olympus epl-5
Started Jun 24, 2013 | Discussions
paul cool Contributing Member • Posts: 568
olympus epl-5
just purchased  a epl-5 how will this do for a pocketable camera also the deal at the moment is a free 17mm pancake so I couldn't resist ? this will hopefully be back up for my gh3 when  I don't need zooms and bulk ,sorry talking of m43 and bulk does not seem true but it can add up .I have heard bad things of olys menus and great things of ooc jpegs cant wait for those .also will i need a view finder, like the idea of v4 looks like a big viewer which is good for composition,  any tips would be great I wonder if  my zukio 135mm lens behaves better on the Olympus with ibis although only 3 axis must help .
 paul cool's gear list:paul cool's gear list
Olympus E-M1 Panasonic Lumix DMC-GH4 Panasonic Lumix DMC-GX8 Olympus M.Zuiko Digital ED 75mm F1.8 Panasonic 12-35mm F2.8 +2 more
Panasonic Lumix DMC-GH3
markintosh13
markintosh13 Senior Member • Posts: 1,942
Re: olympus epl-5
Depends on the size of your pockets and your expectations. Since you have one, feel free to try.
Ok
Ok
If you say so. Perhaps you need more exercise - see the tips below.
Ok
That depends on if you think you need a view finder
Since you have a GH3, are using this as a backup, and are so  concerned about bulk and pocket-ability, I'm going to say "no"
It probably won't help you fit things into a pocket. The primary reason to buy a PL5 over something slightly smaller is the fold out screen - you might want to give that a try.
Don't eat yellow snow
Eat more vegetables. Spinach might be good.
Get more exercise
Learn to use paragraphs, punctuation and structured writing techniques
That probably won't fit into your pocket, and I'm going to guess that it might add bulk.
In all seriousness, enjoy your PL5 - it's great.
jalywol
jalywol Veteran Member • Posts: 7,394
Re: olympus epl-5
Congratulations!
The EPL5 is an excellent complement to your GH3. You can set it up to have all the necessary adjustments at your fingertips, without having to menu dive for anything. In addition, you can activate the Super Control Panel, which is a quick menu that allows rapid access to most menu parameters.
(You should look at the info guides by Guy Parsons about setting up the EPL5 for use; his Oly setup pages start here: http://homepages.ihug.com.au/~parsog/olyepl1/01-epl1-menu.html )
Only you know if you need a viewfinder or not....I have the VF-4 on my EPM2, and it is absolutely fabulous.  It is a much nicer viewfinder in all ways than the one on the GH3, which I also have used for a  while.  The VF-4 is the single best EVF I have tried on any camera yet....definitely worth the investment if you use them.
Long lenses at very low shutter speeds will be helped some by the IBIS, although it's not as effective as OIS or the 5-axis IBIS in the OMD.  I'd experiement with it and see if it makes a difference for you in your shooting situations...
The Oly menus are not as straightforward as the Panasonic ones, but they are not that bad.  You should be able to set up the camera to your liking within a very short period of playing around with it....
Enjoy your new camera!
-J
paul cool OP Contributing Member • Posts: 568
Re: olympus epl-5
is the 17mm pancake any good ?
thanks for the guy parsons link
the zukio 135mm f2.8 is small for this type of  lens ,it only requires a 55 mm filter so not huge
but a heavy construction build  all metal and built in hood
jalywol
Re: olympus epl-5
I have not used it, but the 17mm f2.8 is generally regarded as one of the softer lenses for M43.  Stopped down it's ok, from what I recall reading, and some copied perform better than others....
I've used the 100-300mm on my EPM2, as well as some heavier legacy lenses, and I just hold the whole setup by the lens body, with my left hand, rather than holding the weight of it on the camera grip.  It works well that way, even though it looks kind of silly
-J
RichRMA Senior Member • Posts: 4,073
This isn't Twitter (thank God)
Where people avoid using proper English as much as possible.
Re: This isn't Twitter (thank God)
too true
traveler_101 Senior Member • Posts: 1,685
Re: olympus epl-5
It is best shot at 4.0-5.6 I remember reading. The lens has its defenders but it also has many critics.
 traveler_101's gear list:traveler_101's gear list
Olympus PEN E-P5 Olympus M.Zuiko Digital 17mm 1:1.8 Olympus M.Zuiko Digital 25mm F1.8 Panasonic Lumix G 20mm F1.7 ASPH Olympus M.Zuiko Digital ED 40-150mm 1:4-5.6 +2 more
Re: olympus epl-5
Ok
Ok
Ok
I have two pockets although not as deep as the 250 pounds needed to buy it ,price is almost as much as the camera costs so will hang fire for the moment.
Get more exercise
im just lazy where punctuation and structured writing is concerned oh hum ,
and don't wipe your bum on a stinging nettle
love spinach
and I don't do excercise
ok
Re: olympus epl-5
well at least it will make the Olympus a more compact  camera
I will probably use my pana leica 25mm f1.4 with the Olympus its my smallest lens ,and my only other prime is the pana leica 45mm f2,8 although about the same size as the 25mm .
Edward Lowy
Edward Lowy Regular Member • Posts: 212
Re: olympus epl-5
-J
Quite right. Have used my 43rds 70-300 on my EPL2 with the same technique for some time, no problem at all - and pretty good results I have to say.
Edward
 Edward Lowy's gear list:Edward Lowy's gear list
Olympus PEN E-P5 Olympus M.Zuiko Digital 45mm F1.8 Olympus M.Zuiko Digital ED 12mm 1:2 Olympus M.Zuiko Digital ED 60mm 1:2.8 Macro Olympus PEN E-PL2 +4 more
Re: olympus epl-5
Edward Lowy wrote:
-J
Edward
its good practise to support lens with the other hand it helps stability
if I use the epl-5 with my 100-300mm i can mount the lens to a  tripod.
i  use a German  made collar tripod adaptor  www.r-Roche.de
