Please help!-don't know if 58mm tube ring fits canon SX50-HS
Started Jun 21, 2013 | Questions
amatuerphotographer777
New MemberPosts: 3
Jun 21, 2013
I've recently bought a 58mm filter adapter for my canon sx50 and i don't know if it will fit.
I bought it from here- http://www.aliexpress.com/item/58mm-Adapter-Tube-Ring-Square-Filter-Holder-for-Canon-SX40-HS-SX30-SX20-SX10-IS-FA/735016688.html
Please help!!!
Jay7h
Regular MemberPosts: 171
Re: Please help!-don't know if 58mm tube ring fits canon SX50-HS
In reply to amatuerphotographer777, Jun 21, 2013
I am not sure what you ordered but before doing anything, you will need a 58mm adapter that locks into the lens of the camera. This left on and will give you a 58mm connection to anything (filter etc) that size.
http://www.amazon.com/Conversion-PowerShot-MagicFiber-Microfiber-Cleaning/dp/B00C1PXJ8W/ref=sr_1_2?ie=UTF8&qid=1371836228&sr=8-2&keywords=58mm+adapter+for+canon+sx+50
Monicakm
Senior MemberPosts: 2,344
In reply to Jay7h, Jun 21, 2013
Yes but like Jay said, you'll need an adapter ring first.  The SX50 doesn't have threads on the end of the lens barrel.  Just think of the ring as adding threads to the barrel (something every other camera I've owned already had!)  The barrel is 58mm so yes, 58mm lenses will work.
Monica/SX50
unknown member
(unknown member)
While a little pricey the Lensmate 58mm adapter works very well on the SX50.
Murry
New MemberPosts: 3
In reply to Monicakm, Jun 22, 2013
I don't think you did understand. what i've but is a filter adapter that in one end connects to the canon sx40 (and sx30 sx20...) and the other and connects to 58mm accessories (for example a filter).the other thing that comes with the adapter is a square filter holder that fits 58mm. i'm worried that the filter adapter doesn't fit my canon sx50.
one thing i know is that the filter adapter in the link doesn't mount like the lensmate 58mm adapter for the canon sx cameras. with the lensmate you only need to turn it 90 degrees, and the adapter i ordered mounts like a screw (i guess...).
unknown member
(unknown member)
In reply to amatuerphotographer777, Jun 22, 2013
The SX50 lens is slightly larger than those on the SX10-SX40s so you may have a problem if your adapter doesn't say it fits the SX50?  Of course you can give it a try but I wouldn't force it.
Murry
Blink11
Forum MemberPosts: 86
If your adaptor mounts with a thread, it doesn't fit either the SX20,30,40, or 50, despite the claims of the vendor.
You'll need the bayonet type adaptor as per Lensmate or canon.
Pete
j2l3m7
Senior MemberPosts: 4,041Gear list
It states
"Square Filter Holder for the FA-DC67A"
Filter Adapter FA-DC67A  is For the PowerShot SX30 IS,SX40 HS,SX50 HS
Thanks for posting, have a great day.
John
 j2l3m7's gear list:j2l3m7's gear list
Canon EOS 70D Canon EF 100mm f/2.8L Macro IS USM Canon EF 70-300mm f/4-5.6L IS USM Canon PowerShot SX60 HS Canon EF 85mm f/1.8 USM +10 more
Augustin Man
Veteran MemberPosts: 5,993Gear list
In reply to j2l3m7, Jun 22, 2013
j2l3m7 wrote:
It states
John
Yes, but the original Canon adapter is for 67mm filter, in my opinion without any reason: the Lensmate 58mm adapter mounts perfectly and of the difference in dimension one can get a better quality filter. More than that, with a down-step ring 58-43mm you can also screw in your Raynox 150/250 lenses.
I have both adapters and never use the original Canon one...
All the best,
Augustin
 Augustin Man's gear list:Augustin Man's gear list
Canon PowerShot SX50 HS Nikon Coolpix P900
