7d problem shows "Err CF" and "Cannot write to card"
Started Jul 12, 2013 | Questions
Grogly
Grogly Contributing Member • Posts: 575
Hi All,
I am in a bit of a panic because my 7D has the above errors associated with my CF function. The top display says "Err CF" and the back display says "Cannot write to card." Anybody seen this before and found a way around it?
Here is what I have tried:
I have 3 CF cards, all have the exact same behavior error as mentioned above. The camera will lock all functions except for menu operations.
I have removed the battery and replaced it.
I am able to read the cards while in the camera and view files on them, so I am pretty sure that they are not the problem.
I removed the card and changed the mode to allow shooting without the card and the camera behaves normally and the shutter will fire, AF works and IS works on my lens.
I have changed operational modes using the mode dial, no difference in behavior
I have changed from my normal RAW mode to JPG and back with no change in behavior.
Live view has the same error messages.
Removing the lens and replacing it has the same error messages.
I have inspected the pins on the DF connector internal to the card slot and they look normal, no bent pins.
That's all I can think of now, I have done other things though. Thanks in advance for your help.
Rod,
Photographic hack since 1969.
Samples of my favorite images can be found here:
http://www.flickr.com/photos/grogley/collections/72157600201558641/
 Grogly's gear list:Grogly's gear list
Canon PowerShot G10 Canon EOS 5D Mark III Canon EOS M Canon EF 28mm f/1.8 USM Canon EF 50mm f/1.4 USM +10 more
Canon EOS 7D
mailman88
mailman88 Veteran Member • Posts: 5,579
Re: 7d problem shows "Err CF" and "Cannot write to card"
did you format your cards?
 mailman88's gear list:mailman88's gear list
Canon EOS 30D Canon EOS 7D Canon EF 50mm f/1.8 II Canon EF 200mm f/2.8L II USM Canon EF-S 10-22mm f/3.5-4.5 USM +4 more
Dale Buhanan MOD Veteran Member • Posts: 4,002
Grogly wrote:
Hi All,
That is what will happen if the write protect tab on the card got moved to lock somehow.  Just a thought.
kind regards
Dale
 Dale Buhanan's gear list:Dale Buhanan's gear list
Canon PowerShot SX50 HS Canon PowerShot G1 X II Canon EOS 70D Canon PowerShot SD500 Canon PowerShot G5 +34 more
Grogly
Grogly OP Contributing Member • Posts: 575
I only format my CF cards in the camera. Currently, I cannot format the cards since the camera tells me I cannot write to the card.
I am away from home for a few days but when I get home, I will format the card in a PC.
Rod,
Grogly
As far as I can tell, there is no lock tab on these cards that I use.
Rod,
David Yule Regular Member • Posts: 191
It's a long shot, but you could try removing the date backup button cell as well as the main battery. Leave both out the camera for a few minutes. You'll probably lose all custom settings if you do this though.
I've had card write errors 2 or 3 times in the three years I've owned a 7D, twice with the same card. Taking the main battery out cleared the problem each time.
Have you got firmware 2.03 installed? The errors I got were with older firmware.
David
garykohs Veteran Member • Posts: 4,046
If no pins are bent then one of them must have gotten pushed in. Take a look at this video:
http://www.youtube.com/watch?v=TjYeC7gqL5k
 garykohs's gear list:garykohs's gear list
Konica Minolta Maxxum 7D Canon EOS-1D X Sony SLT-A99 Sony a77 II Canon EOS 7D Mark II +13 more
Grogly
Thanks for the reply, I currently have FW 2.0. I was not aware of a later FW. I will try that if I can find the FW update.
The button cell? Where is that thing? I will have to google that I guess. I will try that first before the FW.
Rod,
Grogly
I have taken a photo of the CF slot to inspect the pins. All seem normal (I am familiar with inspecting these types of images for my job.) except two pins on either side of the connector look "shorter" than the other pins. Here is a link to the photo:
http://www.flickr.com/photos/grogley/9274042633/
This may be normal for CF slots but since I have never inspected my previous cameras, I am not sure and I can't find anything online that says anything about the pin heights for CF.
Rod,
Lemming51
Lemming51 Forum Pro • Posts: 14,051
Re: 2.0.3
Link for v2.0.3 from Canon USA:  http://consumer.usa.canon.com/cusa/consumer/products/cameras/slr_cameras/eos_7d#DriversAndSoftware
2.0.0 had some bugginess for some users and Canon released 2.0.3 shortly after (link above lists the release date as Sept. 13, 2012).
Unapologetic Canon Apologist
 Lemming51's gear list:Lemming51's gear list
Canon EOS 40D Canon EF 50mm f/1.8 II Canon EF-S 15-85mm f/3.5-5.6 IS USM Canon EF 70-200mm f/2.8L USM +5 more
phill104 Senior Member • Posts: 2,704
Rod,
That is correct, those two are designed to be shorter.
Grogly
Re: 2.0.3
I updated the FW, didn't help.
I removed button cell and battery, didn't help.
Ugh!
Rod,
tesch Regular Member • Posts: 437
I had this very same problem with my camera of another brand. I sent it into warranty and they found corrosion on the main board so it had to be replaced. Not saying this is your problem, but you may have to send it in. Sorry, man!
 tesch's gear list:tesch's gear list
Sony Alpha DSLR-A100 Sony Alpha DSLR-A500 Sony SLT-A77 Sony Alpha 7 Sony DT 18-55mm F3.5-5.6 SAM +6 more
Don Richardson Senior Member • Posts: 1,454
You didn't mention Read/Right speed of your cards. They've come out with faster cards since the 7D came out (800X and 1000X). Is it possible your card is not recognized by the 7D.
 Don Richardson's gear list:Don Richardson's gear list
Canon EOS 7D Tamron SP 150-600mm F/5-6.3 Di VC USD Epson Artisan 835 +1 more
Grogly
All three cards I use exhibit the issue. I have been using them for 2 two year and always have worked fine. I have two Kingston 16GB 266x cards and one Transcend 32GB 400x card. These are not that old or fast that they should be a problem.
Rod,
Mark B. Forum Pro • Posts: 19,569
kind regards
Dale
CF cards don't have a write protect tab.
Grogly
Thanks to all. I have tried everything I can think of and all your suggestions and still the camera is misbehaving. It looks like I will be dropping it off at the NJ service center on the way home from my trip. Argh!
Rod,
The pins look the same as my 7D.
David
