Remote trigger or intervalometer for RX100?
Started Jul 5, 2013 | Discussions
Robert Anderson Senior Member • Posts: 2,261
Any way to remotely trigger the RX100 or do intervalometer shooting?
Sony RX100
cosmonaut
cosmonaut Senior Member • Posts: 2,180
Re: Remote trigger or intervalometer for RX100?
No without a remote port on the camera it can't be done. I have the same problem with the RX-1. The small size comes with price.
www.gregmccary.com
DavidBoulder Junior Member • Posts: 29
I would live to see Sony add this with a firmware update, but I don't see that happening.
Robert Anderson OP Senior Member • Posts: 2,261
The Canon point and shoot cameras can  be triggered through the USB port if you add CHDK firmware. Also this firmware allows scripts which add intervalometer functions.
areichow Senior Member • Posts: 1,581
The RX100 II supports sonny's Sony's new wired remote, but not the RX100. If you want that for an RX100, you'd have to use something based on a servo.
 areichow's gear list:areichow's gear list
Canon PowerShot SD1000 Sony RX100 NEX5R Sony Alpha 7
Tommygun45 Senior Member • Posts: 1,324
The RXII supports wifi and apps though right? Therefore through play memories you can control the shutter wirelessly with your smart phone no?
 Tommygun45's gear list:Tommygun45's gear list
Sony Cyber-shot DSC-RX100 III Nikon D750 Nikon AF-S Nikkor 24-70mm f/2.8G ED Nikon AF-S Nikkor 50mm f/1.8G +1 more
Yes, but that doesn't mean you have an intervalometer. Though, it seems people have figured out enough of the NEX wifi API that an intervalometer controlled from an Android device would be doable.
lmeredith New Member • Posts: 6
I'm interested in this also for the RX100 II. I'm thinking that the Multi Terminal connector or maybe even the Multi Interface Shoe would facilitate this. It would be great if one of these or something similar would work.
http://www.amazon.com/NEEWER-RM-S1AM-Remote-Shutter-Release/dp/B003LYKLCO/ref=sr_1_1?ie=UTF8&qid=1349457834&sr=8-1&keywords=intervalometer+sony
http://www.amazon.com/Giga-Pro-Timer-remote-Sony/dp/B00345ZNWS/ref=sr_1_7?s=photo&ie=UTF8&qid=1373121949&sr=1-7
yuanzhoulv New Member • Posts: 6
There isn't a "good" way, but for a quick hack you can put it in continuous shooting mode and strap a rubber band and small plastic object to keep the shutter pressed. You can control the speed by saving RAW and using a slower card.
Not a very elegant method but hey, it's a solution, better than nothing
sybersitizen Veteran Member • Posts: 5,707
Snapsh0t
Snapsh0t Contributing Member • Posts: 875
You shouldn't expect people who wake up long dead threads to care about small details like that.......
 Snapsh0t's gear list:Snapsh0t's gear list
Sony Cyber-shot DSC-RX10 Fujifilm X30
g61 New Member • Posts: 5
Works great with my RX100ii.
GorgiGR New Member • Posts: 3
In the mean time Sony has developed a Playmemories-App called "Timelapse" which does exactly that. One can select from presets (who does that anyway?) but there is also a custom mode where one can shoot with his own selection of ISO/Aperture/Shutterspeed etc. The interval can be set from 1 to 60 seconds in one second steps, and the number of pictures to be taken can also be set
Here is the link , I hope this helps.
