UV filter
Started Jul 6, 2013 | Discussions
Joanel Contributing Member • Posts: 889
UV filter
New  sony 70-300 lens.  need a good UV filter 62mm .  any specific recommendations for one you use and feel it doesn't degrade the image.  ( know I can go without one - but don't want to).
thanks
 Joanel's gear list:Joanel's gear list
Olympus E-M1 Sony a77 II Olympus M.Zuiko ED 75-300mm 1:4.8-6.7 II Tamron SP 150-600mm F/5-6.3 Di VC USD Canon PowerShot SX50 HS +6 more
steelhead3 Veteran Member • Posts: 6,238
Re: UV filter
UV is for film, get any multicoated clear filter.
 steelhead3's gear list:steelhead3's gear list
Sony a77 II
_Fotogrfr_ Contributing Member • Posts: 755
Re: UV filter
thanks
I put a Hoya Super HMC UV filter on my 70-400G1 soon after buying the lens several years ago.  After doing some testing and determining that the filter did not affect the IQ to any noticeable degree, I have kept it on ever since.
JPEG Shooter
galleries at: http://www.pbase.com/fotogrfr
Brian_Smith
Brian_Smith Senior Member • Posts: 2,530
Re: UV filter
If you're going to put any filter in from of that lens - make it a Zeiss.
Brian Smith
Sony Artisan of Imagery
Miami Photographer | Portrait Photography | Commercial Photography | Photography Blog | Books
AarSee
AarSee Veteran Member • Posts: 4,654
Re: Clear filter
I have been happy with this one on my SAL70-300G.
Link: http://www.amazon.com/Hoya-62mm-PRO1-Glass-Protector/dp/B0009K50TW/ref=sr_1_1?ie=UTF8&qid=1373157475&sr=8-1&keywords=hoya+pro1+clear+62mm
Hoya 62mm Pro1 Clear
Rick
 AarSee's gear list:AarSee's gear list
Sony SLT-A77 Sony a6000 Sony a77 II Sony Cyber-shot DSC-RX100 III Sony Alpha NEX-3N +10 more
John Tait
John Tait Regular Member • Posts: 343
Re: UV filter
I've been very happy with the B+W XS-Pro Clear MRC-Nano filters. They're expensive, but I don't see any IQ loss under normal circumstances and they add just a tiny bit of flair under very difficult lighting. If you can, test for flair problems with whatever filters you are considering.
If anyone points you to the lenstip UV filter comparison keep in mind that digital cameras don't benefit from UV filtering.
edit:  I use these filters on the 70-300G, 70-400G, zeiss 85mm, and zeiss 135mm.
 John Tait's gear list:John Tait's gear list
Sony SLT-A77 Sony SLT-A99 Sony 70-400mm F4-5.6 G SSM Sony 85mm F1.4 ZA Carl Zeiss Planar T* Sony 135mm F1.8 ZA Carl Zeiss Sonnar T* +5 more
DistantView Forum Member • Posts: 53
Re: UV filter
I don't know if this will help but until now I've always used filters to protect my lenses but recently bought a Minolta 75 -300 Big Beer Can with filter online only to find it really poor over 200mm - to cut to the chase it seems that the filter (a recognised make) & the lens were incompatible & once I took the filter off, the lens was as sharp as it should have been.
I suppose the thing to draw from this is "try before you buy" - for the record I have found Marumi filters worked well for me.
Good luck
RT
