Firmware update and Apple Macs
Started Jun 25, 2013 | Discussions
masterofdeception Regular Member • Posts: 267
My PC is a 5 year old Mac using Lion, "upgraded" from Snow Leopard, and the new Fuji firmware won't work, as Power PC is no longer supported (something to do with Rosetta). Guess this is an Apple problem, and I'll upgrade from a friend's computer, but anyone else having this issue?
Chris Dodkin
Chris Dodkin MOD Veteran Member • Posts: 6,775
Re: Firmware update and Apple Macs
the issue you are most likely seeing is easily fixed
The Mac will automatically rename the file you download from Fuji, if one of the same name already exists in the downloads folder
This rename happens without the Mac telling you anything - it usually just adds -1 or -2 etc to teh name
The Fuji camera will fail to recognize this file as a valid file and the upgrade will fail.
clean out all the old fuji firmware files from your downloads folder first
Download the new firmware
Copy to SD card
Upgrade
That should sort you out
http://www.dodkin.com
Chris@1D-Images.com
Mac Pro/MacBook Pro/iPods/iPhones/iPad
 Chris Dodkin's gear list:Chris Dodkin's gear list
Fujifilm FinePix X100 Canon EOS 5D Mark II Canon EOS-1D Canon EOS-1D Mark II Canon EOS 30D +34 more
Al Valentino Senior Member • Posts: 4,619
If you have an older version of the update it might gotten renamed "-1"
This happens all the time when I download an upgrade to my mac. All version of the firmware have the same name so every download renames the file and it will not work.
so take the downloaded file and copy it to a freshly formatted SD card. Then look at the file name. It should be ...0001.dat, if it is something like ...0001-1.dat then rename it. Then place in camera, turn On while holding down the Disp button and you should be good. If the camera reads the file that is different in name it will not recognize it. All fuji firmware files for all version have the identical name.
 Al Valentino's gear list:Al Valentino's gear list
Fujifilm X-E1 Fujifilm XF 14mm F2.8 R Fujifilm XF 18-55mm F2.8-4 R LM OIS Fujifilm XF 55-200mm F3.5-4.8 R LM OIS Rokinon 8mm f/2.8 UMC Aspherical Fisheye +6 more
masterofdeception OP Regular Member • Posts: 267
Thanks, but i think this is an Apple problem, as I can't even get the file onto my desktop.  It just won't download.  I've contacted Fuji, but my guess it it's a problem related to the change from Snow Leopard to Lion, which lost support for Rosetta based apps.
I've had no problems with previous updates, but those were all done when I was using Snow Leopard.
Antone
Antone Contributing Member • Posts: 853
In Safari, have you tried right-click (or control-click) to get the pop-up dialog window? There should be a "Save linked file as" or some such. Choose it and you should be able to save it to where ever you want. Make sure your SD card is formatted in your Fuji camera, then just copy the file over to the Fuji formatted SD card.
Tony-S
redsim74 Senior Member • Posts: 2,156
Why would it have anything to do with Rosetta? You're not running the firmware update on your Mac.
No issues here downloading f/w to a 2008 MacBook running Mountain Lion.
David McGaughey Senior Member • Posts: 2,246
Doesn't make any sense
You are just downloading a file and copying it to a blank, formatted (in camera) SD card. The OS doesn't matter.
Safari is no help because I'm told there is no application to open the file.  From a few Google searches, I'm sure it's an Apple related issue, though if your Mac is a newer one than mine it shouldn't occur.  If anyone has a quick fix though (other than paying Apple for more hardware) then I'd be very happy to hear from you.
Re: Doesn't make any sense
Sorry, I have downloaded the update, but I can't open it (or copy it) because "Power PC applications are no longer supported".
webfrasse Veteran Member • Posts: 3,857
It's a file you download from Fuji's website. The OS on your Mac or PC means nothing. Really has nothing to do with it. The file doesn't need to be on your Desktop either. It can download anywhere. It needs to be on the root of the SD card. That's all...
Mikael
fluxism Contributing Member • Posts: 505
I just did the update on my mac with Mountain Lion
 fluxism's gear list:fluxism's gear list
Fujifilm X-E2 Fujifilm X-Pro1 Fujifilm X-Pro2 Fujifilm XF 56mm F1.2 R Fujifilm XF 35mm F1.4 R +2 more
Chris Dodkin
you don't have to open the file - just download it
Chris@1D-Images.com
Chris Dodkin
You simply drag the file onto the icon for your docked SD card to copy it
No need to try and open it
Chris@1D-Images.com
AB8ND
AB8ND Regular Member • Posts: 165
You don't open the file, read the Fiji instructions. Download it, copy it to a camera formatted card ( in a card reader), put the card back in the camera then follow the rest of the instructions. I say again no need to open the file.
 AB8ND's gear list:AB8ND's gear list
Fujifilm X100S Fujifilm X-E1 Canon EOS 6D Fujifilm X-T10 Fujifilm XF 14mm F2.8 R +5 more
Antone
No file needed to open
This is a dialog box from Safari? Can you state exactly what it says?
If your camera is an X-E1, simply paste this URL into Safari's URL box:
http://download.fujifilm.co.jp/pub/tools/xe1q5sbcfvj/FWUP0001.DAT
You should get a file download named FWUP0001.DAT in your download folder ~home/Downloads. Simply drag and drop this file onto your SD card that was formatted in your camera.
Tony-S
Re: No file needed to open
Tony-S
Not necessarily true. If you have a previous firmware update that you downloaded at some prior date in that download folder then the file will be automatically renamed to FWUP0001-1.DAT. So when you drag it over to the formated SD card, you need to rename (remove the '-1). Then, and only then, will the camera recognize it. I go through this all the time with my Mac. The first time drove me crazy until I realized my mac was renaming the new version. It is also a good idea to remove the file from the download folder. That will prevent renaming next time.
briny Regular Member • Posts: 275
Use Finder to locate the Fuji file FWUP0001.DAT in your Downloads folder. Insert your formatted camera card into your Mac's card slot. Then simply drag the Fuji file to your card to copy it there.
 briny's gear list:briny's gear list
Fujifilm X-T1 Fujifilm X-E1 Fujifilm XF 18-55mm F2.8-4 R LM OIS
rh22 Regular Member • Posts: 157
Same with me.  No issues on Mountain Lion.
 rh22's gear list:rh22's gear list
Fujifilm X-T10 Apple iPhone 6 Apple iPad Air
Thanks to everyone who pointed out the error of my ways, I've now managed to achieve what was quite a simple task.  I think I did it slightly differently to previous upgrades, but got distracted by the error messages I started to get when I tried to put the file on my desktop (as per the instructions).  Lesson learned = don't try firmware upgrades when it's past your bedtime!
Thanks again everyone.
