could not resist the K-5 II offer
Started Jul 7, 2013 | Discussions
Kerusker
Kerusker Contributing Member • Posts: 885
yes I upgraded from my K-5 to the K-5 II because of a special offer adding to the PENTAX cash back (50 €). The K-5 IIs would be 350€ more currently in Germany.
Main reason: I wanted to check the new AF sensor for apertures of 2.8 or faster.
My K-5 is very bad in catch in focus (CIF) with my old M and A lenses (28/2, 35/2, 50/1.4, 85/2) but hurrayh - the K-5 II does a very good job with it's additional center sensor for fast lenses.
That's the main reason why I will keep it. For the first time I can securely focus my fast M and A lenses.
I can use CIF or the focus confirmation (hexagon) for fast lenses now.
It seems I was lucky to get one of the better bodies:
Manufactured in January this year having Production Code 2.2.
I tested a K-5 II from Oct 2012 with Production Code 2.1 for a week and I didn't see too much difference to my K-5.
When I switched from SLR to DSLR, about 2008 I bought three used K10Ds with Prod. Codes 1.1, 2.2 and finally 2.1 (because of a high external serial number). The second one was the best of those.
Does anybody know the meaning of the second digit of the PENTAX camera Production Code (in EXIF data)?
Now I will sell some bodies and/or lenses to justify the upgrade.
][.Kerusker
we don't see that we don't see (eye's blind spot)
 Kerusker's gear list:Kerusker's gear list
Pentax K-5 II Pentax K-5 Pentax smc DA 15mm F4 ED AL Limited Pentax smc DA* 16-50mm F2.8 ED AL (IF) SDM Pentax smc DA 55-300mm F4.0-5.8 ED
Pentax K10D Pentax K-5 Pentax K-5 II Pentax K-5 IIs
Petroglyph
Petroglyph Senior Member • Posts: 4,812
Re: could not resist the K-5 II offer
Very interesting information.  Thank you.
Do you think Pentax have updated the firmware in this interval?  The K5 went to ver. 1.14 somewhere in there.
][.Kerusker
 Petroglyph's gear list:Petroglyph's gear list
Pentax K-3 Sony Alpha 7R II Pentax smc DA* 60-250mm F4.0 ED (IF) SDM Pentax smc DA* 300mm F4.0 ED (IF) SDM Pentax smc FA 43mm F1.9 Limited +4 more
Kerusker
Kerusker OP Contributing Member • Posts: 885
I updated the one of Oct 2012 to FW vers 1.03.21.09 before using it; but I did not test the AF sensor for fast lenses at that time.
The K-5 II from Jan 2013 I got came with FW 1.00.00.02 whereas very early bodies came with vers. 1.00.00.00.
][.Kerusker
ASR45
ASR45 Forum Pro • Posts: 34,791
Have fun.
The K-5II is an excellent camera.
Alan.
It is better to keep your mouth closed and let people think you are a fool than to open it and remove all doubt.
Mark Twain
 ASR45's gear list:ASR45's gear list
Canon PowerShot G16 Canon EF 100-400mm F4.5-5.6L IS II Canon PowerShot G12 Canon EOS-1D X Canon EOS 5D Mark III +7 more
Barry Pearson
Barry Pearson Veteran Member • Posts: 6,904
What is a Production Code?
How do I find the Production Code of my K-5IIs?
 Barry Pearson's gear list:Barry Pearson's gear list
Panasonic Lumix DMC-LX100 Pentax K-3 II Pentax K-1 Pentax smc DA* 55mm F1.4 SDM Pentax smc DA 10-17mm F3.5-4.5 ED (IF) Fisheye +19 more
Kerusker
Each jpg image file contains EXIF data which can be read out by different tools (f.ex. exiftool).
In section 'Manufacturer Data' there you find
  • 'Manufacture Date'
  • 'Production Code'
  • 'Internal Serial Number'
These are generic names created by the exiftool.
I only have some guesses about 'Production Code' (PdC = x.y)
When a body was serviced, usually x is set from 1 or 2 to 8 (at least for K10D; don't know about now).
y seems to be an indication for the build status of the body - but no body really knows for sure. During a production cycle some parts may be replaced or upgraded. Till now I only saw y = 1 or 2 for the PdC.
Wild guesses aren't helpful so take it with a big grain of salt.
][.Kerusker
Barry Pearson
  • 'Production Code'
Thanks. I've just exiftool on a DNG from my K-5IIs:
Manufacture date: 2012:12:14
Production Code: 2.1
I haven't used catch-in-focus. But I have used AF-S a lot in my studio and elsewhere, and AF-C a lot for airshows and motor sports. Both are better (I think much better) than my K-5.
