Whirring noise P7100
Started Jun 30, 2013 | Discussions
Doctor Chris New Member • Posts: 4
Hi all,
Sorry to join this forum with a question but I’d be grateful to hear if any of you have had similar experiences to me with your P7100.
There is a constant whirring noise that appears to emanate from the lens area. I thought that it might be the VR function, but the noise is present whether or not VR is switched on. I’ve played around and have observed the following:
VR switched OFF when powering up: noise present but ceases when I press the Main Menu button AND the SET UP tab is the active tab AND any one of the set up menu items is highlighted. Noise comes back when I press the Main Menu button again, or half press the shutter button.
It gets spooky: if I switch the Quick Menu Dial to My Menu, and the Vibration Reduction option (which I have set there) is displayed at that time, and then I press the Quick Menu Button twice the noise ceases and will not return until the camera is powered down and back up again! Note that by doing this I am not turning VR off, it is merely highlighted.
If VR is already set to ON when the camera powers up the noise will only cease if I turn VR off, or hit the Main Menu button in exactly the same manner as explained above. Once again, the noise returns when half-pressing the shutter.
The other thing I have noticed is that there is the occasional ‘electrical’ whistling from the LCD screen, although this tends only to happen whilst carrying out the above diagnostics.
I have spoken to Nikon who said that the noise was ‘normal’, but I don’t think the guy quite got the grasp of the exact circumstances under which the noise is present.
Any comments would be gratefully appreciated.
Many thanks!
Chris
Nikon Coolpix P7100
RichardAB New Member • Posts: 11
Re: Whirring noise P7100
When I bought my P7100 in September 2011, it came with a 2-year guarantee.
If you bought the camera new, then you should return it.
Dwayne Oakes
Dwayne Oakes Senior Member • Posts: 1,295
A couple of questions.
1-I take it the camera is still under warranty ?
2-How are your images turning out ?
3-(save your photos) Did you try a camera reset ?
4-(save your photos) Did you try the new firmware update. you could just have a bug
in the camera's firmware ?
tomjar Regular Member • Posts: 490
Doctor Chris wrote:
Hi all,
Many thanks!
Chris
Hi Chris. I think you are observing the same noise that got me worried for a while about half a year ago (my camera is P7700) - check this thread.
I think there is nothing wrong with your P7100.
Kind regards, Tomaz
 tomjar's gear list:tomjar's gear list
Nikon Coolpix P7700 Nikon Coolpix AW120 Nikon D5000 Nikon AF-S DX Nikkor 18-105mm f/3.5-5.6G ED VR Nikon AF-S DX Nikkor 35mm f/1.8G +2 more
Tom52 Regular Member • Posts: 330
My P7100 has the same whirring noise. Never noticed it until now. I guess my 60 year old ears aren't what they used to be. My P7100 is about a year old and I've never had any issues with it.
 Tom52's gear list:Tom52's gear list
Fujifilm X100T Nikon D7000 Pentax K-5 II Pentax K-50 Fujifilm X-T1 +6 more
Doctor Chris OP New Member • Posts: 4
All seems to be fine with the camera in general, and I did a full reset.
There are no firmware updates so I guess all is normal!
Thank you for that, Tomaz. That's most helpful.
mallbuedel
mallbuedel Contributing Member • Posts: 921
Check wether the autofocus mode is set to AF-S or AF-F. If set to AF-F (full time AF), the camera focuses and refocusses at all times, even when the shutter release button is not pressed. The movement of the lenses generate a faint noise, also in my P7100. Once you press the shutter release button half down, the actual focus is locked and the noise is gone.
Thanks for that. Focus mode seems to make no difference; I'm inclined to think it's more to do with the VR system. Although I can't understand why the whirring is present when VR is turned off!
