Bulbs for light tent
Started Jul 2, 2013 | Discussions
Nathanio Regular Member • Posts: 234
Hi,
I am sorting myself out a light tent to photograph some Jewellery for insurance purposes for some family members.
I'm not sure which bulbs will be best to use with the light tent for this sort of thing. Any tips please?
 Nathanio's gear list:Nathanio's gear list
Sony a77 II Sony DT 50mm F1.8 SAM Tamron SP 70-300mm F/4-5.6 Di USD Sony DT 16-50mm F2.8 SSM Sony DT 18-135mm F3.5-5.6 SAM +1 more
Sailor Blue
Sailor Blue Veteran Member • Posts: 9,151
Re: Bulbs for light tent
Incandescent if colors are of critical importance.
CFLs if color isn't of critical importance but heat is a problem.
Living and loving it in Bangkok, Thailand. Canon 7D - See the gear list for the rest.
 Sailor Blue's gear list:Sailor Blue's gear list
Fujifilm FinePix Real 3D W3 Canon EOS 7D Tamron SP AF 90mm F/2.8 Di Macro +10 more
Nathanio OP Regular Member • Posts: 234
I'm just looking a clean light with good coverage. Would a mix of daylight and normal cfl work ok!
Sailor Blue
What daylight?
The color temperature of shade is not the same as North light which is not the same as direct sunlight which is not the same as cloudy daylight.
Mixing color temperatures is not a good idea.
If you are doing small products where color is important then you want to use either flash or incandescent so that you will be working with full spectrum light sources.
If color isn't important then you can work with CFL bulbs. I would recommend daylight but not cool daylight ones.
For lighting a tent with incandescent or CFLs you can use those cheap clamp on metal bowl reflector shop lights with the bulbs. Look for ones like these.
Here is a good tutorial for shooting jewelery in a light tent.
Jewelry photography tips - how to take pictures of jewelry
