Slideshow help needed
Started Jul 5, 2013 | Discussions
peter
peter Regular Member • Posts: 493
Hi,
I am trying to set up a slideshow which will be shown on a TV using a DVD player. Results so far are not as perfect as I would like.
Switching formats on the TV does not seem to help with the distortion ie. squashed images.
Most of the frames are multi images. I have used a paper size of 1200x800 on which to place the images.
Given that most TVs are now 16:9 format would that be a sensible paper format to use ie. 1600x900?
Any help greatly appreciated.
Peter
carl english
carl english Veteran Member • Posts: 8,002
Re: Slideshow help needed
Morning Peter, try Fastone image viewer "free" one of the best browser out there, I'm sure it enables you to create slideshow to play on DVD player, it should automatically resize images for you.
Carl
 carl english's gear list:carl english's gear list
Panasonic Lumix DMC-FZ150 Panasonic Lumix DMC-FZ200 Panasonic Lumix DMC-FZ1000 Nikon D70
peter
peter OP Regular Member • Posts: 493
Hi,
Thanks for the suggested program.
However this is not the main problem. I have tried several programs/methods of getting the images onto the screen but what happens is that the images are always distorted.
I cannot believe that all my ancestors were short and fat!!!
I have tried altering the TV aspect but it makes little difference to the final result.
Peter
carl english
Peter, I'm not to good at explaining methods on PC but I think you problem is image size, when using programs like Fastone or the best of all Proshow gold/producer you find all you need to know in help files. I was hoping that other members would pop in with advice.
Anyway if you are ever in King's Lynn I could show you.
Carl
carl english
carl english
peter
Hi Carl,
I have read the links that you sent and think they have solved the problem. Shifting the image dimensions to the 4:3 ratio has definitely improved the distortion problem.
Many thanks for your input.
Peter
rbl
rbl Forum Member • Posts: 95
When it comes to creating slideshows, I find PTE is pretty hard to beat. I've been using it for years, and with a little experience, you can create some striking slideshows..
http://www.wnsoft.com
If you want to see samples, have a look here:
http://www.beechbrook.com/pte
Dick
Max the Brave
Max the Brave Junior Member • Posts: 49
Hi guys, i'm new here, but i'll try to be efficient.
As for me and my family - we use this program for making slideshows. It makes great transition, put's music and burn's DVD's, and it's very easy.
Also, you may try other free software.
