Filters..how frequently do you guys use them?
Started Jul 15, 2013 | Discussions
SkywalkerR2D2 Forum Member • Posts: 53
How frequently do you guys use the CPL, ND, UV filters? are they really worth buying?
 SkywalkerR2D2's gear list:SkywalkerR2D2's gear list
Canon EOS 60D Sigma 18-200mm f/3.5-6.3 II DC OS HSM
mclewis Contributing Member • Posts: 535
Re: Filters..how frequently do you guys use them?
UV filters are pointless.  If you need protection for the front of the lens beyond what a lens hood provides just get a clear protection filter.  I occasionally use a polariser - when I want a polarised effect.
MarkInSF Senior Member • Posts: 2,216
CPL, sometimes, not often, but still well worth having as nothing gives the same effect; ND, don't own and can do without, but see value for some specific kinds of photography; UV, own one, but only use it in very dirty conditions to keep lens cleaner.   I can always unscrew the UV filter and wash it off.   But most of the time it's in my case.
Barrie Davis
Barrie Davis Forum Pro • Posts: 21,460
I use them very rarely indeed, and I am (was) a professional photographer
However, if you intend using filters at all, no matter how rarely, you will find it impossible unless you actually HAVE them, wont you? So, whatever your level of use, you will always need 100% of a filter.
Baz
"Ahh... But the thing is, these guys were no ORDINARY time travellers!"
Mark B. Forum Pro • Posts: 19,549
UV, never.  There's already a UV filter in front of the sensor, and I use a lens hood to protect the lens.
CPL and ND only occassionally.  Polarizer is useful for enhancing blue skies, especially if there are clouds and the sun is roughly 90 degrees away from the section of the sky.  It's also useful for removing or reducing reflections.  ND is useful for getting a slower shutter speed - think moving water that you want to smooth out.
Mark
Chris R-UK Forum Pro • Posts: 15,318
It depends what you shoot.
I have only used ND and graduated ND filters when shooting landscapes and waterfalls which I don't do very often.
I use CPLs from time to time to eliminate reflections.
UV - don't own any but I might if I took a lot of shots in extreme situations with blowing sand or dust.
Chris R
 Chris R-UK's gear list:Chris R-UK's gear list
Panasonic Lumix DMC-GH2 Olympus E-M1 Panasonic Lumix G Vario 14-45mm F3.5-5.6 ASPH OIS Panasonic Lumix G 20mm F1.7 ASPH Olympus M.Zuiko Digital 45mm F1.8 +3 more
Cailean Gallimore Veteran Member • Posts: 6,082
CPL and ND occasionally.
UV never.
Daisy AU
Daisy AU Senior Member • Posts: 1,564
I have a CPL on my 16-85VR permanently on, plus the hood. I mostly take outdoor photos and if I don't need the CPL, I remove it as needed. I have clear protective filters on all my other lenses, plus the hoods. I own some ND but have not used any yet.
You will find people who believe some filters are not necessary and you will find people like me, who prefer to protect the lens with filters and hoods.
If you are going to buy filters, you can get the biggest size according to what lenses you currently own (and which lenses you intend to purchase in the future), and then use step-down rings to be able to use the one filter with all your other lenses.  Most of my filters are either 67 or 77.
Thanks,
Daisy AU - Brisbane
( Nikon D7000 and V1 )
http://www.flickr.com/photos/ney_images/
 Daisy AU's gear list:Daisy AU's gear list
Nikon D7000 Nikon 1 V1 Nikon AF-S DX Nikkor 16-85mm f/3.5-5.6G ED VR Nikon AF-S DX Nikkor 35mm f/1.8G Nikon AF-S Nikkor 70-300mm f/4.5-5.6G VR +8 more
GreenMountainGirl Contributing Member • Posts: 677
I see a problem with this method.  Using a lens hood will not be possible when using a filter larger than the lens.  OP have said that a hood is not important when using a CPL, but sometimes after adjusting the filter, I snap the lens hood back on before shooting.
For me, the lens hood is protective when using the camera, the lens cap is protective when storing the camera, so UV filters are only useful in dirty conditions, especially with wind.
I own UV filters, seldom use them; CPLs, use them when needed (reflective surfaces, bright sun, skies); grad ND, for sunrise/sunset pictures.
Advice given to me:  don't buy equipment of any kind until you know you need it and will use it.  Photography can be a "money pit" and purchasing filters, lenses, etc. because they sound good is a pathway to having a closet full of items you never use!
Good Luck...
Susan
GreenMountainGirl
 GreenMountainGirl's gear list:GreenMountainGirl's gear list
Nikon D7000 Nikon AF-S Nikkor 24-70mm f/2.8G ED Nikon AF-S Nikkor 70-300mm f/4.5-5.6G VR Sigma 150mm F2.8 EX DG Macro HSM Canon Pixma MX870 +2 more
Yes, this is a problem because using a filter will increase the chances of flare so all the more reason to use the hood.
This is how I always use a CPL.
The only filter I have that I'll use a step-down ring with is a variable ND; it's something I'll use very rarely, and when I do I know it's going to be tripod mounted.  I'll use my hand or hat to shade the lens to keep flare away.
That's great advice
Mark
Tom Axford Senior Member • Posts: 2,805
I use UV filters more-or-less all the time.
I belong to the minority who always use filters for protection. I have UV filters almost permanently fitted to all my lenses as a protection. I find it easier to clean the filter than the front element of the lens (although it is better to keep it clean in the first place).
There are very few situations in which the presence of the filter causes a degradation in image quality, and in those cases I might remove the filter.
In this thread , some examples showed that UV filters can significantly reduce the amount of purple fringing due to longitudinal chromatic aberration. Almost all of the fringing was removed by a stronger than usual UV filter (unfortunately not readily available commercially).
 Tom Axford's gear list:Tom Axford's gear list
Panasonic Lumix DMC-GM1 Olympus OM-D E-M10 II
Daisy AU
Good Luck...
Susan
GreenMountainGirl
In my case, I have screw on lens hoods that match some of my filters, so that when using step-down rings I can still use a hood.
Thanks,
Daisy AU - Brisbane
Re: I use UV filters more-or-less all the time.
I'm not sure I understand this argument.  Whether you're cleaning the filter or the front element, you're still cleaning something.  Lens elements are actually tougher than glass filters and will stand up to multiple cleanings better.
Mark
tim81786 Forum Member • Posts: 77
Now that I am starting to do more landscapes I just purchased a set of Cokin ND grad filters(part of kit with slide holder) a ND filter and CPL.  From what I've heard UV filters are pointless as some others have stated because most lenses already have UV protection.  I can see using it in harsh conditions like sand or slat spray at a beach.  If you're worried about dropping it a lens hood should be sufficient.
 tim81786's gear list:tim81786's gear list
Canon EOS 600D Canon EF-S 18-55mm f/3.5-5.6 II Canon EF-S 55-250mm f/4-5.6 IS II Rokinon 14mm f/2.8 IF ED MC Canon Pixma Pro9000 Mark II +3 more
Mark
UV filters (from a reputable manufacturer) are made out of the same sort of optical glass that is used for lens elements and have the same anti-reflection coatings. In general, I know of no reason to think that one is any softer than the other.
I find the flat filter easier to clean than many front lens elements, which are often curved and recessed more deeply.
However, I also worry less about damaging the filter - it is usually much cheaper to replace a filter than replace a lens.
Doug Pardee
Doug Pardee Veteran Member • Posts: 8,017
Never
I don't think I've used a filter in over five years. I have them; I just don't use them. I don't see the value vs. the tradeoffs — for everyday photography.
For some specific kinds of photography, specific filters can be useful. But if your photography interests lie elsewhere, filters are a waste of money.
The open-source LightZone Project: http://lightzoneproject.org/
 Doug Pardee's gear list:Doug Pardee's gear list
Canon EOS 350D Fujifilm X-T10 Canon EF-S 17-85mm f/4-5.6 IS USM Fujifilm XF 18-55mm F2.8-4 R LM OIS LG G5 +13 more
Tom Axford wrote:
Mark
Never had to replace a lens or had to get one repaired due to front element damage in over 15 years of lens use.  It also depends a lot on where one shoots; I tend not to shoot where there is an abundance of wind, debris, sand, etc.
Mark
Combat By Design
Combat By Design Regular Member • Posts: 285
Hey Luke,
I like my filters... I shoot kind of all over the place, but primarily at a river up in New Hampshire, and local concerts/shows. I almost alway have my polarizing filters on both my 18-135mm and my Zoom lenses as I shoot out doors A LOT, and really only change them out when I'm going to shoot inside.
I'll toss the UV filter I got with the camera on when I'm at shows to protect the lens itself, but that's because I only have a CPL and UV...
The reality of this situation is that you may lose a some sharpness in the photos, but if you like the way the photos look with the filters...shoot with the filters.
They're your photos, its' your art, it's your call...
 Combat By Design's gear list:Combat By Design's gear list
Canon EOS Rebel T4i Canon EOS 7D Mark II Canon EF 50mm f/1.8 II Tamron SP AF 200-500mm F/5-6.3 Di LD (IF) Sigma 50mm F2.8 EX DG Macro +8 more
Klaus dk
Klaus dk Veteran Member • Posts: 3,349
Never. I could probably use an ND filter and a CPL filter, but I haven't felt the need yet.
 Klaus dk's gear list:Klaus dk's gear list
Canon PowerShot S120 Canon EOS 500D Canon EOS 7D Canon EF 35mm f/2.0 Canon EF 50mm f/1.8 II +9 more
Daisy, Screw-on hoods is something I have been meaning to look into.  But thus I haven't had any problems with just snapping the hood on after adjusting the CPL.  I know OP who have the screw-on hoods and it sounds like a time-saver.
Susan
GreenMountainGirl
