Recommendations for an ND grad system
Started Jul 5, 2013 | Discussions
andywhoa Regular Member • Posts: 391
Hi!
I'm taking a trip next month to Colorado, and I'd like to use an ND grad system to take some landscape pictures with.
I haven't used ND grads in a long while, so I'm in the market to purchase a kit.
I'm looking for slides as opposed to a screw on filter.  The camera I'm taking is a Fuji X100.  The thread size is 49mm.
Does anyone have any recommendations?
Thank you for your help.
 andywhoa's gear list:andywhoa's gear list
Fujifilm X-T1
Fujifilm FinePix X100
Kuppenbender
Kuppenbender Senior Member • Posts: 1,990
Me too!
Thankfully three of the better know square filter brands have recently brought out systems for smaller lenses.
Lee Seven5 - expensive but highly regarded.
Cokin Snap - cheap and cheerful rebranded A series
and sitting somewhere in the middle
Hitech 67mm series - much less expensive than the Lee Seven5, but hopefully better than the Cokins.
I'm inclined to go for the Hitech series as Cokin (and some of the cheap 'no name' brands) appear to suffer from colour casts. I'd be interested in hearing any first-hand opinions of these systems.
 Kuppenbender's gear list:Kuppenbender's gear list
Panasonic Lumix DMC-GX7 Panasonic Lumix G Vario 100-300mm F4-5.6 OIS Olympus M.Zuiko Digital 45mm F1.8 +3 more
andywhoa OP Regular Member • Posts: 391
Re: Me too!
Thank you for your reply!
I'm really interested in the seven5 system.  I'll check it out!
Fujifilm X-T1
Sailor Blue
Sailor Blue Veteran Member • Posts: 9,284
Re: Recommendations for an ND grad system
I learned photography with film and to save money you had to do your best to get it right in the camera.  Using ND Gradient filters with film made great sense.
Today I wouldn't bother with a ND Gradient filter - I would do HDR.  Even if you only take one shot for the foreground and one for the sky you can put the two images on layers and add a gradient layer mask to one image to get the same results as you would have gotten with a ND Gradient filter.
Add a third shot by using your camera's Exposure Bracketing and you now have a much wider dynamic range available than you can ever get with filters.
Remember, a HDR image does not have to have that fake HDR look - it can look just like a normal image with lots of details in the highlights and shadows.
Instead of investing in an expensive ND Gradient filter put your money into a good tripod and ball head to make doing HDR easy.
Living and loving it in Bangkok, Thailand. Canon 7D - See the gear list for the rest.
 Sailor Blue's gear list:Sailor Blue's gear list
Fujifilm FinePix Real 3D W3 Canon EOS 7D Tamron SP AF 90mm F/2.8 Di Macro +10 more
Clueless Wanderer
Clueless Wanderer Senior Member • Posts: 1,142
Ive had Hitech ones for years I highly rate them. Then sailor blue points out the alternative, which I do from a single raw file. I pp the raw file, then make a virtual copy in Lightroom and under or over expose the copy by one stop, depending on what is needed. I then combine them in Photoshop. The most I have ever done is four different exposures of the same file.
Grads save you a hell of a lot of time pp, so I carry them with me and decide at the scene which option I will use. I use a cokin z pro holder with Hitech soft edge ND's. Its not been unknown for me to slide a darker filter in from the top for the sky and slide a not so darker one from below to darken the foreground. Again this can be done in post, But sliding in a grad is a hell of a lot faster..
 Clueless Wanderer's gear list:Clueless Wanderer's gear list
Nikon D200 Nikon D700 Nikon AF-S Nikkor 300mm f/4D ED-IF Nikon AF-S Nikkor 24-70mm f/2.8G ED Nikon AF-S Nikkor 70-200mm f/2.8G ED VR II +21 more
Footski
Footski MOD Senior Member • Posts: 1,833
Re: Me too!
I have very recently bought he Cokin Snap system and out of he box he whole set up looks very good quality. I have grads and full ND filters. I will nope fully be putting ether all to the test later this week.
 Footski's gear list:Footski's gear list
Leica V-Lux 4 Nikon D7000 Fujifilm MX-700 Fujifilm FinePix F601 Zoom Samsung NV10 +15 more
FlowBerlin
FlowBerlin Forum Member • Posts: 65
+1 on this! Anything you need to fiddle around with or carry with you in addition to the camera is a burden.
wazu
wazu Senior Member • Posts: 1,371
andywhoa wrote:
Hi!
I have 49mm thread on my RX-1 and decided since I have several 52mm lenses to get a stepup converter to 52mm. Then I purchased the Heliopan variable ND 0,3-1,8 which has 12 markings for bracketing purposes.
There is a crack in everything That's how the light gets in. - Leonard Cohen
