Banding on long exposures: lens or camera?
Started Jul 15, 2013 | Discussions
Ncedra
Forum MemberPosts: 73Gear list
Jul 15, 2013
Hello all.
I was at a festvial this weekend and took some long exposures with my OMD in Live Bulb mode at base ISO (200) and with a small and very flimsy tripod. I used the 20mm/1.7 lens, which is known for banding issues at high ISOs. On the computer I saw that the long exposures show quite some banding in the sky, which gets worse when PostProduction is not applied very carefully. The live bulb mode als introduces some noise as I have read.
Do you know if this problem is due to the lens or due to the live bulb mode?
If it is the camera, is there a work around? Maybe less captures during live bulb mode?
It was my first try of long exposures with this camera, so I haven't tried other lenses. The pictures were taken in RAW and I tried to be carefully with PP, so the banding is not too prominent on websized pictures. If you look closely, you can see it in the skies on the left and right side.
Wetterleuchten Festival
s_grins
Forum ProPosts: 10,100Gear list
Re: Banding on long exposures: lens or camera?
In reply to Ncedra, Jul 15, 2013
I think this is a sensor + over PP that transferred a night into a day.
Looking for equilibrium...
 s_grins's gear list:s_grins's gear list
Panasonic Lumix DMC-GH2 Panasonic Lumix G Vario 14-45mm F3.5-5.6 ASPH OIS Panasonic Lumix G 20mm F1.7 ASPH Panasonic Lumix G Vario 45-200mm F4-5.6 OIS Sigma 30mm F2.8 EX DN +3 more
Ncedra
Ncedra OP
In reply to s_grins, Jul 15, 2013
The problem is I didn't do a lot of PP: some white balance and only slight changes to exposure and contrast, because I saw that this just emphasises the banding. What turned the night into a day is the 30s exposure and the light pollution in the Innvalley.
s_grins
Did you try to reduce exposure during PP (one stop maybe)?
Bob Tullis
Forum ProPosts: 30,501Gear list
Nice photo.
The 20/1.7 can produce banding, particularly. Anders has found out if one tries to AF the lens for a few seconds before executing the shot the banding may be avoided.
Banding like that may be tamed with a NR app like Dfine (I don't know if other NR apps as of late also have a banding correction feature).
Live Time/Bulb modes can tend to be a little noisier than the standard long exposure, but that's a different matter.
...Bob, NYC
http://www.bobtullis.com
http://www.flickr.com/photos/bobtullis/
"Well, sometimes the magic works. . . Sometimes, it doesn't." - Little Big Man
 Bob Tullis's gear list:Bob Tullis's gear list
Sony Alpha 7S Sony Alpha 7R II Voigtlander 28mm F2 Ultron Olympus 12-40mm F2.8 Sony RX1R II +20 more
Ncedra
Ncedra OP
In reply to Bob Tullis, Jul 15, 2013
Thanks for your input! Tonight I will give the pic a PP rerun with lower exposure settings and look for some NR software.
s_grins
This is my take of your photo:
Ncedra
Ncedra OP
I don't manage to open it in a bigger size, but judging from the image in the thread you are right, there is more night in your pic. Did you just reduce general exposure? Or did you do some more refined PP-magic? I'd like to keep the outlines of the tents in the shadows visible and the bright trace of the headlamp to pop out, so I have to mask these areas for exposure reduction.
s_grins
I did reduce general exposure. Also I've applied a little of blur to reduce noise. All this took not more than 15 sec. You can do it better if you can spend 2 minutes
Ncedra
Ncedra OP
Thanks! I will give it a go tonight!
Anders W
Forum ProPosts: 21,460Gear list
Ncedra wrote:
Hello all.
The kind of banding you show here is due to the lens and the camera combined but has in all likelihood nothing to do with live time/bulb, nor with the long exposure per se. The 20/1.7 is prone to cause banding but only on the E-M5 and other cameras with the same sensor (including the GH3 according to the GH3 manual). So both the lens and the camera is to blame.
The most likely cause is some kind of electrical interference between the circuitry of the lens and the circuitry of the camera (with the 20/1.7 being an unusually strong source of such interference and cameras with the latest sensor unusually sensitive to it). As Bob pointed out, it may help to "warm up" the 20/1.7 a bit before use (give it a few AF cycles) but the exact nature of the problem is hard to nail and I am still not sure this always helps with my own copies of lens and camera, let alone that of others.
Note also that the 20/1.7 is not the only lens that can give rise to banding with the latest sensor generation. I have seen examples of it with other lenses too but the 20/1.7 is in all likelihood the worst "sinner" in this regard.
Live time/bulb will generate slightly more read noise than would the same exposure if shot without the live feature but the difference is fairly small. Further, there is no evidence that I am aware that live time/bulb generates pattern noise (banding), just that the overall noise level increases slightly. More info on the ins and outs live time/bulb here if you are interested:
http://www.dpreview.com/forums/post/50399103
Panasonic Lumix DMC-G1 Olympus OM-D E-M5 Olympus E-M1 Panasonic Lumix G Vario 14-45mm F3.5-5.6 ASPH OIS Panasonic Lumix G Vario 7-14mm F4 ASPH +28 more
Ncedra
Ncedra OP
In reply to Anders W, Jul 15, 2013
Thanks for your extensive reply!
Before I took this picture, I took some others as well and I had to fight a bit with the focussing because it was so dark, so I think the circuits were warmed up.
I read about the high ISO banding of the 20/1.7, but I wasn't aware that it can occur at low ISO as well.
inasir1971
Senior MemberPosts: 3,417Gear list
Did you have IBIS on? For long exposures remember to switch off IBIS/IS.
As someone above suggested, exposing to the right and dropping the exposure in post will help with any banding...
 inasir1971's gear list:inasir1971's gear list
Nikon D4 Nikon D810 Nikon D750
Anders W
You are welcome.
Yes, as I said, I am far from sure that the solution I have suggested is a cure-all. In spite of many long threads on the subject with quite a bit of experimentation, I don't think anyone has quite nailed the causal pattern, let alone found a really good remedy yet. It will be interesting to see if the PCB of the new version of the 20/1.7 that has just been announced will look any different from the old. One might hope that Pany has done something to eliminate the ultimate source, most likely a noisy voltage regulator on that PCB.
If the banding is there, it is there at any ISO but will show less and less the lower you go (since the ratio between signal and read noise gets larger and larger). As a rule of thumb, I'd say it's rarely visible at ISO 1600 or lower and ISO 3200 may not be much of a problem either. At ISO 6400 and higher, there is a fairly high likelihood that you see it.
Did you push the sky of that ISO 200 shot a bit in post-processing? It looks a bit more noisy in the sky than I'd normally expect an ISO 200 shot to be.
Of course, the fact that you used the live time/bulb feature might contribute slightly to the visibility as well, not because the live exposure feature itself causes the banding but because it increases the noise level slightly, thus making any read noise pattern more visible than it would otherwise be.
Ncedra
Ncedra OP
This is how it looks now. The banding is a lot better. I think the Lightroom import settings went a bit crazy.  Corrected that and reduced the exposure. Thank you for your input!
I accidentally left the IBIS on, but I corrected this for the following pictures. I cannot see a difference in sharpness. The tripod was very small and shaky, so all pictures are not supersharp at greater magnification.
s_grins
Good to know. Thanks for informing.
S.
