Damselfly - almost but not quite!
Started Jul 20, 2013 | Discussions
bradtort
bradtort Regular Member • Posts: 196
It came out a little underexposed and lacking in depth of field. But it's an improvement.
This is an uncropped image.
Nikon D7000, SB600, Tamron 90mm VC macro.
Looks best @ 100%
Nikon D7000
bradtort
bradtort OP Regular Member • Posts: 196
Another image
Didn't get close enough.   This is a crop.
bradtort
And another one
Also cropped.
sperera
sperera New Member • Posts: 11
Re: And another one
This is a very nice shot. You managed to keep the entire body in focus. And it has a better composition to the other two.
Sanath.
bgD300
bgD300 Veteran Member • Posts: 4,552
Re: Another image
I like this one best.  It might help with a little tighter crop.
The first has too much OOF for me to find it attractive.  With these long insects, front on for the face or close to a profile shot works best.  In the third shot, wing detail is lost in the dark background.  You can see more in this one .
EXIF is embedded in photos
My photo blog: http://birdsnbugs.wordpress.com
My camera club porfolio: http://www.pacameraclub.com/Member.Galleries/Brian_20Grant/index.html
RF Stock Portfolio - http://www.dreamstime.com/resp129611
WSSA #51 as bg5700
 bgD300's gear list:bgD300's gear list
Nikon Coolpix P7100 Nikon D90 Nikon D300 Nikon 1 V1 Nikon AF-S Nikkor 70-200mm f/2.8G ED VR +16 more
Gpruitt54
Gpruitt54 Forum Member • Posts: 85
Re: And another one
I like this shot.
I have a difficult time photographing these specific insects. I often get into position where I can move when needed. But these things take off as soon as I move toward them.
Any pointers on how not to drive off my insect subjects?
 Gpruitt54's gear list:Gpruitt54's gear list
Nikon D200 Nikon AF-S DX Nikkor 18-200mm f/3.5-5.6G ED VR II Nikon AF-S DX Nikkor 18-70mm f/3.5-4.5G ED-IF Nikon AF Nikkor 50mm f/1.8D Adobe Photoshop Lightroom 4 +4 more
bradtort
Re: And another one
Patience.  I keep shooting until I find one that will stay in place.
bradtort
Another attempt
Although no one expresses any love for this photo, I think it is potentially interesting if I can pull of the lighting and focus.
This morning I went out and stalked the damselfly.
I ran off quite a few shots, but only one was close to being in focus.  And once again they were underexposed.  I need to dial in about +.7 to +1.
I think the emphasis on the face is improved, and the lighting has more dramatic impact, but the underexposure has created murky areas.   I guess I could do a better job of massaging it in PS Elements, but the shot needs to be improved in other ways that aren't the fault of image processing.
I'm struggly with focus.  I've tried autofocus with single-focus point and it fails most of the time.  Expanding to a higher number of points doesn't help.
Manually focusing just doesn't work for me.  These are hand held, and what looks like it's in focus through the viewfinder almost never is.  Tripod/monopod wouldn't work for these creatures.
I've never really used live view.   Do people use it for macro?
bradtort
A brighter version
bgD300
Re: And another one
There are a number of different odonata activities and their actions vary by species.  For example, the Saddlebags seem to want the highest position with good visibility.  You are usually going to get shots from underneath them.
When dropping eggs, they won't stay at rest for very long and will vary location a lot.
During hunting, they will often return to the same perch.  If you observe them for a while and see this behavior, you can move slowly closer each time they fly away.  Eventually, they will consider you part of the environment and ignore you.
WSSA #51 as bg5700
bgD300
Re: Another attempt
Try this.
Put the single point on the area you want in focus, use AF-S to achieve course focus and then, holding the shutter at half press, move slightly to capture the exact point you want in focus.
I seldom use liveview except on a tripod.
WSSA #51 as bg5700
bradtort
Thanks for comments and suggestions n/m
No text.
