First results with Pentax SMC K 135mm f2.5
Started Jul 23, 2013 | Discussions
Kerusker
Kerusker Contributing Member • Posts: 892
Re: First results with Pentax SMC K 135mm f2.5
kitsios_spyros wrote:
Thanks Kerusker. Mine is the SMC PENTAX 1;2.5 135mm version- SN: 5291529, but I have not found what the differences between the two versions are. I have found the following though
The K SMC lens seems to be identical to the third version of the Takumar variants
Variants:
1965: Super-Takumar 1:2.5/135 - see photo above and fist lens diagram
1971: Super-Multi-Coated TAKUMAR 1:2.5/135 (model 1) - first lens diagram
both with 5 elements in 4 groups.
1972: Super-Multi-Coated TAKUMAR 1:2.5/135 (model 2) - second lens diagram
with 6 elements in 6 groups
The latest variant has the same optical design with 6 elements as it's K counterpart. This latest variant suports open-aperture metering on Spotmatic F, ES and ESII.
Source: pentax -- forums -- lens -- database
This thread was of great help also:
http://www.dpreview.com/forums/thread/3467011
Kind Regards,
Spyros
Thanks for the info. I've re-read your post section in that thread.
Maybe you're interested in reading a comparison of 135 lenses:
http://forum.digitalfotonetz.de/userpix/3484_Vergleichstest_135mm.pdf
It's in German but images and tables can be evaluated easily and there are translation tools.
If I remember correctly the difference between the SMC 135 and SMC 135mm is visable in the color aberrations (seen on images like the ones with 'Halogen lamp'. When I bought mine (the 135mm) I also tried the other one (135) - if I remember correctly.
I also owned the Auto Revuenon but I've sold it later on.
][.Kerusker
we don't see that we don't see (eye's blind spot)
 Kerusker's gear list:Kerusker's gear list
Pentax K-5 II Pentax K-5 Pentax smc DA 15mm F4 ED AL Limited Pentax smc DA* 16-50mm F2.8 ED AL (IF) SDM Pentax smc DA 55-300mm F4.0-5.8 ED
kitsios_spyros
kitsios_spyros OP Senior Member • Posts: 2,008
][.Kerusker
Well, that is a very usefull test. Many thanks!
The F version seems the best and actually I was looking for one but the prices were pretty high. Regarding the K SMC version, this test is not far appart from other reviews. In this test it looses points due to its size/weight/not retracted hood, sharpness is improved if stopped down from ~f4 and has this lovely bokeg that attracted me so much. For me this was the most important reason in selecting it. Some tests/owners report better sharpness wide open, which looked very promising also, but mine possibly behaves closer to the sample of this review. But I need more tests to conclude.
Below I attach the photos of the aperture blades. It seems to me that the problem is almost non existant at f16, minimal at f22 but at f32 one specific blade always closes a little more than the others. It is always the same blade. I tried Miles Greens suggestion but it did not work with this issue. Sometimes this problematic blade is closer to the ideal possition (like at f11 setting0 but usually there is some stretching of the octagone shape. I will probably never use it at f32 due to diffraction but I don't know if this problem starts presenting at wider apertures too after some usage of the lens. Or if it is fixable.
You can also see the shape of octagone's angles at around f4 that I was talking about.
Any thoughts?
Kind Regards,
Spyros
The lens
f2.5
f4. This shape is similar at the f3.5 / f4 / f4.5 positions
f5.6
f8
f11
f16
f22
f32 at its best - less problematic form
f32 again
f32 at its typical form
f32 at its worst- most problematic form
f32 at its typical form again
 kitsios_spyros's gear list:kitsios_spyros's gear list
Pentax K-01 Pentax K-5 II Samsung NX300 Pentax K-3 Pentax K-3 II +13 more
Joseph Tainter Veteran Member • Posts: 9,251
Very nice.
Joe
kitsios_spyros
Thank you Joe.
Kind regards,
Spyros
