Another LF1 blog post -- Random thoughts and Wi-Fi
Started Jul 18, 2013 | Discussions
TKinVA Senior Member • Posts: 1,804
Read it here: Some random thoughts about the Panasonic DMC-LF1
Click on image to see full size
Techno-Impressionist Museum -- http://timuseum.com
Art and the Zen of Design -- http://artzen2.com
Bookstore: http://tonykarpbooks.com
Art in 3D: http://tonykarp3d.com
Pinterest: http://pinterest.com/tonykarp/art-1/
Panasonic Lumix DMC-LF1
Mike Wrob Regular Member • Posts: 247
Re: Another LF1 blog post -- Random thoughts and Wi-Fi
I know you said you were going to leave image evaluation to the review sites, but how do you think image quality compares to your ZS20?
 Mike Wrob's gear list:Mike Wrob's gear list
Sony Cyber-shot DSC-TX5 Panasonic Lumix DMC-LF1 Panasonic Lumix DMC-LX100 Panasonic Lumix DMC-FZ300 Apple iPhone 6s
vincent filomena
vincent filomena Veteran Member • Posts: 5,106
Pany LF1 - It slips into your Shirt Pocket...
The Pany LF1 is a Gem: But, I got the Stealthy White One !
See first 4 pictures in my Gallery !
Vjim
 vincent filomena's gear list:vincent filomena's gear list
Panasonic Lumix DMC-LF1 Panasonic Lumix DMC-G5 Olympus PEN E-PL5 Olympus M.Zuiko Digital 45mm F1.8 Olympus M.Zuiko Digital ED 60mm 1:2.8 Macro +1 more
Peg Bethany Veteran Member • Posts: 3,056
Wow! It is tiny. Seeing it like that makes a bigger impression on me than 4.0 x 2.4 x 1.1"
peg
Impulses Senior Member • Posts: 4,043
I think TK's got big hands... It's small but not noticeably smaller than other similar cameras that have been around for a while (Canon's S line, Panasonic's own ZS travel zooms, etc). I might bulk mine up (by a fraction) and slap a grip on it, that front fascia's gonna be slippery if I've had a drink in my hand or if I've got gloves on etc. Seems Flipbac's grips don't protrude anymore then the control ring already does...
I've barely plated with the WIFI on mine but it's one of the big reasons I got it (much to the chagrin of many a serious photog it seems)... I know it's been said that you have to open the app first before initiating pairing thru NFC (cause otherwise it just opens a web link on your phone) but I'm curious to see if that can be changed.
On my first Android phone I actually had an app that allowed you to change the intents of many different triggers on the phone, like say, what music player would be called up when you press play on an external Bluetooth device (like a car'ssteering wheel controls)... Haven't had it installed in a while tho, might not even work with ICS/JB or it might not reveal any sort of NFC intent, worth a shot tho.
My other thought is just using Tasker to have the app auto launch when the phone detects the camera thru NFC... Kind of a lot of thought just to eliminate one step but what can I say, I'm a geek.
 Impulses's gear list:Impulses's gear list
Panasonic Lumix DMC-GM1 Olympus E-M5 II Olympus M.Zuiko Digital ED 9-18mm F4.0-5.6 Panasonic 20mm F1.7 II Panasonic Lumix G 42.5mm F1.7 +26 more
TKinVA OP Senior Member • Posts: 1,804
Hi Mike
In terms of pure photographic performance, I would choose the ZS20 over the LF1. It has a longer zoom range (which I sorely miss) and slightly better image quality.
However...
The LF1 has a viewfinder and an exposure-lock button (using the Fn) button. So it's what I'm using now.
Life is full of tradeoffs and compromises.
Re: Hi Mike
I have a ZS20 and am very happy with the quality of photos from it.  However, the viewfinder and smaller size of the LF1 are very enticing.  I think I would miss the wider angle at the bottom end more than the added zoom.
Hi Peg
My hands are actually small and this thing is also quite small. It's about the size of the ZS20, but a little thinner and about 2/3 ounce lighter. It's about an inch shorter than my phone and about an ounce heavier.
Perhaps the smallest camera with an EVF.
I suspect that it looks smaller because I'm using it with the EVF and my hands are wrapped around the camera.
But this is how others will see you when you use the LF1.
peg
Re: Hi Peg
Yeah you're probably right, more of a perspective thing... So unusual to see a small P&S up against someone's face these days. I'm finding the EVF a lot more usable than I figured it'd be but I've yet to venture out in the middle of a sunny day to really try it out when I might need it most. Still getting used to the UI in general, so a big shift from my Sony P&S... Menus seem better organized (and more responsive) but it's still throwing me off.
