converting TIF to JPG saving EXIF
Started Jun 24, 2013 | Discussions
sherman_levine
sherman_levine Veteran Member • Posts: 9,957
I have a bunch of images which have been processed from RAW to TIF, and which contain accurate EXIF information.
I want to convert the TIFs to JPGs for posting, however neither Irfanview nor Faststone preserves the ISO/aperture/shutter speed, despite my checking the appropriate fields in the batch converter.
Is there any program which can perform the batch conversion and keep the EXIF information visible?
Sherm
 sherman_levine's gear list:sherman_levine's gear list
Panasonic Lumix DMC-FZ1000 Nikon Coolpix P900
JudyN Veteran Member • Posts: 3,852
Re: converting TIF to JPG saving EXIF
Are you sure? That sounds very surprising.  I use exiftoolGUI which lives on top of exiftool when I need to know what the metadata really looks like.
I munge my files that come out of my camera to store information from the camera data in metadata fields that Lightroom can read before loading into LR.  So you could move the information you want before processing.  Still surprising though.  What I'm moving is rather obscure camera settings on my Sony camera, not something basic like you are talking about.
Judy
 JudyN's gear list:JudyN's gear list
Panasonic Lumix DMC-G1 Sony SLT-A77 Olympus OM-D E-M5 Olympus Zuiko Digital ED 9-18mm 1:4.0-5.6 Panasonic Lumix G 20mm F1.7 ASPH +7 more
Glen Barrington
Glen Barrington Forum Pro • Posts: 16,442
ACDSee Pro 6
Probably the Raw Aware ACDSee 16 as well (Opens and displays raw but can't develop raw). Right now, they are VERY close in price. ACDSee16 was just released, and Pro 7 which we expect to share a lot of code with ACDSee 16 to be released "soon", so If you have a specific need that pro 6 can fill, or if you hate 30 day free trials, it's at a good price.
As an FYI, even though I knew it could do it, I retested Pro 6 before answering this query. It converted both my ORF files and my 16 bit tiffs to jpg with no loss of EXIF data no problem. So I feel confident I'm not wrong.
I still like soup. . .
Now that you've judged the quality of my typing, take a look at my photos. . .
http://www.flickr.com/photos/7267302@N03/
 Glen Barrington's gear list:Glen Barrington's gear list
Olympus OM-D E-M10 Olympus Zuiko Digital ED 9-18mm 1:4.0-5.6 Olympus Zuiko Digital ED 40-150mm 1:4.0-5.6 Olympus Zuiko Digital 14-54mm 1:2.8-3.5 Olympus M.Zuiko Digital 14-42mm 1:3.5-5.6 II R +11 more
sherman_levine
sherman_levine OP Veteran Member • Posts: 9,957
I didn't realize it was an issue until I looked for the EXIF info, but it's apparently a well-known problem with several programs which perform TIF-JPG conversion.    I ended up using ViewNX2, which handled the EXIF info fine, although it locked while processing about 10% of the TIFs
Sherm
sherman_levine
Re: ACDSee Pro 6
Thanks for your help. I was able to convert with EXIF preserved using ViewNX2. but I'll keep ACDSee Pro in mind
Sherm
cliik Regular Member • Posts: 128
I just converted a batch of TIFFs using FastStone v4.8 and all EXIF data remained intact.
 cliik's gear list:cliik's gear list
Pentax K-7 Sony SLT-A99 Tamron AF 28-75mm F/2.8 XR Di LD Aspherical (IF) Tamron SP AF 90mm F/2.8 Di Macro Sigma 70-200mm F2.8 EX DG OS HSM +4 more
sherman_levine
The FastStone results are strange. I can see the EXIF (including the ISO) if I look at the JPG in e.g. Irfanview, but the ISO doesn't appear in either Windows Explorer or in Picasa.
If I convert using ViewNX2, the ISO does appear in both Explorer and Picasa.
so the two programs for some reason yield different results.
Sherm
