Which is the better lens the sony 50-300 or the Tamron sp 75-300
Started Jul 3, 2013 | Discussions
Edward Greenberg Regular Member • Posts: 420
Want to purchase a tele zoom for my A&&. I know the Sony is a little cheaper and the firmware is set to compensate for its deficiencies, so while I figured optically the Tamron might be better, real world pictures with the Sony might be better. Am I correct?
 Edward Greenberg's gear list:Edward Greenberg's gear list
Sony Alpha 7R
dlkeller Veteran Member • Posts: 6,922
Re: Which is the better lens the sony 50-300 or the Tamron sp 75-300
Suggest you check dyxum.com for ratings and information on lenses.  I just did this on these lenses, I don't see a Sony 50-300 listed and the only Tamron 75-300 is not rated very well.  Maybe I need to dig deeper as this was just a quick check.
Dave
craig66 Contributing Member • Posts: 926
Without seeing formal tests from the same source of both lenses, it's hard to say which is optically better. Consensus seem to be that they are roughly equal optically. Which leaves other criteria any of which may or may not be important to a particular person
Sony 55-300 Advantages:
1. Much lighter than the Tamron
2. In camera corrections
3. A little more flexible - 55mm vs 70mm at the wide end
4. A little cheaper
Tamron SP 70-300 Advantages:
1. Front element does not rotate
2. Full frame lens
3. AF is claimed to be faster, but in the absence of formal tests it's a bit hard to say for certain.
4. AF possibly quieter.
I have a 55-300 for which I paid $250 AUD new and consider it very good for the price. The lower price and lower weight were that main factors that swayed me to the Sony over the Tamron.
 craig66's gear list:craig66's gear list
Sony a77 II Sony DT 55-300mm F4.5-5.6 SAM Tamron SP AF 200-500mm F/5-6.3 Di LD (IF) Sigma 500mm F4.5 EX DG HSM Tamron SP AF 60mm F/2 Di II LD IF Macro +9 more
If the OP meant the two lenses you wrote about (and I suspect he did)  I agree totally with your analysis.
Dave
Photoviewer Regular Member • Posts: 464
4. A little cheaper
2. Full frame lens
This is exactly why I chose the Sony as well. The Tamron indeed look far more serious in term of build and weight. Its weight turn me off. But if I am ok with the weight, I will chose a used Sony 70-300 G any time which is Sony own lense, come with focus hold, focus limiter and of cause, it is a G
Cheers.
OpticsEngineer Senior Member • Posts: 4,553
"Want to purchase a tele zoom for my A&&. I know the Sony is a little cheaper and the firmware is set to compensate for its deficiencies, so while I figured optically the Tamron might be better, real world pictures with the Sony might be better. Am I correct?"
That is the way I figured it too and I got the Sony 55-300 SAM.  It is a very nice lens.
 OpticsEngineer's gear list:OpticsEngineer's gear list
Fujifilm XF1 Olympus XZ-2 iHS Canon PowerShot G7 X Olympus Tough TG-4 Sony Alpha NEX-7 +21 more
DistantView Forum Member • Posts: 53
Hi Edward
I asked the same question yesterday & it might help you to look at the replies on that thread - about 10 posts below this one but I've no idea how to add a link - sorry !
Good luck
RT
grgi Forum Member • Posts: 53
No comparison, but some real world experiences with the Tamron
Hi Edward,
I don't know how good the Sony is, I just can give you a few experiences with the Tamron
- First, the Sony telezoom lenses are said to be produced by Tamron, I heard that the Sony 70-300G has the same optical calculation as the Tamron 70-300 SP. I just heard that, I don't have a proof about it.
- My Tamron is sharp and bright with a good, smooth bokeh up to 250mm.
- Stopping down 1 stop makes it even better. Perfectly crisp pictures. 135mm @ f8 equals perfect portraits. And yes, I think f8 makes the background blurry enough.
- At 300mm, there's a visible decline in sharpness. Some unsharp masking in PP, and it is fine, nevertheless I try to avoid the 300mm.
- Yeah it's bulky. I used it with my A37 which was too tiny to get good ergnonomics. I sold the A37 and got the A58. So you see, I like the Tamron .
best regards
grgi
Gary Waugh Senior Member • Posts: 1,599
The Tamron has a six year warranty. You won't get that with the Sony lens.
Gary in PA
Edward Greenberg OP Regular Member • Posts: 420
It looks like I will go with the Sony. My a77 is heavy enough without adding the lens. As optically they seem similar, the longer reachand lighter weight sway me to the Sony. As far as the warranty., I have a bunch of lenses two years to 20 years and all work fine. I am not a pro so I don't need pro caliber stuff. Besides my 16-50 is on my camera 90 percent of thetime. Thanks you all for your input.
Sony Alpha 7R
