Tilting text ??
Started Jun 27, 2013 | Discussions
Central Fla Regular Member • Posts: 438
Tilting text ??
This simple task has eluded me today.  I can sort of fake it by free transform and cruching the text but it does not look right.  I want to place text on an object in an image that is on an angle.  Tried all my usual learning places and can't seem to find it,  I have learned a lot from you folks and appreciate your help.  In sharing something,  I tried to place text yesterday on something and it needed to be larger text than photoshop listed, 72 pt,  If this happens you can click your cursor directly on top of the font size number ( exmple 72pt ) in the font size selection box and type in whatever you want.
Thanks for any help.
Jen Yates Senior Member • Posts: 1,411
Re: Tilting text ??
Seeing as you use {insert operating system} and use {insert application name} version {insert version name} I would suggest you use tool {insert tool} and use {insert settings} but be careful of {insert cautions}.
I would be more specific but without knowing more on what software you are using it is very difficult.
Central Fla OP Regular Member • Posts: 438
Re: Tilting text ??
Sorry, W7 PS CS6, tried for an hour with text tool  and free transform with no luck.
(unknown member) Forum Pro • Posts: 10,011
Re: Tilting text ??
  1. Convert text to smart object
  2. Hit Ctrl-T
  3. Right click and choose the kind of alteration you want
~ Peano
www.radiantpics.com
Re: Tilting text ??
Thanks Peano, I found that menu using free transform but still can not lean the text forward or back. I did follow your suggestion all the way through, can do everything but tilt ?
I think now that SKEW will do it,  it may not actually tilt like my mind wanted but i guess it is the same thing,  make the bottom smalle and the top larger
look promising ?? Thanks Peano, that did it
richardplondon
richardplondon Veteran Member • Posts: 9,828
Re: Tilting text ??
Another way, is to hold the Ctrl key while you move the Free Transform corner handles. This linear warps.. not strictly into "perspective" AFAICT, because it does not seem to handle foreshortening quite 100% accurately, but close enough to that for most purposes.
Camera correction (horizontal and vertical perspective adjust) will be more technically accurate but offers a less extreme range of transformation.
However the text layer may need to be first get rendered into simple pixels with these options; certainly with some past PS versions, a live editable text layer can scale, rotate and skew - but not get warped / perspectivised.
It will be important to ensure your text maps onto a generous number of pixels, before you pixelise it, if so.
 richardplondon's gear list:richardplondon's gear list
Panasonic Lumix DMC-LX100 Pentax K-5 Sigma 10-20mm F4-5.6 EX DC HSM Pentax smc DA 21mm F3.2 AL Limited Pentax smc DA 70mm F2.4 AL Limited +7 more
Thanks Richard
wrote that one down also.
Do you think these techniques
are an equal match to something that did an actual tilt  ??
richardplondon
Re: Do you think these techniques
I think the Free Transform method (with perspective) is the only practicable way with standard Photoshop to change the 3D aspect / angle of one thing (such as some text) interactively, until it matches up with a background image that you need to see at the same time.
However, it is easy to get something looking as if it is stretched out and pinned onto a siurface, but stretched more in one direction than another - it takes some judgement to get this natural.
For example, here's two variations in putting some text onto a surface - which one is "better", the upper or the lower? To me, the lower one is more credible but that's not always a clearcut matter.
At least with CS5 (which I have) the camera correction tool does not let you view any background layer while you are making the adjustments... so that's no good for lining things up this way.
Extended PS (CC is equuivalent to PS Extended not Standard, a fact often missed) includes 3D transform tools which should not suffer from that restriction... and should retain a realistic apparent proportion as you rotate and swim the text around in a virtual space.
Perspective adjustment in the lens correction tool, though, works better IMO when you are changing the perspective of an entire picture. Usually this is a question of getting verticals vertical, and the grid that the tool gives you is all that you are paying attention to.
If you try to use Transform to do the latter kind of job, firstly it is very difficult - and secondly, it is easy to accidentally make all the things in the picture look skinny or fat as a side-effect of fixing a perspective convergence - just like the isolated text in my sample above, but affecting the whole image - IOW, there is no "reality proportion lock".
RP
Allen Gerdes Veteran Member • Posts: 5,560
Re: Tilting text ??
I cannot help you to perform this using CS6, but it is very easy to do in PSPX5.  Here is an example, wherein I opened an image with a white background, created a black triangle on a new transparent layer, added the red text at the bottom of the triangle on a separate layer, copied the text and pasted it on a new layer to the right side of the triangle and used the Pick tool to rotate and align it in relation to the right side of the triangle.  Did the same for the text on the left side.  Once satisfied, merged all layers.
Regards....Allen
mikes
mikes Veteran Member • Posts: 3,243
Re: Tilting text ??
A vector illustration program, such as CorelDraw, (or illustrator if you already have ) is better designed for work with text.
Only when you can criticize yourself, should you criticize others. Mikes.
Re: Tilting text ??
Not for what the OP wants (and a good deal more besides). Text in Photoshop is a vector object, the same as in Illustrator. When converted to a smart object it can be scaled, skewed, bent, warped, and distorted in all sorts of ways. CorelDraw and Illustrator can't do any of those things any better.
~ Peano
www.radiantpics.com
drh681
drh681 Forum Pro • Posts: 16,711
Re: Tilting text ??
There is a text transformation tool that will do what you want when the text tool is active.
It looks like a box with a round belly.
Click that and you will get a selction of adjustable presets.
Photons by the bag.
Gravitons no longer shipped outside US or Canada
You got a camera, now go out and get a life; or at least a picture of one!
 drh681's gear list:drh681's gear list
Nokia Lumia Icon
Sailor Blue
Sailor Blue Veteran Member • Posts: 9,060
Re: Tilting text ??
Photons by the bag.
To access the text warping tools such as this one with the text layer selected use the Photoshop Type>Warp Text command and select the tool you want to use.
Living and loving it in Bangkok, Thailand. Canon 7D - See the gear list for the rest.
 Sailor Blue's gear list:Sailor Blue's gear list
Fujifilm FinePix Real 3D W3 Canon EOS 7D Tamron SP AF 90mm F/2.8 Di Macro +10 more
drh681
OOps...
It is the "T" on a bridge that activates the warp dialog for a selected text.
Photons by the bag.
Nokia Lumia Icon
Michael Edward Rudge Veteran Member • Posts: 6,995
I tried this method
I used PS CS2  A4  times roman 72 size typed "TEST "
draw box round word,  copy and past, now we have grab handles to re-size and turn and twist
this may be a way forward
cheers Michael North wales
 Michael Edward Rudge's gear list:Michael Edward Rudge's gear list
Canon EF 50mm f/1.8 STM Canon Pixma MG5350 Samsung Galaxy S4
Thanks to everyone !!
If I were a paranoid person I would say this simple ability was intentionally left out,  lean the text forward and backward does not seem such a difficult idea to include if CS6 already can do everything with warp.
Smart object, Peano was right.
I think the key lesson here is the smart object, that activates the greyed out distort command.
Re: Thanks to everyone !!
It does include that. With a free-transform box, hold Ctrl-Shift and grab a middle handle. Smart object not required.
~ Peano
www.radiantpics.com
