Hd video editing and rendering on sony Vegas 11
Started Jul 21, 2013 | Questions
zippyzain New Member • Posts: 1
Hi, i hv just startedworking on video editing from past 6 months d software I use is sony vegas pro 11. As d system was old and very slow I recently upgraded to a brand new one...
Specs :
Cpu : i7 3820
Mother board : intel dx79to
Gpu : gtx 760
Smps : thunderbolt 700watts
Ram : 8 gb × 2
Hdd : 2 tb (7200 rpm)
I hv made an heavy investment on dis not sure if i hv picked d rite components pls advice. And my another question wen I try to render a video on 720p or 1080p mp4 I get an error msg which I used to get on my old pc.
Pls suggest wat is dat I need to instal to get dis bug out. And also suggest wat other should I instal to utilise my config completly for my editing works. This pc is dedicated only for video editing purpose. The OS im using on it is windows 7 ultimate (32 bit).
Please help me out with dis as m completly confused if I made a rite choice of specs seeing these repeated problems.
Thank you.
Samsung i7
Jim Cockfield Forum Pro • Posts: 16,333
switch to a 64 bit OS for starters
You're kidding, right?
A 32 bit version of Windows will only use around 3.25GB of memory, no matter how much is installed, and some programs may use less than 2GB of it.
You need to upgrade to a 64 Bit Operating System for starters (for example, 64 Bit Windows 7. Home Premium will use the full 16GB you have installed now) . If you want the ability to use more, install Pro or Ultimate instead (making sure to go with 64 bit versions).
Or, upgrade to 64 bit Windows 8 (as even the basic version of it can use up to 32GB).  But, avoid a 32 bit OS (as they're going to be limited to a bit over 3GB, period -- no matter what version you install if it's 32 bit).
IOW, the biggest problem I see with your specs is the use of a 32 Bit Operating System (as only around 3.25GB of your memory is going to be usable with a 32 bit OS like 32 Bit Win 7 Ultimate).
You need a 64 Bit OS to take advantage of the 16GB of memory you have installed now
JimC
Comparison Chart
Comparison Chart. Note that the x86 (32 bit versions) can use a maximum of 4GB of memory, no matter how much you have installed. It doesn't make any difference if you're using a Pro or Ultimate version of Windows 7. It still won't use more than 4GB if you use a 32 bit version of Windows.
http://en.wikipedia.org/wiki/Windows_7_editions#Comparison_chart
Another Chart (and note that the x86 versions are 32 Bit; and the x64 versions are 64 Bit:
http://msdn.microsoft.com/en-us/library/aa366778(VS.85).aspx#physical_memory_limits_windows_7
But, some of that 4GB is used by hardware resources. So, in reality, the OS and programs will only be able to use around 3.25GB of memory, no matter how much you have installed.
Since the Operating system and drivers use a portion of that 4GB (or more like 3.25GB), even less is available to programs.
Your system specifications look great, except for the 32 Bit Operating System. Basically, all of your memory above 4GB is not being used with a 32 Bit Operating System.
You need to install a 64 Bit version of Windows to make use of your memory. Note that you can not do an in place upgrade for 32 bit to 64 Bit Windows 7. You'll need to perform a clean installation of the Operating Systems and all Programs to use a 64 Bit OS.
It sounds like someone gave you some bad advise along the way -- perhaps convincing you that since you're installing the Ultimate version, more memory could be used. That's not the way it works. You need to install a 64 Bit (a.k.a., x64) versus 32 bit (a.k.a., x86) version of Windows before it will recognize and use anything more than the first 4GB (and because your hardware makes use of some of it, only around 3.25GB of that first 4GB will be usable by the OS and Programs with a 32 bit OS).
So, I'd get a copy of a 64 Bit version of Windows (for example, 64 Bit Windows 7 Home Premium, Pro or Ultimate; or Windows 8) and install it so that more of your memory can be used.
JimC
