ICC Paper profile problem w Lightroom5
Started Jun 22, 2013 | Discussions
johnsong Senior Member • Posts: 1,173
Installed trail version of LR 5 and the paper ICC profiles did not follow from LR 4.
Do I have to reinstall all the paper profiles ?
Simon Garrett Veteran Member • Posts: 4,995
Re: ICC Paper profile problem w Lightroom5
In the drop-down list to select profile, are they in "Other..."?  You may have to click the check-box by the names of the profiles you want to use.
Simon
 Simon Garrett's gear list:Simon Garrett's gear list
Nikon D800
johnsong OP Senior Member • Posts: 1,173
Simon
Tried using that . mine is blank
LR 4.4 is populated
goanna Contributing Member • Posts: 638
Well I have upgraded and there is not a problem.
Check that they still exist on you pc
On WIndows 7 they are located here
C:\Windows\System32\Spool\Drivers\Color\
Or go to your Control Panel > colour management > and select all profiles tab.
If your profiles are still there then there is something wrong with the LR 5 installation.
Sorry
Cannot help your for other Win Versions or Apple
 goanna's gear list:goanna's gear list
Canon EOS 5D Canon EOS 40D Canon EOS 7D Canon EF-S 15-85mm f/3.5-5.6 IS USM Canon EF-S 17-55mm f/2.8 IS USM +9 more
