Am I relying on SSS too much?
Started Jul 20, 2013 | Questions
TFSJake Junior Member • Posts: 48
I know the old "50mm = 1/50 shutter speed" rule of thumb, and I know it doesn't exactly apply. So I'm asking, what would be a modern day equivalent of that with SSS? I know SSS allows you (theoretically) to shoot 3-4 stops slower than without it, so is this an acceptable rule:
I figure my crop factor makes my 50mm lens behave like a 75mm lens. That would necessitate a 1/80 shutter speed, in the pre-SSS days. Now, moving it down 2 stops would be 1/20, and even further 3 stops is 1/10.
Is this the proper way of thinking? I'll admit, it's 1 in the morning and I got out of bed to post this because it was bugging me, so I may be completely off base in my thinking. If I am, could someone just give me a 2013 version of the 'focal length = shutter speed' rule of thumb?
Atgard
Atgard Regular Member • Posts: 432
Re: Am I relying on SSS too much?
I think you're in the right ballpark. At 50mm I can usually get sharp shots at 1/10th or 1/20th shutter speed. Sometimes as slow as 1/4 or 1/8 if I'm lucky.
Of course, with moving subjects, that goes out the window. But I do find the IBIS to be worth 2-3 stops -- a big advantage.
 Atgard's gear list:Atgard's gear list
Sony SLT-A37 Sony a77 II Sony 70-400mm F4-5.6 G SSM
Nordstjernen
Nordstjernen Veteran Member • Posts: 6,876
Just check your pictures. All generalized rules like this one has to be balanced to personal shooting technique and personal preferences.
Much more important than focal length is image scale and viewing distance. A 50 mm lens is 50 mm lens, With an aps-c sensor you just use a tighter crop.
 Nordstjernen's gear list:Nordstjernen's gear list
Sony SLT-A99 Sony Alpha 7
Chimere
Chimere Senior Member • Posts: 1,462
Methinks that your thinking method is right (besides a small slip: not a "further" but a "total" of three steps would be 1/10 seconds). Think about it this way: if the final products (the pictures) are the same, mainly in size, it does not matter as how you arrive there.
The SSS however is just a very rough guide line. Much will depend on your implementation. If you squeeze the camera against your skull, perhaps support your bottom somewhere, and hold your breath while you press the shutter button you do far better. Just try it out and see how you do. Finally we are not shooting film anymore.
Chimere
Allan Olesen Senior Member • Posts: 3,357
Well, at same image scale, viewing distance and "shakiness", his reasoning about focal length is correct. 50 mm does not give the same blur from camera shake on different formats.
seilerbird666
seilerbird666 Senior Member • Posts: 1,101
I just blast away and never worry about it.
My photos:
picasaweb.google.com/seilerbird
Rab G Regular Member • Posts: 397
Hi
This shot taken in the Riverside Museum (Transport) Glasgow A37 kit lens at 20mm so that would be 30mm full frame and taken at 1/5th sec.
TFSJake OP Junior Member • Posts: 48
Okay, I think I need to shoot without it for a few days so I can really appreciate it... I keep wanting to use 1/10 and move around...forgetting that SSS isn't some kind of magic bullet. Thanks for the confirmation of my thought process.
Ed at Ridersite Forum Pro • Posts: 17,151
If you have a stationary subject, I think SSS works wonders.  I shoot a lot of wildlife and use shutter speeds well below the historical 1/focal length recommendation.  Shooting at 300mm, I don't hesitate to fire off three or four frames at 1/40th to 1/50th expecting to keep the best.  In fact, I think this is where SSS provides the most benefit.  If I have a tree to brace against, I'll even shoot at 1/20th or slower.  I generally pick slow shutter over high ISO.  Film is cheap these days
AEH
http://aehass.zenfolio.com/
http://aehass.zenfolio.com/blog
Question: What do you do all week?
Answer: Mon to Fri. Nothing, Sat & Sun I rest!
Atgard
Yup, I do this too… with a stationary subject, I'd rather try 5 shots at half the shutter speed (hoping to get one sharp) than double the ISO.
On a side note, I just now realized that your username is not"Ed at Riverside."
cplunk Senior Member • Posts: 1,783
The 50mm = 1/50 sec shutter speed is based on the "amplification" of the movement of the image on the sensor based on the distance between the lens's focal point and the sensor.
This distance does not change with a smaller sensor, it's still 50mm. And the same amount of camera movement would make the same amount of "shake" in the image.
But this rule, I think it's the best rule of thumb, I think it's a bit of a safety measure for the film days. I'm pretty sure, even without SSS on, I can generally get a bit slower in most conditions. It's when carrying a heavy bag, getting tired, etc that people can get a lot shakier without really noticing, and becomes a good time to follow this rule.
But really, even 1/50 is pretty slow. Stop trying to keep it at ISO 100 all the time. Going up to ISO 400 you probably won't see much, if any difference in quality.
 cplunk's gear list:cplunk's gear list
Sony RX100 Sony Alpha DSLR-A900 Sony Alpha DSLR-A330 Sony Alpha NEX-6 Sony SLT-A99 +22 more
No. It would make the same amount of shake on the sensor.
But since the sensor is smaller, the amount of shake will be larger, compared to the sensor size, and consequently more visible in the final image, compared to the same image taken with a larger sensor.
So, your taking the same amount of blur on the sensor, and expanding it for final viewing at a similar size?
I guess that does make sense.
Tone Row Regular Member • Posts: 334
What I'm hearing is that the 1/FL on an APS-C really means 1/effective FL, meaning 1/75 sec with a 50mm lens? In that case, three stops from 1/80 would be 1/20 and not 1/10?
 Tone Row's gear list:Tone Row's gear list
Sony SLT-A55 NEX5R
Hmmm, i'm bored so I did this as an impromptu test:
1/80 down to 1/2 in full stop jump SSS enabled, shot in Shutter Priority. Focused on the front part of the basket. RAW files converted to JPEG in Lightroom.
(Minolta 50mm 1.7)
I can't believe I forgot the EXIF data on those... argh Take my word for it that they're full stop jumps.
Same setup but Stead Shot = off (if I can get these pictures to do right...)
I think the 1/2 second exposure with SSS on might have been a fluke... (man I hope these did right)
What have you been drinking?
AEH
AEH
Would you like some? lol
brian14478
brian14478 Senior Member • Posts: 3,703
I am glad I followed this thread if only for your response..that was funny.   it may be a 'spirited' question, but not mean spirited whatsoever*
thanks for the laugh, brian
