, 2013
baobob wrote:
at
http://www.photographyblog.com/reviews/fujifilm_xf_27mm_f2_8_review/?utm_source=feedburner&utm_medium=feed&utm_campaign=Feed%3A+photographyblog+PhotographyBLOG
Why did they produce a crappy 27mm f2.8 pancake instead of taking the decent 23mm f2 lens from the X100 ?
I dont get it.
 geejay101's gear list:geejay101's gear list
Sigma DP1x Panasonic Lumix DMC-GF1 Panasonic Lumix DMC-GX1 Panasonic Lumix G Vario 14-45mm F3.5-5.6 ASPH OIS Panasonic Lumix G 20mm F1.7 ASPH +3 more
dengx
Contributing MemberPosts: 999
In reply to geejay101, Jul 24, 2013
Because 23mm f/2 found in X100 is not a pancake.
Regards
geejay101
In reply to dengx, Jul 24, 2013
Regards
I dont understand what you want to say. Are you saying that the 23mm lens is actually very deep ?
dengx
Being a fixed camera it allowed the engineers to hide most of it inside the X100
Courtesy of:
http://www.jamesmaherphotography.com/photoblog_view_post/767-taking-apart-the-fuji-x100
and
http://www.finepix-x100.com/en/story
Regards
SixDasher
It's not like it will fit in your pocket with that 27mm on it, so why make a slower softer not-so-cheap lens and make a decent 23/1.4 a few months later?
FujiFilm X-E1
dengx
In reply to SixDasher, Jul 24, 2013
Because it will drive the sales of X-M1 I suppose.
Regards
Krich13
Contributing MemberPosts: 570
I dont get it.
Because they do not want to cannibalize the sales of X100s.
viking79
Forum ProPosts: 14,104Gear list
geejay101 wrote:
Regards
Yes, and fixed lenses usually perform better than interchangeable lenses since they can put a large element very close to the sensor (the rear element is nearly as large as the sensor so incident light angle is close to perpendicular).  With interchangeable lens cameras the mount limits how large the rear element can be.
Also, as for performance, the lens looks fine.  Remember, those book shelf shots only show how the lens performs for close to macro work.  Real world shooting might be substantially different at say infinity focus.
Eric
Sony Alpha 7R Samsung NX1 Samsung NX 30mm F2 Pancake Samsung NX 85mm F1.4 ED SSA Samsung NX 60mm F2.8 Macro ED OIS SSA +5 more
ballwin12
Regular MemberPosts: 287Gear list
baobob wrote:
at
Not sharp at all in my eyes.... I hope I'm wrong !
 ballwin12's gear list:ballwin12's gear list
Leica X (Typ 113) Sony Alpha 7 II Sony FE 55mm F1.8 Sony FE 24-70mm F4 OSS Sony FE 28mm F2 +1 more
Krich13
In reply to viking79, Jul 24, 2013
That is incorrect.
dengx
In reply to Krich13, Jul 24, 2013
That is incorrect.
  • Exploiting the benefits of a fixed lens, the rear lens element is larger than the front lens element. By giving it a diameter of 27mm, which is about the same as the sensor's diagonal dimension of 28.4mm, ample light volume can be received in the edge areas of the sensor.
Regards
Krich13
dengx wrote:
That is incorrect.
Regards
The size of the rear element has nothing to do with "incident light angle" being "close to perpendicular". Think of a field flattener lens near the sensor as a trivial example. Make the distance to the sensor zero (optical contact with the sensor) while you at it. As a matter of fact, this is the basic principle behind fast and cheap TV lenses.
BTW, I am an optical engineer.
Krich13
Here's and example
geejay101
In reply to dengx, Jul 25, 2013
Courtesy of:
and
Regards
Thanks for the link to the tear-down. The camera looks fightingly plasticky. Not something one is likely to leave for the grandchildren like the Leica...
dengx
In reply to Krich13, Jul 25, 2013
Krich13 wrote:
dengx wrote:
That is incorrect.
Regards
I've got you wrong thinking that you are saying that the rear element is not nearly as large as the sensor itself
Hope that it clears out now.
Regards
