Minolta 28mm f/2.8 AF
Started Jun 24, 2013 | Discussions
CaptureAll
CaptureAll Regular Member • Posts: 178
Hi all,
Right now I have the 18-55 SAM II kit which is not bad but, I really like the 42mm equivalent for every day shooting and 127mm equivalent for my kids activities where I can't always be so close.
I would like an opinion of anyone who has or had the Minolta 28mm f/2.8 AF. Image quality, speed, whatever info you have. There is one that is available near me and I'll be checking it out tomorrow. The other option is the Sony 35mm f/1.8 DT which seems to be getting very good reviews as well. A small amount longer but the f/1.8 might come in handy sometimes. It's about $90 more locally than the Minolta mentioned above.
Thanks again
 CaptureAll's gear list:CaptureAll's gear list
Pentax K-r
geoffmalter
geoffmalter Senior Member • Posts: 2,489
Re: Minolta 28mm f/2.8 AF
I have the 35 f1.8 and IMO for the money it's excellent. Have you been over to dyxum.com? Best for consumer Minolta lens reviews.
 geoffmalter's gear list:geoffmalter's gear list
Olympus Tough TG-1 iHS Panasonic Lumix DMC-LX7 Sony SLT-A57 Canon EOS M Sony DT 55-300mm F4.5-5.6 SAM +8 more
CaptureAll
CaptureAll OP Regular Member • Posts: 178
Thank you for that link Geoff, seems the Minolta 28mm f/2.8 gets a decent rating; 4.3 overall from 126 reviews. I'll have a look at it tomorrow and decide.
In the near future I want a 85-100mm as well. The 85mm SAM f/2.8 looks good for $320 locally, unless another used-gem pops up in one of the shops here.
Pentax K-r
beardedspoooon
beardedspoooon Regular Member • Posts: 139
I have the Sony version. It's kind of a weird focal length, but I thought it good enough for walking around. I could zoom with my feet when necessary/
If I could go back, I would have purchased the 35mm 1.8. I've since purchased a Tamron 17-50 2.8, so the 28mm will be hitting the auction block soon enough.
Here's an image with the 28mm and a 100% crop FWIW.
This one might be more helpful:
puttin
puttin Veteran Member • Posts: 6,715
Have you looked at the Sigma 30mm f1.4. The old version is under $200 which is cheaper than the new model and the optics are the same, happy with mine and also my Minolta 28
 puttin's gear list:puttin's gear list
Fujifilm XF1 Fujifilm X100S Nikon Coolpix A Nikon D300 Fujifilm X-Pro1 +30 more
PhotoLouP
PhotoLouP Junior Member • Posts: 25
It is a very nice lens but itbdepends on your need.  It is sharp and autofocus is fast, but for a prime is  a bit slow.  Sony steadyshot helps, but for indoors I'd favor a faster lens.  It is a great walkaround lens.  I use it or a 50mm for night/star shots, as primes are far better than zooms.  It is a bargain compared to the faster minolta or sony primes with excellent quality with the only limitation of the f2.8.  I like this kind of lens for hiking and activities that are bright outdoors and where it might get damaged or stolen. Good luck with your choice!
 PhotoLouP's gear list:PhotoLouP's gear list
Sony Alpha DSLR-A350 Sony Alpha DSLR-A580 Samsung NX100 Sony a77 II Samsung NX 30mm F2 Pancake +8 more
NAwlins Contrarian
NAwlins Contrarian Regular Member • Posts: 463
I had a Minolta AF 28mm f/2.8 years ago, purchased for film. Overall, I thought its performance was good but not stellar. On an "APS-C"-sensor Sony, it is exactly a "normal" lens, that is, one whose focal length equals the diagonal dimension of the sensor (or film). If I were in your position, I'd either stick with the 35mm f/1.8, or get something significantly wider, like the Minolta 24mm f/2.8 (which by all accounts is also better optically). I you just have to have something wider than 35mm, but you don't want something wide as 24mm, I'd go for the Sigma 30mm f/1.4, which is discontinued in the Sony mount but should still be available.
 NAwlins Contrarian's gear list:NAwlins Contrarian's gear list
Canon PowerShot SD4000 IS Canon PowerShot SX230 HS Nikon Coolpix S30 Sony Alpha DSLR-A580 Tamron SP AF 90mm F/2.8 Di Macro +6 more
CaptureAll
Thanks all for the input on this lens, I really appreciate it. I have decided to go with the 35mm f/1.8 and the 85mm f/2.8.
Unfortunately, I'm going to have to wait on the purchase(s) as money is going towards something else right now. Maybe in a month or 2, unless my upcoming review at work yeild a decent increase The kit lens (18-55mm SAL II) will have to do, actually it's probably the best kit lens I've had!
Pentax K-r
