Can a lens be too pwerful for a camera
Started Jul 9, 2013 | Discussions
CShell12 Forum Member • Posts: 56
Right I know I haven't put that very well so forgive me.
I have the A55 with a 70-300g and 70-400g lens.
When I have the A55 with the 70-300 the images look great, but when I put the 70-400g lens on they look worse.
I am wondering if the 70-400g is, if you like, too powerful for the sensor, too much resolution for it capable to handle and would it be better on a full frame sensor?
Or have I got a crap copy of the the lens
Cheers
 CShell12's gear list:CShell12's gear list
Sony Cyber-shot DSC-H5 Sony SLT-A55 Sony SLT-A99 Sony 70-300mm F4.5-5.6 G SSM Sony 70-400mm F4-5.6 G SSM +4 more
Sony SLT-A55
JimmyMelbourne Senior Member • Posts: 2,441
Re: Can a lens be too pwerful for a camera
The 70 400 demands more attention to the photographer skill. You could have a bad copy or you may not be using it to its full potential.
 JimmyMelbourne's gear list:JimmyMelbourne's gear list
Sony Alpha DSLR-A300 Sony SLT-A77 Sony SLT-A37 NEX-5T Sony Alpha 7 +20 more
Chimere
Chimere Senior Member • Posts: 1,463
May be you can post some samples, so we see the "worse", can judge what your problem might be ?
Chimere
GJWhite
GJWhite Regular Member • Posts: 152
Had very similar problem, have both those lenses, a couple of years ago I was getting terrible results with it on my A700, turned out to be the Hoya Protection filter, a god one on the 70/300 and a bad one on the 70/400, they looked OK to the eye.  Now leave them off and great results, just a thought.
Gordon White - New Age Pensioner - "Get in the Slow Lane of Life, it's much more fun"
 GJWhite's gear list:GJWhite's gear list
Sony Alpha DSLR-A700 Sony SLT-A77 Sony a77 II Tamron SP AF 10-24mm F/3.5-4.5 Di II LD Aspherical (IF) Sony 70-300mm F4.5-5.6 G SSM +16 more
Sonyshine
Sonyshine Senior Member • Posts: 7,680
The 70-400G works fine on the A55. Its just a much bigger, heavier lens needing skill to extract the full potential.
 Sonyshine's gear list:Sonyshine's gear list
Nikon 1 V2 Nikon 1 J5 Nikon 1 Nikkor VR 30-110mm f/3.8-5.6 Nikon 1 Nikkor 10mm f/2.8 Nikon 1 Nikkor 18.5mm f/1.8 +7 more
CShell12 OP Forum Member • Posts: 56
Hi
Thanks for the replies.
The shots that I took that I wasn't pleased about where done using a Monopod, however, I don't have the steadiest of hands so I did some shots using a tripod.
Theses where much better, but as a few have said you need skill using it to get the best results, seems I'm going to have to keep practicing.
So it looks like with they weight, and the shaky hands, I'm going to have to use it on a tripod to get the best results
Marco Cinnirella
Marco Cinnirella Veteran Member • Posts: 5,111
Hi
Look up my recent, very long thread about my 70-400 - I seem to be getting better results with no filter attached, but using the 70-400 takes practice and I still need to use 1/1000 shutter at the moment to get the best out of mine.
"When words become unclear, I shall focus with photographs. When images become inadequate, I shall be content with silence." Ansell Adams.
 Marco Cinnirella's gear list:Marco Cinnirella's gear list
Fujifilm FinePix X100 Sony SLT-A77 Olympus OM-D E-M5 Sony SLT-A99 Fujifilm X-T1 +4 more
busch
busch Forum Pro • Posts: 31,430
Marco Cinnirella wrote:
(clip)
Marco, I shoot most of my aircraft shots handheld at around 1/350 and get pretty good results IMO. Examples:
Busch
Take the scenic route! Life is too short to do otherwise.
My Photos
 busch's gear list:busch's gear list
Sony Cyber-shot DSC-R1 Panasonic Lumix DMC-ZS7 Sony a77 II Sony 70-200mm F2.8 G Sony 16-35mm F2.8 ZA SSM Carl Zeiss Vario-Sonnar T* +11 more
Marco Cinnirella
(clip)
Busch
My Photos
Hey Busch - undeniably great shots - it must be those fighter pilot nerves of steel and steady hand - my nerves are shot to shreds and I have shaky hands, so maybe my high shutter speed requirements are different to those of the average person...
headfirst
headfirst Contributing Member • Posts: 670
of course it could also be that your 70-400 is back/front focusing on that body (which unfortunately does not have micro-adjust).
 headfirst's gear list:headfirst's gear list
Konica Minolta Maxxum 7D Sony Alpha DSLR-A200 Sony Alpha DSLR-A700 Sony Alpha DSLR-A580 Sony SLT-A77 +8 more
Marco Cinnirella
Yes, should be easy to test for that, though nothing you can do other than upgrade to an a77/a99 or get Sony to re-calibrate the lens to your camera
seilerbird666
seilerbird666 Senior Member • Posts: 1,101
I have owned an a55 since they first came out and I have taken thousands of shots with my Tamron 200-500 at the 500mm end so I know for fact that the 70-400 is not too powerful for the camera.
Your problem is definitely too slow of a shutter speed. You should not use anything less than 1/1000th of a second. If the light is too dim for that shutter speed then put the lens away.
My photos:
picasaweb.google.com/seilerbird
RichV Veteran Member • Posts: 6,135
One other thing you can try
As mentioned elsewhere, you might have a focus alignment issue (in addition to a stability problem). Maybe a good way to try it is to shoot the same subject (one with detail to it and good lighting) from the tripod - one shot with AF and another with magnified manual focus. While the magnified MF should always look better (relative to distance and object characteristics), if there's a huge difference then you should look to further testing for back/front focus. Also realize that if your style include focus-recompose, you could lose some accuracy, depending on subject distance and angle.
Rich
 RichV's gear list:RichV's gear list
Sony RX100 Sony SLT-A77 Sony SLT-A99 Sony 70-200mm F2.8 G Sony 50mm F1.4 +6 more
