Advice on the lighting set up
Started Jul 3, 2013 | Discussions
Omaarsl New Member • Posts: 3
No text.
DotCom Editor Veteran Member • Posts: 6,785
Re: Advice on the lighting set up
Omaarsl wrote:
[nothing]
Kind of hard to make a recommendation from the meager information you provided.
kgbruce01 Senior Member • Posts: 1,245
5
DotCom Editor wrote:
Omaarsl wrote:
[nothing]
Not around here it isn't.
First, get an AB800,stand, battery pack,soft box and umbrella or two. Then take some bad pictures. Then come back and ask for help. You'll be told that you can do great photos with only one light and good technique and skills.
Dont believe it.
You should then order two or three more lights, with more power, and more soft boxes and a beauty dish. Better get another battery. Then take much brighter bad pictures. Come back and ask why, get told 6-7 different things to try. Try them with mixed results and feel bad for spending so much money.
Go back to one light, actually practice for a few weekends, and start making good pictures with an actual understanding of what is going on. Repeat.
Good luck.
DecibelPhoto Contributing Member • Posts: 791
You're going to need some Briese HMI's.  It's the only way to do it.  If you buy cheap you will end up buying twice.
hotdog321
hotdog321 Forum Pro • Posts: 15,195
Buy a copy of Light Science and Magic.
 hotdog321's gear list:hotdog321's gear list
Canon EOS 5D Mark III Canon EF 70-200mm f/2.8L IS II USM Canon EF 24-70mm f/2.8L II USM Canon EF 16-35mm f/4L IS USM Canon EF 11-24mm F4L +1 more
