What prevents you from moving to a mirrorless camera?
Started Jun 26, 2013 | Polls
RedFox88 Forum Pro • Posts: 24,705
Re: What prevents you from moving to a mirrorless camera?
The results of this poll clearly indicates the shortcomings of EVIL cameras: slow autofocus and viewfinder issues be it lack of a real viewfinder or refresh rates on framing photographs properly, e.g. panning/action.  Olympus, Sony, and Panasonic should take note if they want to survive!
Glen Barrington
Glen Barrington OP Forum Pro • Posts: 16,451
Maybe you should do a poll. . .
Just Having Fun wrote:
Glen Barrington wrote:
I listed the reasons I remembered reading about....
...and didn't consider there might others or even some people might have "no reason".
Clearly someone as brilliant as you would do a crackerjack job.
I still like soup. . .
Now that you've judged the quality of my typing, take a look at my photos. . .
http://www.flickr.com/photos/7267302@N03/
 Glen Barrington's gear list:Glen Barrington's gear list
Olympus OM-D E-M10 Olympus M.Zuiko Digital 14-42mm 1:3.5-5.6 II R Olympus Zuiko Digital 14-54mm 1:2.8-3.5 Olympus Zuiko Digital ED 9-18mm 1:4.0-5.6 Olympus Zuiko Digital ED 40-150mm 1:4.0-5.6 +11 more
Martin.au
Martin.au Forum Pro • Posts: 10,272
Yeah. Because listening to a heap of people with none/limited experience of their products is a great way to determine fact.
 Martin.au's gear list:Martin.au's gear list
Olympus E-M1 Olympus OM-D E-M5 Olympus M.Zuiko Digital ED 60mm 1:2.8 Macro Olympus M.Zuiko Digital ED 12-50mm 1:3.5-6.3 EZ Panasonic Lumix G Fisheye 8mm F3.5 +6 more
So you disagree with the fact that focusing of EVIL cameras are slower than SLR cameras and that framing photos through the rear LCD or an EVF is more difficult because of the refresh rate and that LCD screen have compared to OVF that works at the speed of light?
Just Having Fun Veteran Member • Posts: 3,869
Re: Maybe you should do a poll. . .
What do you like best about Crackerjack?
_ Caramel covered popcorn
_ Peanuts
_ Prize
_ other
Draek
Draek Senior Member • Posts: 2,028
I think he disagrees with the fact that focusing on most mirrorless cameras isn't fast enough, and that updating an image at the 'speed of light' is necessary in spite of our many-orders-of-magnitude-slower nervous system (case in point, how nobody ever speaks of mirror delay even though it's on the same order of magnitude as an LCD's refresh rate).
 Draek's gear list:Draek's gear list
Fujifilm FinePix F70EXR Canon PowerShot A1200 Samsung TL500 Sony Alpha DSLR-A390
Martin.au
RedFox88 wrote:
So you disagree with the fact that focusing of EVIL cameras are slower than SLR cameras and that framing photos through the rear LCD or an EVF is more difficult because of the refresh rate andthat LCD screen have compared to OVF that works at the speed of light?
In both cases, it depends on the cameras and situations being compared.
If you're trying to focus in low light, or with manual focus, etc, then EVF may be better and easier. If you're trying to chase a fast moving object through a long lens, then OVF may be better (though I think there's a better solution than EVF/OVF for that).
As for focus speed. Yeah, I'd put the OM-D up against most DSLR's for S-AF.
sderdiarian Veteran Member • Posts: 3,927
Agreed.
Then there's that size thing. Canon has made a valiant attempt at producing a DSLR that can compete with mirrorless on size and weight with its SL1 (100D). While it appears to compare favorably when viewed from the front... http://j.mp/14g6oVz
...view it from the top with a standard zoom and it points out the unchangeable DSLR downsides of fat bodies and oversized lenses: http://j.mp/14g6D2S
The E-M5 is currently the most complete expression of mirrorless advantages:
  • small, light, rugged weathersealed alloy body
  • a comprehensive system of equally small and light high quality lenses
  • Excellent EVF with virtually instant refresh that can show all settings, a histogram and a level or simply a grid at your option
  • 9 fps shooting capability
  • 5-axis IBIS, the benchmark for all IBIS systems
  • always spot-on accurate and fast CDAF
  • tilt and touch 3" OLED screen
  • 14x image magnification in the EVF or OLED screen for fine focusing distant and macro subjects
  • excellent low-light IQ
  • dual control wheels
Once mirrorless improves focus tracking (only a matter of time, hopefully in the OM-D II this fall) to solve the one remaining downside, there will be no rational reason left for lugging about oversized DSLR bodies and lenses, only resistance to change by people who haven't even tried the cameras, an ever diminishing audience.
Sailin' Steve
 sderdiarian's gear list:sderdiarian's gear list
Panasonic Lumix DMC-GM1 Olympus OM-D E-M10 II Panasonic Lumix G 20mm F1.7 ASPH Olympus M.Zuiko ED 75-300mm 1:4.8-6.7 II Panasonic Lumix G Vario HD 12-32mm F3.5-5.6 Mega OIS +1 more
As for focus speed. Yeah, I'd put the OM-D up against most DSLR's for S-AF.Agreed.
Agreed.
Once mirrorless improves focus tracking (only a matter of time, hopefully in the OM-D II this fall) there will be no rational reason left for lugging about oversized DSLR bodies and lenses.  Only resistance to change by people who likely haven't even tried the cameras, an ever diminishing audience.
Sailin' Steve
Re: DPR edit feature not working, apologies
First tried to edit my first post above so it was clear what was new and what was quoted, but the edit option wouldn't come up, so I then tried to withdraw and re-post, but it wouldn't allow me to withdraw it since I was the original author!  Time to call in the mechanic again, DPR .
Apologies for the duplication.
Sailin' Steve
AllMankind
AllMankind Contributing Member • Posts: 564
Oh please.
Believe it or not, some people actually LIKE a larger camera. just because you don't does not mean that those that do are wrong, or, as you state ' resistance to change by people who likely haven't even tried the cameras'
Buy/use the camera YOU like and find convenient/fun to use, but please, allows others to do the same.
Personally, I own 3 FF DSLRs.  I also own 2 mirrorless cameras.  A Panasonic GX1 and an NEX-6.  I use all my cameras pretty much equally.  I grab a particular camera based on what it is I intend to be shooting.
Oppose Tyranny in all its forms.
Mjankor wrote:
 for S-AF.
Just what is that?  Please write out your words instead of abbreviation that are not standard.
RedFox88 wrote:
Mjankor wrote:
for S-AF.
S-AF stands for Single Auto Focus. It is where the camera focuses on an area one time and doesn't then try to change focus. When acquiring quick focus and taking a picture in a split second, you don't want a camera that is as accurate as these trying to re-focus.
DPR has repeatedly said comments like these about the latest mirrorless cameras...
Single AF acquisition is impressively fast - using most Micro Four Thirds lenses will result in some of the fastest focus on any system.
Of course you already know that the CDAF focusing used by these cameras is also the most accurate from the DPR article/report...
1. Phase-detection autofocus (even using still targets and center-point only) wasn’t nearly as accurate as contrast detection.
2. The contrast-detection autofocus was about as accurate as the most careful manual focusing.
http://www.dpreview.com/news/2012/08/01/Roger-Cicala-Lensrentals-Canon-Autofocus-marketing-claims
So there you go.
- some of the fastest focus on any system.
- the MOST accurate focusing
Who wouldn't want that??
jtan163 Senior Member • Posts: 2,264
Two things.
There are full frame mirrorless. I'm assuming by which you mean 35mm. RX1, Lecia.
You forgot the "nothing I have a mirrorless camera and it rocks my socks" and "nothing is stopping me except money" options.
 jtan163's gear list:jtan163's gear list
Nikon D750 Olympus OM-D E-M5 Nikon D4 Olympus M.Zuiko Digital 45mm F1.8 Olympus M.Zuiko Digital 17mm 1:1.8 +7 more
eNo
eNo Forum Pro • Posts: 11,744
In a word, Quality
http://imagesbyeduardo.com/
Los Angeles wedding photography that seeks the heart and spirit in each image
dmanthree Veteran Member • Posts: 5,530
Nothing. I did change.
And haven't looked back.
No Signature.
RedSkiesAtNight Regular Member • Posts: 236
Re: In a word, Quality
No need to be afraid of quality.
AllMankind
Could you be a little more specific?
Quality of what?  Images?  Camera build?  Lenses?
I own micro43, NEX and FF DSLRs.  I think all are good quality.
I do have nits to pick with Sony regarding the 'quality' of their firmware, but build quality is excellent.  As is image quality of both NEX and micro43, and both systems have some stellar lenses (and some less so too).
ironcam Forum Member • Posts: 98
Re: Not missing at all, in my opinion.
Everyone is going on about how people aren't buying mirrorless cameras in the amounts that the industry expected them to, and how they seem to be more popular in Asia than in Europe and North America I wanted some clue as to why. Getting information from people who HAVE purchased a mirrorless camera didn't seem pertinent to the question.
This video pretty much explains why.
http://www.youtube.com/watch?v=JmWGmnnXz0c
Most people don't even know quality mirrorless camera's exist.
FrankyM Senior Member • Posts: 2,245
Samsung's answer to this question
