What Just Happened?
Started Jun 29, 2013 | Discussions
Gary Eickmeier Veteran Member • Posts: 3,479
What Just Happened?
Did your DPR site just get smaller, with a wrap-around ad frame?
Gary Eickmeier
rsn48 Veteran Member • Posts: 7,254
I suspect you have some form of maleware
Try Spy Bot (free download) and kaspersky free scan (it will only scan once then uninstall but it is a very good program).  Also Roguekiller.
Hindsight is better than foresight, except for lost opportunity costs.
Gary Eickmeier OP Veteran Member • Posts: 3,479
Re: I suspect you have some form of maleware
I don't think so. Same on two different computers. Here is what I am seeing:
Is that what you have?
Gary Eickmeier
Joseph T Lewis III Senior Member • Posts: 2,821
Mine Is Doing It Too....
I was in the "old" view of DPR.  When I saw the original post, I exited DPR and then brought it up again.
I'm seeing an Amazon ad across the top, with a  lot of gray space on either side of the DPR forum stuff. The ads on the right side and my login ID info is there just like it used to be.  Only difference is a fair amount of gray blank space on either side.
Tom
 Joseph T Lewis III's gear list:Joseph T Lewis III's gear list
Canon PowerShot G7 X Olympus E-M1 Olympus E-PL7 Olympus M.Zuiko Digital ED 9-18mm F4.0-5.6 Olympus M.Zuiko Digital ED 14-150mm 1:4-5.6 +5 more
gene thomson Veteran Member • Posts: 5,193
Re: Mine Is Doing It Too....
Press Ctrl and rotate the mouse thumbwheel to get the size you want.
Antioch Senior Member • Posts: 1,962
Re: On Windows Machine, Press CTRL plus + to make Site bigger
and Ctrl Plus - to make the site smaller.
DonA2
DonA2 Senior Member • Posts: 2,638
If only all internet fixes were so quick and easy.  Didn't need personally but good to know.
 DonA2's gear list:DonA2's gear list
Canon PowerShot S2 IS Canon PowerShot SX10 IS Canon PowerShot S100 Canon PowerShot SX40 HS Canon PowerShot SX50 HS +1 more
This is NOT a solution to whatever happened. Doing the control key and mouse wheel thing affects the size of the fonts (blows everything up or shrinks it down). Left alone the ads, messages, etc are still of the same size and clarity; it's not like they were shrunk down or anything.  The readability and usefulness of the site continues to be fine, at least for me.
The only difference I can see is that there seems to be some wasted gray space on either side that wasn't there before.
Tom
Daisy AU
Daisy AU Senior Member • Posts: 1,564
Re: What Just Happened?
Yes, I have a banner of Amazon adds at the top. However, most "free" sites are going that way, i.e. adding targeted ads to the page. Doesn't bother me and I'm used to seeing similar ads on many sites now.
Thanks,
Daisy AU - Brisbane
http://www.flickr.com/photos/ney_images/
 Daisy AU's gear list:Daisy AU's gear list
Nikon D7000 Nikon 1 V1 Nikon AF-S DX Nikkor 16-85mm f/3.5-5.6G ED VR Nikon AF-S DX Nikkor 35mm f/1.8G Nikon AF-S Nikkor 70-300mm f/4.5-5.6G VR +8 more
Thanks,
Daisy AU - Brisbane
Well, on a PHOTO site where a lot of pictures are posted it bothers me a lot to have my page shrunk down with no explanation.
Moderators, what just happened?
PS, the mouse trick was great - thanks.
Gary Eickmeier
AllMankind
AllMankind Contributing Member • Posts: 564
Nope.
Might want to try an ad-blocker.  VERY effective.
Oppose Tyranny in all its forms.
Simon Joinson
Simon Joinson dpreview Admin • Posts: 4,816
Thanks,
Daisy AU - Brisbane
Gary Eickmeier
We didn't change anything. The fixed width of the site has been the same since 2008, when it got slightly wider than it had been since 1998.  What you're talking about is the size of your browser window.
Simon Joinson, Editor-in-chief
dpreview.com
connect.dpreview.com
 Simon Joinson's gear list:Simon Joinson's gear list
Fujifilm FinePix X100 Sony RX100 II Canon EOS 20D Panasonic Lumix DMC-GM1 Nikon D750 +23 more
Simon Joinson
Nope.
It's kind of ironic that those who complain loudest about problems with DPR are also the ones that actively take steps to ensure that they do not to contribute to its upkeep.
dpreview.com
DonA2
Thanks,
Daisy AU - Brisbane
Gary Eickmeier
dpreview.com
Browsers do behave very differently.  Chrome works well on this site, IE10 not so much.  There may be some hope for us IE diehards with the announcement of IE11, comming soon.  Will it kill of cure?
