Damn Nikon, I need that MACRO lens NOW!
Started Jul 1, 2013 | Discussions
IVN
IVN
Senior MemberPosts: 1,612Gear list
Jul 1, 2013
The 10-30 is nice, but I need to be able to get even closer! It's silly how fast and accurate the AF is. All these samples were taken with AF. Ever hear of how you are not supposed to use AF when shooting macro? I guess this doesn't apply to N1 cameras and lenses. So how about that 35-40mm macro lens, NIKON!?
(click on the images to enlarge to full HD)
I wonder how much detail Nikon V2's sensor could capture.
Does anyone have experience with achromatic lenses? I'm thinking about investing in a Marumi DHG +5 while waiting for Nikon to release a proper macro lens.
P.S. when shooting at ISO100 with the V1 I almost never apply NR or sharpening. In case you are wondering...
Nikon 1 V1 Nikon 1 V2
Aspenz
Contributing MemberPosts: 764Gear list
Re: Damn Nikon, I need that MACRO lens NOW!
In reply to IVN, Jul 1, 2013
The clarity of the fly, the cool background, it's almost like it's on display! Great shot.
 Aspenz's gear list:Aspenz's gear list
Nikon 1 V3 Nikon AF-S Nikkor 85mm f/1.4G Nikon 1 Nikkor VR 10-30mm f/3.5-5.6 Nikon 1 Nikkor VR 30-110mm f/3.8-5.6 Nikon 1 Nikkor 18.5mm f/1.8 +3 more
D300SandV1shooter
Senior MemberPosts: 1,778Gear list
There is (or will be) this:-
"N1-CL1 Close-up Lens
This slim 40.5mm accessory fits onto the two Nikon kit lenses and provides macro capabilities of up to 3.8x on the 30-110mm zoom, and 0.76x on the 10-30mm".
http://www.sansmirror.com/accessories/nikon-1-accessories/n1-cl1-close-up-lens.html
 D300SandV1shooter's gear list:D300SandV1shooter's gear list
Nikon D700 Nikon D300S Nikon 1 V1 Nikon 1 V2 Nikon 1 V3 +12 more
marike6
Senior MemberPosts: 5,071Gear list
I agree that the Nikon 1 system needs a dedicated macro lens, but it's likely that one will be released at some point, hopefully soon.
Until that time, if you have the FT-1 adapter, you could mount something like the Nikon 40 f/2.8 DX lens, which is an extremely sharp 1:1 macro lens. With the 2.7 times crop factor on the V1, the 40 2.8 would act as a 108 f/2.8 macro, pretty close to the classic 105mm focal length of the Nikon macros (the middle one of the 60mm, 105mm, 200mm Nikkors) one of the better focal lengths in a macro lens for shooting insects.
Other than that, you could look into a Raynox DCR-250, which are quite good.
http://www.bhphotovideo.com/c/product/275182-REG/Raynox_DCR_250_DCR_250_2_5x_Super_Macro.html
Search for "Raynox DCR-250" on Flickr or Google images to see lots of example images from this setup.
Best of luck, Markus
 marike6's gear list:marike6's gear list
Nikon Coolpix P330 Panasonic Lumix DMC-GH2 Nikon D800 Fujifilm X-E1 Panasonic Lumix G 20mm F1.7 ASPH +7 more
A. Westreich
Senior MemberPosts: 1,195Gear list
Has anyone tried the FT-1 with a 40mm 2.8 dx close-up?
 A. Westreich's gear list:A. Westreich's gear list
Nikon D7100 Nikon AF Nikkor 35mm f/2D Nikon AF-S DX Micro Nikkor 40mm F2.8 Nikon AF-S Nikkor 80-400mm f/4.5-5.6G ED VR
IVN
IVN OP
In reply to D300SandV1shooter, Jul 1, 2013
N1-CL1
"This slim 40.5mm accessory fits onto the two Nikon kit lenses and provides macro capabilities of up to 3.8x on the 30-110mm zoom, and 0.76x on the 10-30mm".
What does that mean? More than 1:1 magnification factor? That would be quite a boost compared to the default macro capability of the 10-30.
Paul Pasco
Veteran MemberPosts: 4,854Gear list
I use Nikon 3T and 4T close up lenses on the 30-110 with very good results, including AF. However lately I have enjoyed using my Cosina 100 macro manually focused. I prefer the long focal lengths for macro because of the greater working distance they afford.
Regards, Paul
Lili's Dad
 Paul Pasco's gear list:Paul Pasco's gear list
Panasonic Lumix DMC-FZ28 Nikon D50 Nikon D300 Nikon 1 V1 Nikon 1 J1 +17 more
IVN
IVN OP
In reply to Aspenz, Jul 1, 2013
Thanks!
D300SandV1shooter
N1-CL1
"When the N1-CL1 is attached to the 1 NIKKOR VR 10-30mm f/3.5-5.6, the minimum focus distance from the tip of the N1-CL1 is shortened to approx. 0.09 m and the maximum reproduction ratio is increased up to approx. 0.76x (when converted to 35mm format), enabling the easy capture of shots resembling those taken with a micro lens".
More useful link here.
IVN
IVN OP
N1-CL1
I still don't get it. If it's 0.76x, I'm guessing it's still less than what real macro lenses offer (1:1), more like 1:1.32. Using the Marumi +5 on the 10-30 would result in an 1.4:1 reproduction ratio at 30mm. That would make N1-CL1 inferior.
Seedeich
Senior MemberPosts: 1,348
The Marumi is a very good achromat. I have the +3, branded as Soligor.
D300SandV1shooter
In reply to Seedeich, Jul 1, 2013
Unlike the OP pics, you're using the 30-110 - which would also be preferable to use with Nikon's N1-CL1 alternative. The Nikon link I gave before shows pics of its use with both kit zooms, which clarifies the magnification offered in each case.
IVN
IVN OP
I don't own that lens and am not thinking about buying it in the near future. My next lens will probably be the 6.7-13mm.
patabi
Regular MemberPosts: 289
I use a close-up lens Hama +2 or +4 with de 10-30. It's probably most efficient on the 30-110 but it's my only lens.
http://www.pbase.com/patabi/closeup
Amitiés
Patrick
bgD300
Veteran MemberPosts: 4,552Gear list
I have good luck with the Leitz ELPRO achromats
Here are a few recent ones.  A few more posts at my blog if you search for ELPRO
EXIF is embedded in photos
My photo blog: http://birdsnbugs.wordpress.com
My camera club porfolio: http://www.pacameraclub.com/Member.Galleries/Brian_20Grant/index.html
RF Stock Portfolio - http://www.dreamstime.com/resp129611
WSSA #51 as bg5700
 bgD300's gear list:bgD300's gear list
Nikon Coolpix P7100 Nikon D90 Nikon D300 Nikon 1 V1 Nikon AF-S Nikkor 70-200mm f/2.8G ED VR +16 more
Seedeich
I wonder how the image quality of the Nikon close-up lens compares to the Marumi achromat.
The Nikon lens is only one element, while the Marumi is a lens system, which corrects for colour fringing.
https://en.wikipedia.org/wiki/Achromatic_lens
D300SandV1shooter
Does it say that somewhere? Perhaps I was assuming it would be a 40.5mm version of the 62mm Nikon 5T which I have used on the 30-110 with step-ups - and which is definitely a diopter, and a good one.
OP might note people are using the 30-110 for working distance as well as magnification.
Seedeich
You mean one element?
Yup, it does. Go to the specification tab in the link you provided.
Lens construction - 1 element in 1 group
http://imaging.nikon.com/lineup/acil/lenses/n1_cl1_closeup/spec.htm
IVN
IVN OP
DAMN! Those fly photos are sick!
In reply to bgD300, Jul 1, 2013
WSSA #51 as bg5700
I'll have to get a 30-110 sooner or later!
Gaber
Veteran MemberPosts: 5,617Gear list
In reply to marike6, Jul 2, 2013
I  agree with Markus. Get the FT-1 and the 40mm macro. I use it with the 105 macro because I already have it. Here are a few with that combo.
I also can use the Canon 250D with the 30-110 (at 110 preferably) with a step up ring to 52mm, the size of the 250D. It's small and I can keep it in my V1 bag for whenever I need it.
 Gaber's gear list:Gaber's gear list
Nikon 1 V2 Nikon D7100 Nikon 1 J5 Nikon AF-S DX Nikkor 18-200mm f/3.5-5.6G IF-ED VR Nikon AF-S Nikkor 300mm f/4D ED-IF +15 more
