Adding a New Time Machine Drive
Started Jun 30, 2013 | Discussions
InspectorHud Regular Member • Posts: 206
My Time Machine backup is getting near capacity.  Is it possible to add another drive that will be an extension to the current or do I have to start over with a bigger drive?
I'm currently using an iMac with latest OS and WD 2TB Firewire 800 externals.
TheDanS Forum Member • Posts: 57
Re: Adding a New Time Machine Drive
It's a 2TB drive. I would just let it get full until TM prompts you to delete some of the oldest backups. It should do it automatically.
 TheDanS's gear list:TheDanS's gear list
Fujifilm FinePix X100 Canon EOS 7D Olympus PEN E-P3 Sony a6000 Canon EF-S 15-85mm f/3.5-5.6 IS USM +5 more
InspectorHud OP Regular Member • Posts: 206
Perhaps you're right, since I do use the vault backup in Aperture, but is there a way to extend the drive to another?  That would be my preference.
DenWil
DenWil Senior Member • Posts: 2,485
Extend the drive to another? Unplug the 2T you have and plug in another. I use my backup to protect me from hard drive failure. Using using drive after drive  to track every thing that happens  continuously serves me no purpose.  I in fact deleted all the saved backups from 2012 the other evening.
I'm a one month old iMac with a 1TB drive. I have an external 1TB usb drive and its actually overkill for my backup flow. Are you fairly new to mac? I don't want that to sound offensive but i'm thinking you are overthinking your backup strategy.
(unknown member) Veteran Member • Posts: 5,593
I'm assuming your drive is filled up due to media files? Have you considered permanently backing up those files? I look at Time Machine as an operational backup system, not something for archival or long term storage. You are much better off eventually moving those files into a more permanent location and giving your Time Machine drive and your internal drive room to do their thing.
I suggest reading the Wikipedia article on how Time Machine works.
http://en.wikipedia.org/wiki/Time_Machine_(Mac_OS)
An Apple support quote from the article.
"Time Machine is a backup utility, not an archival utility, it is not intended as offline storage. Time Machine captures the most recent state of your data on your disk. As snapshots age, they are prioritized progressively lower compared to your more recent ones."
noirdesir Forum Pro • Posts: 12,488
Very simple, just copy it from one drive to another
You can simply copy/move the whole TM backup folder from the old drive to the new drive. There are just a few details to remember: (1) the new drive has to be formatted as HSF+ journaled with a GUID partition table (the default when formatting new drives), (2) the 'Ignore ownership' box on the new drive has to be unchecked. And you naturally should switch TM off while moving the backup from one drive to another and point TM to the drive after you're done. Here are the official instructions by Apple.
Good point Basalite and others.  I should probably change my backup strategy, but yes, being a professional photographer I have about 80% of the 2tb drive full right now not to mention my old CD/ DVD iView system.  I agree, I should probably copy the oldest for archiving and let TM work as a backup that serves as a safety net for more recent things.  Given that approach I could probably use a 1tb for TM.  Thanks for the suggestions. It is time to rethink the system.
