RX100 vs RX100M2 RAW samples from ISO100 to 6400
Started Jul 19, 2013 | Discussions
Roland Schulz Contributing Member • Posts: 511
8
Since I got my RX100M2 today I did some tests. If you like to compare yourself you can download the RAW files below.
Here´s a sample of what you get, both ISO400 100% crops, f6.3 at ceiling lightning. Left is RX100, right is RX100M2.
Please don´t ask me to do close up portraits of Ernie, don´t ask me for how much the Accuphase will be sold, it won´t any soon. The D4 is only for holding the 85 1.4G for showing how both cameras handle the reflections in the front lens .
Please don´t ask me for my conclusion, I don´t really have them yet. Have your own findings...
Roland.
http://www.rhs-net.com/storage/RX100vsRX100M2_ISO100-ISO800.zip   (144MB)
http://www.rhs-net.com/storage/RX100vsRX100M2_ISO1600-ISO6400.zip   (114MB)
Nikon D4 Sony RX100 Sony RX100 II
Tapper123
Tapper123 Senior Member • Posts: 1,511
Re: RX100 vs RX100M2 RAW samples from ISO100 to 6400
Thanks for posting this. I'm actually afraid to even look. LOL!
Maybe later.
 Tapper123's gear list:Tapper123's gear list
Sony Cyber-shot DSC-RX100 III Sony Alpha NEX-F3 Olympus E-M5 II Olympus 12-40mm F2.8 Olympus 40-150mm F2.8 Pro +6 more
EthanP99 Senior Member • Posts: 2,421
can I have ernie?
 EthanP99's gear list:EthanP99's gear list
Sony RX1R Sony RX1 Canon EOS 5D Mark II Canon EOS 5D Mark III Canon EOS-1Ds +21 more
palermo22 Regular Member • Posts: 354
I am definitely not an experiences photographer with  untrained eye; however, the photo on the left is the one that appears brighter and sharper. Are you sure the M2 is the one on the right?
Arn
Arn Veteran Member • Posts: 3,527
What do you mean "is he sure"? It's been noted before, that mkII RAW performance doesn't appear to be better than mkI.
 Arn's gear list:Arn's gear list
Sony RX100 II Canon EOS 7D Canon EOS 5D Mark II Samsung NX20 Sony Alpha 7 +19 more
Mattoid Regular Member • Posts: 324
On first inspection the left shot looks better.  I actually misread your post so thought this was the MK2, so it seemed to make sense. I thought that maybe the same ISO gave a greater sensitivity on the MK2 meaning it was brighter, but this is obviously not the case.
Since the MK2 is supposed to have a better sensor I will try to give it the benefit of the doubt.
Perhaps the right image is showing a greater dynamic range, meaning things of the same brightness are recorded slightly darker leaving room for something even brighter which would otherwise be blown out on the left image.  So to get the same as the more vibrant image on the left you would have to expose a little more, which would then reveal more shadow detail.
If this test could be done with a dynamic range chart it may reveal whether this is the case at all.
Arn
very revealing when put into Lightroom 5
Roland.
Thanks for these.
Putting the ISO1600-6400 shots into Lightroom 5, I see that (like the Imaging-resource samples) the mkI shots appear to have a bit more detail and are a bit brighter at the same exposure as the mkII shots. The mkII shots are less exposed (at ISO 1600-3200 by about a 1/3 stop and at ISO 6400 almost 1/2 stop I think), have less noise in the shadow areas, but also have a bit less detail - kinda looks like mkI shots with boosted noise reduction. If you equalize the difference in exposure, the apparent difference in shadow area noise will be be reduced. I assume that the lighting is identical for the shots? This would make the mkII sensor a bit less sensitive than the mkI sensor, which is interesting considering the Sony claims about increased sensitivity!
Roland Schulz OP Contributing Member • Posts: 511
Re: very revealing when put into Lightroom 5
...This would make the mkII sensor a bit less sensitive than the mkI sensor, which is interesting considering the Sony claims about increased sensitivity!
I also was surprised that the "light meter" in the camera showed me "-0.3" EV when shooting the M2 in the very same conditions with the same settings I used with the M1 before.
Sgt93
Sgt93 Forum Member • Posts: 78
My guess is there will be a firmware update to make things 'better' for the M2.
Steve- Central Illinois
Nikon D3s | Nikon 70-200 VR II | Nikon 85 1.4D | Nikon 24 1.4G | Crumpler 8MDH
KnightFall Regular Member • Posts: 173
in your dreams :(
Sony never gave us that. I've waited an update for rx100, and RX1 not happened, and not gonna happen I am sure.
Wait for LR5 and ACR updates...
...since I found that there seems to be a problem with Adobe´s camera profiles. The profiles we use seem to be for the RX100 that is somewhat different from color response to the M2.
I tried to make a profile using Color Checker Passport, but the profile doesn´t appear after generation, only from the M1.
By the way I like the genuine Adobe profiles more than the custom made ones using CCP, so may be we shouldn´t judge the camera for it´s color response yet.
Roland.
Tapper123
Re: Wait for LR5 and ACR updates...
Roland.
Interesting point.
I just looked at your photo comparison and it worried me a lot, but I will wait as you say.
newellj Senior Member • Posts: 1,048
Re: in your dreams :(
Not likely, nor with Oly.  Panasonic is the only maker that really does significant firmware upgrades.  But I returned the LX7 and kept the RX100.
 newellj's gear list:newellj's gear list
Sony RX100 II Olympus E-M1 Olympus OM-D E-M5 Panasonic Lumix DMC-G5 Panasonic Lumix G Vario 7-14mm F4 ASPH +5 more
forgot the update for the Nex 5 etc.??
With the NEX5´s update Sony gave us great new features like peaking etc.. But I still wish they would bring a better bracketing at least...
Donald Chin
Donald Chin Veteran Member • Posts: 5,603
Thanks for sharing. IMO the choice between RX100 and RX100II is not in IQ but rather in features and price.
Arn
It's certainly about features and price. But I think that it is also about image quality. After all, Sony claimed improved sensor and image quality with the new sensor, not worse...
Donald Chin
I'm a native raw shooter, from what I've seen so far the IQ of the two is insignificant, you can find similar result from DxOMark too.
pics: http://www.pbase.com/arn
http://500px.com/arnrna
magicomirko Junior Member • Posts: 33
I'm thinking to buy the RX100...the picture on the left is better !!!
eivissa1
eivissa1 Regular Member • Posts: 473
Matter of sharpening
It has been said before: il looks as if the new Sony produces softer pictures, but the details are still there.
Imaging Resource said that the first Sony did more aggressive sharpening....
 eivissa1's gear list:eivissa1's gear list
Panasonic Lumix DMC-LX100
Arn
Re: Matter of sharpening
From what I tried, I actually couldn't produce the details that are in the mkI image by increasing sharpening in the mkII image. I don't think it's a matter of sharpening (and Imaging-resource was talking about JPGs). Anyway, the difference is quite small, but the fact that the mkII doesn't seem to improve RAW image quality. And there is still the fact that mkI's sensor seems to be 1/3 to 1/2 a stop more sensitive.
