Can I use Canon 580EX II speedlight with X100S
Started Jun 25, 2013 | Questions
Nigel Clifford Contributing Member • Posts: 771
Anyone using Canon flash with X100S
Nigel
 Nigel Clifford's gear list:Nigel Clifford's gear list
Sony RX100 Panasonic Lumix DMC-FZ1000 Panasonic Lumix DMC-ZS60 Sony Alpha 7R II Tamron SP 24-70mm F2.8 Di VC USD +4 more
Fujifilm X100S
Daniel from Bavaria Contributing Member • Posts: 797
Re: Can I use Canon 580EX II speedlight with X100S
Yes, you can. In full manual mode. The trigger will only be the middle contact, so no TTL or kind of that.
Did it with the X100 and the XP1.
Daniel
Nigel Clifford OP Contributing Member • Posts: 771
Thanks for info Daniel. I was pretty sure it would be manual only just wasn't sure it would fire and not blow up the camera, voltage issues.
Nigel
baobob
baobob Veteran Member • Posts: 7,222
You can also use it in A mode my rather similar metz works perfectly that way.
Sony RX100 Olympus Tough TG-4 Fujifilm X-T1 Nikon D7200 Fujifilm X-T10 +12 more
tiberiousgracchus Regular Member • Posts: 250
If interested I think you can also use it wirelessly using a  Wein HS Hot Shoe Slave activated by the on-board flash. Not 100% sure .Can anyone verify this ?
