Panasonic GX1 with Olympus VF3 EVF?
Started Jun 27, 2013 | Discussions
johnparas11zenfoliodotcom Senior Member • Posts: 2,214
are they compatible?
the GX1 is now on clearance for $200.. and I have an Olympus VF3 that I use on my Olympus e-p3.. and was curious if i can plug in my VF3 on the GX1 body..
thanks..
Olympus PEN E-P3 Panasonic Lumix DMC-GX1
Chas2 Veteran Member • Posts: 3,208
Re: Panasonic GX1 with Olympus VF3 EVF? No
thanks..
While the VF3 is compatible with a variety of Olympus bodies, neither it or its two cousins the VF2 and the VF4 are compatible with ANY Panasonic body.
GX1 is only compatible with the Panasonic LVF2.
 Chas2's gear list:Chas2's gear list
Panasonic Lumix DMC-LX5 Panasonic Lumix DMC-GX1 Panasonic Lumix DMC-GX7 Panasonic Lumix DMC-GM1 Panasonic Lumix G Vario 14-45mm F3.5-5.6 ASPH OIS +18 more
johnparas11zenfoliodotcom OP Senior Member • Posts: 2,214
Re: Panasonic GX1 with Olympus VF3 EVF? NO
thanks..
thanks
Sorry I wrote NO in all caps...did not mean to shout!  No offense intended.
jeffharris
jeffharris Veteran Member • Posts: 6,441
thanks..
Nope. But the Panasonic LVF2 is.
Got one for my GX1 @ B&H for $160. It's the same resolution as the Oly VF2, BTW.
 jeffharris's gear list:jeffharris's gear list
Panasonic Lumix DMC-GX7 Panasonic Lumix G Vario 7-14mm F4 ASPH Voigtlander Nokton 25mm F0.95 Voigtlander Nokton 42.5mm F0.95 Voigtlander Nokton 17.5mm F0.95 Aspherical +27 more
thanks..
$160 clearance or used? I don;t see that price at B&H
