My NEX-6 sensor is dirty?
Started Jul 13, 2013 | Discussions
FRANCISCO ARAGAO
Regular MemberPosts: 185Gear list
Jul 13, 2013
I see that spot in the viewfinder even after replacing the lens.
The stain comes out in the pictures.
Can I see sensor dirt through the viewfinder?
NEX-6, 1/320, ƒ/13, ISO 100, 16 mm, Lens E PZ 16-50mm F3.5-5.6 OSS
 FRANCISCO ARAGAO's gear list:FRANCISCO ARAGAO's gear list
Panasonic Lumix DMC-LX3 Panasonic Lumix DMC-FZ40 Samsung Galaxy K Zoom Sony Alpha DSLR-A200 Sony Alpha NEX-C3 +8 more
Sony Alpha NEX-6
Philnw2
Senior MemberPosts: 1,513Gear list
Re: My NEX-6 sensor is dirty?
In reply to FRANCISCO ARAGAO, Jul 13, 2013
Beautiful picture by the way.
Larger "dust" like that is what i think of as a fiber floats around pretty easily.  You need to get yourself  a hand operated rocket blaster - air bulb type of device so you can blow it away without risking any damage to your sensor.  buy one of these blowers designed and cleaned for camera use.  (I've read of people using something designed to blow up air mattresses and toys, - and succeeded in getting talcum powder scattered throughout the inside of their camera - not a good thing to do)
Also, point the lens opening downward when blowing into the camera.  Do not extend the blower nozzle into the interior of your camera body.
I had a fiber like that about a month ago, blowing seemed to move it from one area to another until it finally left the camera.
Phil B
Nex 5n, Pentax K5, Epson R3000
 Philnw2's gear list:Philnw2's gear list
Sony Alpha NEX-6 Pentax K-3 Sony Alpha 7R II Sony FE 55mm F1.8 Sony FE 28mm F2
FRANCISCO ARAGAO
In reply to Philnw2, Jul 14, 2013
Thanks, Philnw2
I never cleaned any sensor, I see that I'll have to take the plunge
Phil B
wb2trf
Senior MemberPosts: 1,983
No problem, just clean it. Here's how
In reply to FRANCISCO ARAGAO, Jul 14, 2013
The sensor has a coating on it that makes it pretty safe to clean it if you exercise reasonable care.
First thing is to try a blower, as another poster has suggested.  Do not use a canned pressure blower as it mulitiiple risks.  The "Rocket blower" is very popular and is what I use.  Hold the nozzle and the bulb, so that the nozzle does not impact the sensor.  If the substance is not sticky, dust for example, it will blow off.
If the blower doesn't work there is a product called "lenspen" that is very good for more stubborn dirt. It comes with a brush and a carbon wand absorber.  First you brush, then you use the carbon wand.  This works very well.
Riquez
Contributing MemberPosts: 918Gear list
Re: No problem, just clean it. Here's how
In reply to wb2trf, Jul 15, 2013
You really should NOT use the lenspen brush end on your sensor. But its OK to use the flat wand tip.
There are various "lenspen" models, one is 'sensorklear' specifically for the sensor, but the regular lenspen (for lenses) has the same wand tip - so its ok to use for sensor.
To clean sensor:
a) first use rocket blower only - it may be enough to blow out the dust & you never need to touch the sensor at all.
b) If that doesnt not work, use a dry cleaning method such as lens pen.
c) if that does not work, use a wet cleaning method such as Sterile wipe or special cleaning kit.
LensPen method
1) On your NEX menu settings put the camera into cleaning mode. Turn off camera as prompted.
2) Remove lens & hold the camera so that the sensor is vertical or facing down (its better to avoid having the sensor facing up so more dust can get in)
3) Use the wand tip to clean the sensor, don't press hard, but just some light pressure to clean it is ok. Dont use the brush end because it can transfer particles from around the sensor & its not a soft brush, its a bit 'scratchy'.
4) Use a rocket blower (hand held squeezy bulb type) to blow out any remaining dust or carbon - again, hold the camera with the sensor facing down so any dust can fall out.
5) Replace lens. You're done.
Check the results by taking a photo at f22 of white computer screen (make a blank text doc). Slow shutter is fine, wiggle the camera a little when you take the shot as this will ensure any spots you see are sensor spots & not spots on your computer screen. You can adjust the levels/contrast of the image to help show up any remaining dust. Some minor faint spots can be left alone as acceptable, you will never see them in real photos.
If you need to resort to wet cleaning then you are best to get a special kit. But you can do a DIY method: http://www.cleaningdigitalcameras.com/howto.html
 Riquez's gear list:Riquez's gear list
Sony Alpha NEX-6 Sony E 16mm F2.8 Pancake Sony E 30mm F3.5 Macro Sony E 55-210mm F4.5-6.3 OSS Sony E 35mm F1.8 OSS +10 more
wb2trf
In reply to Riquez, Jul 15, 2013
What's your source for this claim?  I don't think there is any problem with the brush, unless there is some information I'm not aware of.
Riquez
http://www.cleaningdigitalcameras.com/methods.html
LensPen/DigiKlear™ - This technique has been seen being used by Canon Techs, although it isn't their official policy. Due to the fact that the LensPen can't be cleaned, it should be disposed of and replaced on a regular basis.
  1. Clean the Low Pass Filter with a foot or hand blower.
  2. Wrap a dry kimwipe or Pec*Pad™ in a pair of tweezers making sure the wrapped product sticks out much farther than the tweezers tip.
  3. Wipe the Low Pass Filter clean with the wrapped tweezers. This is more of a brushing than a rubbing exercise, do not put any force from the tweezers onto the Low Pass Filter.
  4. Polish off the Low Pass Filter with the pad end of the LensPen NOT the brush end.
The website quoted above is run & maintained by camera technicians who work or worked at various big brand manufacturers & are experts in cleaning & maintaining cameras. So its probably the best advice you can hope to get.
GingerBread
Regular MemberPosts: 384Gear list
In reply to FRANCISCO ARAGAO, Jul 15, 2013
The sensor dust is much less likely to show if you don't use really small apertures like f/13.  That should should be fine at f/8 or even wider.  As a general rule, I avoid shooting at anything smaller than f/8 on my NEX.  Dust may be large enough to still show at f/8, but it won't be as offensive as at f/13.
Ging
 GingerBread's gear list:GingerBread's gear list
Sony RX100 Panasonic Lumix DMC-LX7 Nikon D700 Sony Alpha NEX-7 Panasonic Lumix DMC-GX1 +3 more
RichardLarssen
Contributing MemberPosts: 995Gear list
I use a rocket blower and if that fails i use a q-tip to wipe the sensor....
Photography for me is not about recreating what i saw through
the viewfinder but to show people the way i want to see the world
Cheers!
Richard Larssen http://www.flickr.com/photos/uberdogleg/
 RichardLarssen's gear list:RichardLarssen's gear list
Sony Alpha NEX-6 Sony Alpha 7 Samyang 14mm F2.8 IF ED MC Aspherical Sony FE 55mm F1.8 Sony FE 70-200 F4 +2 more
FuzzyQball
Senior MemberPosts: 1,350Gear list
I had dust all over my sensor.  Would not blow off, so did a wet clean.  Worked well.  The sensors in these cameras get dirty quickly so investing in cleaning kits and blowers is a must!
Glenn
 FuzzyQball's gear list:FuzzyQball's gear list
Sony Alpha NEX-5N Sony a6000 Sony E 18-55mm F3.5-5.6 OSS Sony E 50mm F1.8 OSS Sony E 55-210mm F4.5-6.3 OSS +1 more
FRANCISCO ARAGAO
In reply to FRANCISCO ARAGAO, Jul 16, 2013
I used a rocket blower and the dirt gone.
Thanks God, no Lenspen, at least now
Thanks, everybody, much appreciated
RonFrank
Senior MemberPosts: 2,128Gear list
I use and recommend eclipse solution and a pec pad with a spatula like tool. I have been using this method for more than a decade.
http://www.luminous-landscape.com/essays/sensor-cleaning.shtml
All sensors get dirty over time.
 RonFrank's gear list:RonFrank's gear list
Nikon D1X Nikon D200 Nikon D300S Sony a6000 Nikon AF-S DX Nikkor 18-200mm f/3.5-5.6G IF-ED VR +7 more
