A Hypothetical "Larger than full-frame": Lens Question
Started Jul 7, 2013 | Discussions
Mike Stratil
Contributing MemberPosts: 794Gear list
Jul 7, 2013
Canon Rumors has passed on rumor that Canon may be preparing a larger than full frame DSLR.
For those with appropriate technical expertise, I have a question. Is it technically possible that such a camera could use existing EOS full-frame lenses?
Michael S
Keith Z Leonard
Veteran MemberPosts: 5,377Gear list
Re: A Hypothetical "Larger than full-frame": Lens Question
In reply to Mike Stratil, Jul 7, 2013
I wouldn't think so, EF lenses are designed to project an image circle to cover 35mm format film.  There MIGHT be some wiggle room there, of course, but it isn't really as though those lenses are going to cover a medium format sized sensor.
 Keith Z Leonard's gear list:Keith Z Leonard's gear list
Canon EOS 5D Mark III Canon EF 70-200mm f/4.0L USM Canon EF 100-400mm f/4.5-5.6L IS USM Sigma 50mm F1.4 EX DG HSM Canon EF 24-105mm f/4L IS USM +15 more
David Mosby
New MemberPosts: 17
Michael S
Surely it would be possible to have a square sensor, larger than full frame. This would be ideal - you could still have in-camera cropping for other formats, for those who want them.
Johanfoto
Veteran MemberPosts: 3,256
In reply to David Mosby, Jul 7, 2013
Michael S
This is a common misconception. Many people think that full frame lenses could be used with a 36 x 36 mm sensor, because they are now also used with a 36 mm wide sensor. That is not true. A square sensor would have to be smaller than 36 x 36 mm (30 x 30 mm) in order to stay within the image circle of an full frame lens, so there's little advantage (if any) of a square sensor.
I explained that on my website some two years ago for a similar rumor about a Samsung larger-than-full-frame camera (that never materialized either):
http://www.johanfoto.com/2011/05/samsung-medium-format/
Toccata47
Senior MemberPosts: 2,777
It's possible just as it's possible to use m4/3 lenses on aps-c cameras now. You won't get the benefit of the whole sensor so there's little reason to do so.
As you probably know, larger than full frame cameras came first. There are a few digital medium format cameras around today but they are typically fairly expensive relative to their 135mm counterparts.
Michael S
hotdog321
Forum ProPosts: 15,155Gear list
I doubt it; I imagine they will introduce a line of specialty lenses for this hypothetical camera or the corners will be hopelessly soft. Most full-frame lenses barely cover the 35mm frame size--that's why the corners and edges are so critical.
One possible exception might be the t/s lenses. I don't know but would be glad for some input.
 hotdog321's gear list:hotdog321's gear list
Canon EOS 5D Mark III Canon EF 70-200mm f/2.8L IS II USM Canon EF 24-70mm f/2.8L II USM Canon EF 16-35mm f/4L IS USM Canon EF 11-24mm F4L +1 more
Press Correspondent
Veteran MemberPosts: 3,345Gear list
Circle Sensor
In reply to Johanfoto, Jul 7, 2013
Michael S
The best invention would be a circle shaped 43-mm diameter sensor allowing a choice of 24x36 conventional (2x3) or 30.5.x30.5 square or 19x38 panorama (1x2) or 25.5x34 (3x4) or any othe proportion like 13.67x41 (1x3) at will.
 Press Correspondent's gear list:Press Correspondent's gear list
Olympus XZ-1 Canon EOS 5D Mark III Canon EF 50mm f/1.4 USM Canon EF 17-40mm f/4.0L USM Canon EF 70-200mm f/4.0L USM +11 more
Press Correspondent
In reply to hotdog321, Jul 7, 2013
Yes, you could use the shift lenses without shifting on a larger sensor. The 17mm and 24mm allow a 1.55 times larger frame, the 45mm and 90mm allow a 1.35 times larger frame in each dimention. The corner quality and vignetting of course are concerns, but this is possible. However, with manual focus and no shift, this is hardly better than using a third party medium format lenses with an adaptor.
Muresan Bogdan
Regular MemberPosts: 496Gear list
It also depends on the distance from the lens to the sensor. The image is projected on the sensor so as you get further the image gets bigger, just like your office projector. So in theory you could use the lens. You would lose infinit focus and probably some IQ also.
 Muresan Bogdan's gear list:Muresan Bogdan's gear list
Canon EOS 5D Mark III Fujifilm X-T1 Canon EF 50mm f/1.4 USM Canon EF 85mm f/1.8 USM Canon EF 24-105mm f/4L IS USM +1 more
Phil
Senior MemberPosts: 2,989Gear list
Michael S
I would expect to see Canon push the resolving power beyond current sensors for a select group of lenses then notch up the body resolution.
I'm already past the medium formats photos my customers got a few years ago so I don't think there would be enough market for them to move is that direction.
Phil Agur
5DMKII - 5DMKII Dual Body Bag - Go 'L' and don't look back!
 Phil's gear list:Phil's gear list
Canon EOS 5D Mark II Canon EOS 5D Mark III Canon EF 17-40mm f/4.0L USM Canon EF 24-70mm f/2.8L USM Canon EF 70-200mm f/2.8L IS II USM +4 more
Mike Stratil
Thanks for the input
This input is very helpful. I own a lot of good Canon lenses, and the possibility of being able to use them with a new high res camera has been very appealing. Right now I am doing most of my photography with the Sigma SD1-M, whose resolution I find significantly better than that of my 5D3. Which is to say I've fallen in love with high resolution photography. But the SD1-M's deficiencies (especially slow write speeds and no live view) have been a negative. Thus, I've been very interested in the possibility of a high res Canon DSLR.
But if such a camera means getting a new suite of Canon lenses, that changes the equation a lot. It sure would be helpful if Canon would give us a clearer idea of where they plan to go.
Michael S
Press Correspondent
Re: Thanks for the input
In reply to Mike Stratil, Jul 8, 2013
Higher resolution doesn't automatically imply a bigger sensor. Nikon D800 has over 36mp with a stunning quality.
Press Correspondent
In reply to Muresan Bogdan, Jul 8, 2013
I don't think the image circle of a lens increases with the image at closer distances. The image increases in size, but does not keep the same quality at the edges. The projector lens in your example is reversed. It is a known technique to reverse the direction of a lens for extreme macro work. The same technique could be used to increase the image circle at close distances. To summarize, in your example, in addition to a closer distance, you would also need to flip the lens back forward to use it with a larger format.
Muresan Bogdan
In reply to Press Correspondent, Jul 8, 2013
Well it increases in size as the distance from the sensor gets bigger. And I already mentioned that there might be a loss in image quality. On the old medium format some people used FF lens with the help of an extension tube.
Reversing the lens gives you magnification more than increse of the image circle. But as I said this technique has been used in the past: using the lens in normal position with an extension. But in normal position not flipping it back-forward.
tim73
Regular MemberPosts: 444
In reply to Johanfoto, Jul 8, 2013
There's also the question of the reflex mirror.  If the sensor is taller than 24mm then the mirror will need to be proportionally larger.  The lens mount is designed to put the lens as close as possible to the sensor whilst leaving enough clearance for the mirror, so there's little or no room for a larger mirror.
Of course with Canon's recent advances in live-view AF you could argue that reflex cameras are on the road to extinction.
Johanfoto
In reply to Mike Stratil, Jul 9, 2013
That may come, but in the shape of a full frame DSLR, not a larger than full frame DSLR.
Well, I think that the answer is very simple. IF Canon would introduce a camera system with a larger than full frame sensor, it must have new lenses as well. You simply cannot use your existing lenses on such a system. I think it is extremely unlikely that Canon will do so, however. There were even pictures (fake, obviously) of that Samsung camera I referred to two years ago. It never materialized nevertheless. Those Canon rumors are the same: Just rumors, probably written by people with more wishful thinking than technical knowhow.
