Unfortunately, but it's a failure.
Started Jul 1, 2013 | User reviews
Mr Slim New Member • Posts: 7
I've bought this cam from Japan in March to be prepared for the Summer 2013 beach season. I'm in the middle of the season now, but the camera is dead already.
My previous pocket camera was Panasonic DMC-ZS3. I was taking that camera with me everywhere for the last 3 years. It had issues, that made me thinking about buying something more reliable. Panasonic's rugged cameras were rejected due to their weak sides, so I have decided to be the owner of Pentax's WG-2 GPS camera.
At first -- the picture was poor, not even half-decent. It's poor. Even my friends have admitted that.
The next -- battery and sd card door design was poor too. Metal door part got rusty after the second use. Rusty sediment was too obvious on the white plastic parts around the door. The door itself looked too lousy. There were traces of humidity on the lens glass from the inside.
That's it. After 2 month and 16 days of owning this camera it has swallowed some water, being in my pocket while I was riding a bicycle under the heavy shower rain. That was the last picture taken with that camera -- my girlfriend, riding a bike under that rain.
It has never been deeper than 2 meters. It has been in the water for 2 hours a few times only. 99% of it's lifetime it was in my pocket as a point-and-shoot camera at work. In a dry environment.
I don't have any claims to the pentax regarding this, but not going to buy from pentax anymore.
PS: Battery life was poor too.
Pentax WG-2 GPS camera is not reliable at all. Avoid it!
The last picture taken
Pentax Optio WG-2 GPS
16 megapixels • 3 screen • 28 – 140 mm (5×)
Announced: Feb 7, 2012
Mr Slim's score
0.5
Average community score
4.1
bad for good for
Kids / pets
awful
Action / sports
awful
Landscapes / scenery
bad
Portraits
bad
Low light (without flash)
awful
Flash photography (social)
bad
Studio / still life
awful
= community average
Jefftan Senior Member • Posts: 1,423
Re: Unfortunately, but it's a failure.
Do you mean WG-3 GPS?
anthony mazzeri
anthony mazzeri Senior Member • Posts: 1,981
That's no good, is it? Defeats the whole point of these cameras.
I assume the rust is from salt water? What's the procedure with using any waterproof cameras, do you rinse under fresh water after being in the ocean?
Taffy MOD Veteran Member • Posts: 4,958
Read the specification of this camera here on this site, nowhere does it state that this camera should be taken UNDERWATER. It is evirionmentally sealed, not made for use under water. See the link below.
http://www.dpreview.com/news/2012/02/07/Pentax_Optio_WG-2_WG-2_GPS#specs
Have a good day.
Regards, Allan.
anthony mazzeri
The official Pentax announcement says it is:
  • Waterproof to depths of 40 feet.
Mr Slim OP New Member • Posts: 7
I'm pretty sure it was WG-2 GPS, not WG-3 GPS.
The rust is obviously from the wrong metal type Pentax used for a camera parts that are going to be exposed to a salt water. I have my Nautica cap for 2 years that has a stain resistant metal buckle.
Yes, I was de-salting it after use the same way I do it with all my gears: boat, trailer, outboard engine, life vests. I use a karcher carwash for that.
Thank you. I don't need this source of information anymore -- my Pentax is dead already. I'm sharing my experience with anyone who is planning to spend money on a Pentax products. My message is -- think twice before buying Pentax.
Correct. It is even imprinted on the LCD glass surface - "waterproof 40ft / 12m"
But it wasn't a good camera even without this rust and leaking issue. Picture quality was not good at all.
DNScott Junior Member • Posts: 44
The camera is still under warranty, send it back to Pentax for repair if it is defective.  Did you read the precautions in the owner's manual before using the camera. Salt water will rust 304 stainless steel.  All underwater photo equipment used in salt water needs to be rinsed off with fresh water after use, this also applies to scuba equipment too.
 DNScott's gear list:DNScott's gear list
Pentax WG-3 Pentax K-3
Abbazz
Abbazz Contributing Member • Posts: 749
A Kärcher carwash is a high pressure water cleaner, deliivering water pressure between 5,000 to 10,000 psi. The Pentax Optio WG2-GPS is designed to withstand a underwater dive up to 12m, corresponding to a water pressure of 17.4 psi...
I am afraid it's your high pressure de-salting that killed the Pentax!
Cheers!
Abbazz
The 6x9 Photography Online Resource: http://artbig.com/
http://artbig.com/broch1b.jpg
Hey Abbazz, my Karcher has a changing pressure sprayer. I was using a shower mode only.
I like your guess anyway )))
Send back to Japan? Are you kidding me?
As I said, I don't want to use it anymore. I could fix it locally, but the picture quality is too poor even for a water camera.
