Sony 55-300 or Tamron 70-300 USD
Started Jul 2, 2013 | Discussions
DistantView
DistantView Forum Member • Posts: 53
I'm trying to decide between these two lenses both of which seem to get pretty good reviews - anyone got experience of both or views ?
look forward to hearing from you !
RT
Photoviewer
Photoviewer Regular Member • Posts: 464
Re: Sony 55-300 or Tamron 70-300 USD
RT
Jeff did a very practical and useful document before. You may take a look. Its helped me a lot.
http://www.dpreview.com/forums/thread/3275452
DistantView
DistantView OP Forum Member • Posts: 53
Hi Photoviewer - many thanks for that link, a really useful thread & just what I needed. Just out of interest which (if any) did you get& why ?
No need for anyone one else to reply - unless you want to !
Best wishes
RT
Photoviewer
Best wishes
RT
Hi RT, I bought the Sony.
Cheers
Stflbn
Stflbn Senior Member • Posts: 2,525
There's nothing about the Tamron 70-300 on that link.  Other than saying he must have had a bad copy.
The Tamron is a fantastic lens thats been praised in multiple different reviews.
 Stflbn's gear list:Stflbn's gear list
Sony a6000 Sony Alpha 7S Sony Alpha 7 II Sony FE 55mm F1.8 Sony FE 24-70mm F4 OSS +6 more
fishbreath
fishbreath Regular Member • Posts: 151
tamron here
retirement isn't all its cracked-up to be,,,,,,,,,,,,its better
 fishbreath's gear list:fishbreath's gear list
Sony SLT-A57 Sony a77 II Sony DT 18-55mm F3.5-5.6 SAM Tamron SP 70-300mm F/4-5.6 Di USD Tamron SP 150-600mm F/5-6.3 Di VC USD
geoffmalter
geoffmalter Senior Member • Posts: 2,489
Best wishes
RT
I originally purchased a Minolta 100-300 APO D, nice IQ, but found the 100mm too restrictive. I then opted for the 55-300 and haven't looked back. I didn't consider the Tamron.
Below is an example at 300mm, taken mid-morning in harsh Phoenix AZ sun, Jpeg, SOOC:
 geoffmalter's gear list:geoffmalter's gear list
Olympus Tough TG-1 iHS Panasonic Lumix DMC-LX7 Sony SLT-A57 Canon EOS M Sony DT 55-300mm F4.5-5.6 SAM +8 more
NAwlins Contrarian
NAwlins Contrarian Regular Member • Posts: 463
We've discussed this basic question several times recently. Perhaps the most detailed thread was:
http://www.dpreview.com/forums/post/51509303
My personal opinions are expressed at some length in the message:
http://www.dpreview.com/forums/post/51513332
And I posted some examples lower in that thread too. Long and the short of it: in my opinion, based on my research and personal experience, the Tamron SP 70-300mm Di USD has better focusing speed, better built quality, full-frame coverage, and overall about equal optical quality, compared to the Sony DT 55-300mm. The Sony 55-300mm may be overall slightly sharper at 300mm (although I'm not convinced of that); and obviously it goes somewhat wider (going from a 100-300 to a 70-300 gets you a 43% wider wide end; going from 70 to 55 gets you wide end an additional 27% wider).
For my own use, where focus speed is very important, the 70-150mm range does the majority of the work, and the 250-300mm range is for occasional extra reach, the Tamron was (and is) the clear winner. YMMV, and if I were most interested in sharpness at 300mm, I might get the Sony DT 55-300mm--or maybe the Sigma 70-300mm DG OS. (And if money is no object, the Sony 70-300 G is probably best, but on the whole only slightly ahead of the Tamron for a lot more money.)
 NAwlins Contrarian's gear list:NAwlins Contrarian's gear list
Canon PowerShot SD4000 IS Canon PowerShot SX230 HS Nikon Coolpix S30 Sony Alpha DSLR-A580 Tamron SP AF 90mm F/2.8 Di Macro +6 more
DistantView
Thanks again to all contributors, much appreciated
RT
