Pennsylvania State Capitol
Started Jul 14, 2013 | Discussions
gnagel Veteran Member • Posts: 6,911
5
I recently visited the Pennsylvania State Capitol. It was one of the more impressive capitol buildings that I've seen. All images captured with the D800.
House of Representatives Chamber
State Supreme Court Dome
Capitol hallway
Rotunda ceiling
5
Senate Chamber
6
Rotunda dome
7
State Supreme Court Chamber
8
Green dome
9
Capitol building
Thanks for looking...
Glenn
Nikon D800
Ernie Misner
Ernie Misner Senior Member • Posts: 2,441
Re: Pennsylvania State Capitol
Those look perfect in every way.    You and the D800 are amazing!
Pat Melone Senior Member • Posts: 1,781
WOW fantastic shots well done.
All post by Scott Bowman:-)
Please check out my Flickr page at
http://www.flickr.com/photos/ttocs/
reginalddwight Senior Member • Posts: 2,003
Wonderfully captured. Few State Capitols can rival the ornate architecture of the U.S. Capitol. The one in Harrisburg, PA has nothing to be ashamed of.
gnagel OP Veteran Member • Posts: 6,911
Thanks Ernie, Pat and Reginald...
Glenn
hiro_pro
hiro_pro Regular Member • Posts: 281
these are great shots.   how did you process them?  i dont see the distortion i would expect at those focal lengths?
 hiro_pro's gear list:hiro_pro's gear list
Nikon D600 Nikon AF Nikkor 50mm f/1.4D Tamron SP 24-70mm F2.8 Di VC USD Tamron SP 70-200mm F/2.8 Di VC USD Nikon AF Nikkor 35mm f/2D +4 more
Thanks!
To minimize distortion, I try to level the lens (using the Virtual Horizon feature built into the D800) at the point of capture.  If there a problem remains with the lines not being straight, I bring the image into Photoshop and use the Perspective Crop tool to straighten everything up.
I've been very pleased with the performance of the Nikon 14-24 lens with regard to distortion at its widest focal length.  It seems that I use the 14mm focal length quite often.
Glenn
Ernie Misner
You sure do get an A+ for all that lovely sharpness and excellent compositions.    I don't see the shutter speeds for some reason.    You are on a tripod and they allow that okay?    No HDR here?
Thanks once again ~
Thanks once again ~
Thanks Ernie...
The reason that you don't see the shutter speeds is that all of these are five exposure HDR.  I've visited 11 capitols in the past year and all of them have allowed the use of a tripod (which is a welcome change from what I normally experience in pubic venues).
Glenn
john49brown Regular Member • Posts: 202
You are right that is impressive ...and so are your photographs.
JohnB
 john49brown's gear list:john49brown's gear list
Nikon D300 Nikon D700 Nikon D800 Samsung NX300 Nikon D810 +20 more
JohnB
Thanks John
Glenn
FtoDin5min Regular Member • Posts: 407
gnagel wrote:
Thanks once again ~
Thanks Ernie...
Glenn
Same comments as the ones I just made on your NY state pictures. Amazing pictures.
Funny typo on the use of tripod in public venues...
FTD5
 FtoDin5min's gear list:FtoDin5min's gear list
Nikon D800 Nikon AF-S Nikkor 24-70mm f/2.8G ED Nikon AF-S Nikkor 85mm f/1.4G Nikon AF-S Nikkor 70-200mm f/4G ED VR Adobe Photoshop CS6 extended +5 more
FTD5
Thanks...yes, you never know what kind of typos you'll get when replying via iPhone!
Glenn
Ernie Misner
Glenn, was it you that posted gorgeous HDR shots before of a dilapidated building interior?   If so... I think you said you do a little global processing on your nefs, convert them to .tiff's, the import into the HDR software?    Which HDR software also?    Thanks so much!
Ernie,
Yes, I posted those HDR images of that building.  I usually make just two adjustments to the NEF files before converting them to TIFF's (white balance and distortion corrections)...then import the TIFFs into Nik's HDR Efex Pro2 software.  From there, I let HDR Efex Pro2 blend the exposures.  I then take the blended TIFF back in to Lightroom and/or Photoshop and process it just like any other image (usually adding some contrast back).
Glenn
