Ganon G15 on iMac
Started Jul 1, 2013 | Discussions
Roberto de La Tour
Regular MemberPosts: 244
Ganon G15 on iMac
Jul 1, 2013
I just purchased a Canon Powershot G15. Very happy about the size, little by little I will go through all it's features. BUT:
To download the pictures, I can only take the card off and put it in the SD card slot (thing that people with some Mac models cannot do) or use iPhoto.
For some reasons I do not understand, if I connect the G15 with an USB cable, the card is not visible. When I connect it, the bundled software "camera Window" starts automatically, but then says "no camera was found". The other bundled software, "Image browser DX" does not see it.
With my previous/other cameras, Sony V3, Olympus eVolt, Panasonic G1, connection with USB cable always made the card appear on the desktop. With the G15, no.
Why is this? I do not like to use iPhoto, I am not in control of where I store the downloaded pictures. Must I always take the card off? Why?
I installed all the bundled software with the "easy install" option, I did not find any driver on Canon website
I have the latest imac with OSX 10.8.4
Roberto
Canon PowerShot G15
wazu
Senior MemberPosts: 1,361Gear list
Re: Ganon G15 on iMac
In reply to Roberto de La Tour, Jul 1, 2013
Roberto
Are you plugging directly into the side of computermor through hub?
Is the camera powered on?
Did you origionally format the card in the same camera you are connecting?
Have you installed and upgraded all the Canon software (ImageBrowser,DPP,Utilities)?
Try another card and cable.
There is a crack in everything That's how the light gets in. - Leonard Cohen
noirdesir
Forum ProPosts: 12,197
Cameras connected via USB with a computer normally use one of two USB 'modes':
  1. Mass Storage Device (class), short MSC, in which the camera acts essentially like a card reader and the memory card mounts like it mounts via any card reader.
  2. Picture Transfer Protocol (PTP) or the related Media Transfer Protocol (MTP), a mode where no filesystem is exposed to the user and only applications that implement these protocols can access the image and video data. By not showing the file system, it is simpler to use and less can go wrong (no need to eject anything, no diving into subfolders on the card to get to image files, no possibility to mess up anything on memory cards).
Almost all cameras support PTP/MTP and a part of all cameras, in particular the higher end ones, additionally support the Mass Storage mode. In cameras that support both, the mode can be set via the camera's menu system. I just checked and it seems that the G15 only supports the second mode (MTP/PTP) whereas for example your Panasonic G1 supported both modes.
You thus have to use either the card slot (or an external card reader) or one of the applications that talk PTP/MTP, which include on top of iPhoto all third-party applications of its type (eg, LR) or the native application Image Capture which is a rather simple application that allows you import image via drag and drop to any Finder window.
I can't speak for Canon's software but I generally don't put too much faith into them (ie, I'd blame the software in this case).
Roberto de La Tour
In reply to noirdesir, Jul 2, 2013
Hey thanks! I did not know this!
Yeah Bundled sofware is moronic. Still want to try the raw editing software, though
Concerning Image capture, I do not know it. I will try. I like to be able to put the picturers in the folders I want.
Thanks again
Roberto
Roberto de La Tour
In reply to wazu, Jul 2, 2013
wazu wrote:
Roberto
No through USB slot direct cable to the camera
Yes indee! And "Camera Window" starts automatically when I turn it on, but then does not recognize it
Oh yes indeed!
Definitely, with the provided CDROM
I will
Cheers
Roberto
