Fuji Finepix HS50EXR problem
Started Jul 12, 2013 | Questions
grahamedwards New Member • Posts: 1
Hi all , i have just taken delivery of a new HS50EXR - i have installed memory card and set time etc - tried a pic outside and it came out almost totally white , tried indoors and pics are coming out very dark and very green / yellow - hard to explaint but in a nutshell the pics are rubbish !!
I have tried on various settingsto no avail - anyone got any ideas ?
Thanks in advance
Jim A Regular Member • Posts: 246
Re: Fuji Finepix HS50EXR problem
Try a reset. Then shoot in P mode if it does not work send it back.
Jim :^)
 Jim A's gear list:Jim A's gear list
Panasonic Lumix DMC-FZ1000 Canon EOS 7D Canon EF 100-400mm f/4.5-5.6L IS USM Canon EF 24-105mm f/4L IS USM Canon EF 70-200mm f/4L IS USM +26 more
Steve40
Steve40 Regular Member • Posts: 445
I recently received a HS35, basically the same camera. Mine was fine, the HS cameras seem to be happy with about a -2ev setting, as they tend to over expose slightly. But it sounds like you have a bad one, I believe you need to exchange it.
Steve40.
http://steveslandscapes.50webs.com
Cameras: Canon's G12, and A1200. Sony DSC-H90. Fuji HS35EXR.
AdamT
AdamT Forum Pro • Posts: 58,440
The HS35 is basically the same camera as the HS30
the HS50 is a different beast altogether and a reset may sort out its whacky metering issues if not then as the other guy said, sounds faulty
Canon PowerShot G1 X Nikon Coolpix P330 Panasonic Lumix DMC-GM5
AlanJones Junior Member • Posts: 32
I have a new HS50 with the same issue. Unless i use the flash I get the funky yellow/green photo. Not what i expected from this camera.
Kim Letkeman
Kim Letkeman Forum Pro • Posts: 33,336
-2EV? That's a brutal underexposure and will dramatically increase your noise. I will go as much as -1EV for lights at night or for ultra contrasty conditions, but -2 is very rare indeed ...
 Kim Letkeman's gear list:Kim Letkeman's gear list
Nikon Coolpix 990 Fujifilm FinePix F200EXR Fujifilm FinePix F770EXR Panasonic Lumix DMC-GH2 Panasonic Lumix DMC-GF3 +16 more
Kim Letkeman
the EXR article ...
Thanks in advance
Read the first section and see how you get on ...
Nothing Special: How to Shoot an EXR Camera
Re: the EXR article ...
Kim,
Thanks for the informative article. I will put recommendations in this article into practice later on today. I have a lot to learn with shooting an EXR but I look forward to the journey.
Alan
Steve40
That's what they call a typo, it should be .67 or two clicks of - EV.  In extreme conditions maybe a full stop -1ev, but not often.
Steve40.
Steve40
I don't know the conditions, or settings you are getting this "Yellow-Green" effect from. But I discovered, if I have my color set to low. at several settings of the EXR mode I will get this effect, setting the color back to STD cures it. But it only occurs, in the EXR mode. I do remember one!, is with the "Pro Low Light" setting.
There could be other settings that cause this problem, so set everything back to default, and see if it cures the problem.
Steve40.
Kim Letkeman
Whew
Kim Letkeman
Using film modes like ASTIA (SOFT) and VELVIA (VIVID) are a sure recipe for out of control chroma noise indoors. Always shoot PROVIA (STANDARD) when indoors. And I still recommend the P mode DR400 to soften the tone curves. That gives you slightly flatter tones, but the end result is simply cleaner. It also has the advantage that lights do not automatically give hard burnouts ... SN mode may have slightly better noise characteristics, but the DR100 tone curve makes the images look harsher and makes lights blow out.
DR400 M size is your friend with EXR cameras ... every day, and all the time.
Kim Letkeman
Depends on your settings ... see my last post in the thread:
http://www.dpreview.com/forums/post/51805995
PerH Contributing Member • Posts: 748
I totally agree with you
/PerH
 PerH's gear list:PerH's gear list
Panasonic Lumix DMC-FZ30 Panasonic Lumix DMC-FZ1000
jcmarfilph Veteran Member • Posts: 7,592
Thanks in advance
Strange coz mine worked flawlessly with or without tune up. It must be a defective one so try a reset and return it if problem persists. And don't listen to those suggesting MSize DR400 is the right setting. It's for lazy people or those who don't know how to maximize EXR camera. Lsize RAW will give you the optimum result.
-=[ Joms ]=-
 jcmarfilph's gear list:jcmarfilph's gear list
Fujifilm X20 Fujifilm FinePix HS50 EXR +1 more
PAUL TILL
PAUL TILL Veteran Member • Posts: 9,285
I've got nothing against people having an opinion, but you've NEVER shown any pictures to prove that Joms. In fact, 99% of what you've shown just goes to prove that shooting L size DOESN'T work.
If it's an EXR camera you shoot it at half resolution, end of story.
The 10% Rule:
You Must Be 10% Smarter Than The Equipment You're Operating
Kim Letkeman
seriously flawed advice ...
Thanks in advance
I agree with Paul. You say it all the time, but your examples are not compelling.
Just an example of the forum fringe trying to hoodwink people into shooting a sensor designed for extended dynamic range and noise control into shooting it without the benefit of either feature ...
I mean ... really .... you gotta be kidding at this point.
Re: seriously flawed advice ...
Thanks in advance
I am serious. You are throwin half of pixels worth of detail with a mere DR recovery. Time to get out of your cave really,
-=[ Joms ]=-
Steve40
I'm sorry but the DR function, is something I could do without As the previous poster stated, it will cost you detail, and causes more noise. As does setting file size to M, you are still getting all the noise from the unused pixels, and no image information. This results in less signal and, more noise. With any digital camera, bar none.
I have finally come to peace with my HS35, Like other digital cameras it does some things wel, l but by far not all. The only EXR function I can say I really like is the "Hi ISO Low Noise" one. Other than that! operating the camera in either M or P mode, with a lot of things turned down is the best way to fly.
Steve40.
(unknown member) Contributing Member • Posts: 500
The pixels aren't unused. If you don't care for higher DR, then fine, but the effect is quite good, and the pixels are used.
 cantanima's gear list:cantanima's gear list
Fujifilm FinePix 2600 Zoom Fujifilm X10
