Metaraw plugin
Started Jun 23, 2013 | Discussions
Vic Chapman
Vic Chapman Veteran Member • Posts: 4,023
Metaraw plugin
Has anyone tried this plugin yet? Any feedback?
http://thepluginsite.com/products/metaraw/index.htm
The sky is full of holes that let the rain get in, the holes are very small - that's why the rain is thin.
Spike Milligan
 Vic Chapman's gear list:Vic Chapman's gear list
Fujifilm X-Pro1 Fujifilm X-E1 Fujifilm X-T1 Fujifilm XF 18mm F2 R Fujifilm XF 35mm F1.4 R +11 more
Dwayne Anders
Dwayne Anders Contributing Member • Posts: 583
Re: Metaraw plugin
I had a version of CS2 and installed meta raw. I was then able to edit Nikon D4 NEF raw files using CS2, which I could not edit them in before. When you open the raw files, you get a popup window asking if you want to use Adobe Camera Raw or Meta Raw. Other than that, it seems to work fine.
Dwayne
Vic Chapman
Vic Chapman OP Veteran Member • Posts: 4,023
Re: Metaraw plugin
Many thanks Dwayne.
Vic
Spike Milligan
