how make the background black
Started Jun 25, 2013 | Discussions
b4cktr4ck
Regular MemberPosts: 156Gear list
Jun 25, 2013
Hi all,
is it possible to make the background a uniform black without affecting the black on the clothes and accessories and without cropping the image?
if yes, can you share how in Photoshop? I have similar photos I would need to retouch
thanks!
 b4cktr4ck's gear list:b4cktr4ck's gear list
Canon EOS 6D
Allen Gerdes
Veteran MemberPosts: 5,490
Re: how make the background black
In reply to b4cktr4ck, Jun 25, 2013
Is this what you are looking for?
I cannot show you how to do it in Photoshop, as I rarely ever use it.  This was done using PSPX5 and the Topaz Labs Remask plugin to extract the subjects from the background.  Then placed the extraction above a black background and merged layers.
Regards....Allen
HB WOODY
Junior MemberPosts: 43
I opened in PS and put a black layer under the image then created a mask to show the black layer in the easy to cover placed. I then used Camera Raw to adjust the shadows and the blacks.
Patsy Murphy
Senior MemberPosts: 2,083
b4cktr4ck wrote:
Hi all,
thanks!
I'm a little confused as to what you really want. You have two black sheets and a pop up background which I assume should  also be black in color, however either due to your camera settings or lighting setup your pop up background is a very dark navy blue color, you can clearly see that due the shadows behind him especially, if you were to uniformally set the whole background to black it would take away the outline on the top of his head, of course you could always add a couple of little highlights to the top of his hair. I did two versions to show you what I mean. One with the accessory and one without.
You can achieve similar results to what Allen did by duplicating the layer change the blend mode to soft light add a mask and mask the people back in.
Regards Patsym
Ralph Ramirez
Veteran MemberPosts: 6,912
Created a mask then placed black layer below image but also lightened his hair so that it shows up a little more.  Used curves until the hair looked like I wanted it, inverted the mask then painted the hair back with white brush .............Ralph
Toermalijn
Forum ProPosts: 13,325Gear list
b4cktr4ck wrote:
Hi all,
thanks!
Next time, if you want to make extractions in photoshop, use white. It's much better for extractions in photoshop.
b4cktr4ck
In reply to Patsy Murphy, Jun 25, 2013
Good point I agree with the hair issue and shadows. What if we retouch it in a way where we leave the backdrop as it is and the same black of the backdrop is used for the rest of the background so that is not pitch black?
Canon EOS 6D
Sailor Blue
Veteran MemberPosts: 8,676Gear list
In reply to b4cktr4ck, Jun 26, 2013
The biggest problems here are the way you placed and lit your subjects.
Your subjects are so close to the background that subject lighting is making the background gray, not black, and the subjects are casting shadows on the background.
First, you need to keep subject a minimum of 6' from the background to keep their shadows off the background.
Second, you should have lit the subjects in such a way that as little as possible light hit the background so that it would be black.  Depending on how you light and what type of light modifiers you use you might have to flag the background to keep the subject light off of it.
A hair light would have helped separate the middle subject's dark hair from the background.
Living and loving it in Bangkok, Thailand. Canon 7D - See the gear list for the rest.
 Sailor Blue's gear list:Sailor Blue's gear list
Fujifilm FinePix Real 3D W3 Canon EOS 7D Tamron SP AF 90mm F/2.8 Di Macro +10 more
b4cktr4ck
In reply to Sailor Blue, Jun 26, 2013
Thanks for the suggestion Sailor Blue. I just didn't have enough room (and background) to move the subjects further from the background
I don't really mind if the background is grey due to the vicinity
Good point with the hair light will keep that in mind
Canon EOS 6D
