suggest manual lens for milky way
Started Jun 21, 2013 | Discussions
kcire
kcire New Member • Posts: 15
I just captured a milky way photo with NEX-5N + 16mm + VCL-ECU1.
I did it but that's very difficult to find infinity focus even using focus peaking in very dark situation.
I think next time I want to use manual lens which has distance mark.
I'm thinking about Samyang 14/2.8, is it good to NEX?
Please suggest the other manual lens which:
- ultra wide (12-20mm)
- small body (not bulky)
- has fix and large aperture (f/2.8)
- has distance mark
thanks
Sony Alpha NEX-5N
nevercat
nevercat Senior Member • Posts: 3,193
Re: suggest manual lens for milky way
First: Beautifull picture! Very nice!
Second Focussing on the stars  is very difficult, it does not matter what lens you use. The focuscale on a MF lens is not accurate, differences in temperature will change the focus setting you need (even when focus is right, when temperatures are dropping you may have to refocus. So focussing iwill always be difficult...
Astrophotographer 10
Astrophotographer 10 Senior Member • Posts: 6,530
Lens wide open, ISO to maximum (I think its 12800) turn focus peaking off- its only distracting. Point to the brightest star, use magnified live view and use the LCD. You should be able to see a bright enough star like that. That is what I use with my Nex 6. I sometimes use the EVF but the LCD is fine.
Alternatively point towards a distant light source if there is one nearby and focus on that. Or focus during the day and tape the focus ring so it doesn't move or put a bit of tape where infinity focus is so you simply line up the tape marks at night.
That lens looks good wideopen. That is unusual. Most have coma or bad chromatic aberration so you would be better off persisting with that lens.
Besides another lens won't help you if its also F2.8.
Greg.
 Astrophotographer 10's gear list:Astrophotographer 10's gear list
Sony Alpha 7R II Sony FE 55mm F1.8 Zeiss Batis 25mm F2 Zeiss Batis 85mm F1.8 Zeiss Loxia 21mm F2.8 +4 more
kcire
kcire OP New Member • Posts: 15
i'm using f/2.8,  iso 1600 / 3200 and 20-30 seconds
the peaking focus and mf assist helps a lot at the first 30 minutes, but after I change focus to a FG / POI, then the problem begins. It can't infinity again for the rest time. is it because low temperature?
i don't understand why e-mount lens focus ring has neverending turn.
nevercat
It should not be for the temp, as long as you'r not in very cold conditions that is, but check the lens fpr fog...
That has to do with the focus by wire, the MF is not directly coupled with the focus system, but it command the focus motor in the lens, but it is not coupled, sa it does not turns when you auto focus the camera. So lets say you MF to infinity, Swithch the camera off, then AF the camera to very close by and swithch to MF you should not be able to focus to infinity again as your ring is at the end stop.
It would be nice if they found a way that you can still feel a stop at infinity...
I don't quite understand this. You would normally shoot in M mode (manual) once focused there is no need to focus again usually. Not sure what you mean by changing AF modes.
You need to keep the camera lens a bit warmer than the ambient air in cold weather otherwise it will fog up. You can do this as simply by putting the lens in your pocket for a while.
I use a bit of insulation wrapped around the lens before I go outside and that prevents heat loss and delays fogging up. You can also get chemical heat pads and wrap them on the lens and put some insulation on 2nd if fogging is really bad.
Greg.
C.Eaton
C.Eaton Contributing Member • Posts: 893
Great sky shot
mike winslow
mike winslow Contributing Member • Posts: 561
It's more likely operator, or firmware and not fog Greg.  I think he's using an E-lens and not an M42.
On his original question - I've had some pleasant wide fields on a very inexpensive Vivitar S1 28mm 2.5 on an m42 mount for under 1 minute subs, untracked.
With a lens this small, it's the smallest of nudge between in and out of focus eg FWHM ~<2 to FWHM 10.
He needs to focus with spot metering and have the lens in MF, not DMF. LENS comps OFF. ISO as low as you can go, since the camera processor is going to try to stretch the frame.  There is allot the camera does to the frame, even before the RAW gets written which appears to contradict the common mythos
Turn off noise reduction I think, and capture your own Darks and bias frames.  shoot multiple exposures and stack. There is some freeware out there, but I use MaximDL and photoshop.  process in 16 bits as long as you can for better SNR (and IQ).
Personally, I'm very tempted to hang this camera on my TAK-FSQ/Temma combination, but my situation prohibits this for now..  This Exmor sensor looks better than my peltier cooled Ex-HAD in allot of ways.
I've been collecting million year old photons for 13 years now.
 mike winslow's gear list:mike winslow's gear list
Sony Cyber-shot DSC-RX10 Sony Alpha NEX-F3 Sony a6000
wictred
wictred Senior Member • Posts: 1,195
great shot.
you can also try using a laser pointer for focusing
 wictred's gear list:wictred's gear list
Sony Alpha 7 II Sony FE 35mm F2.8 +3 more
teaberry
teaberry Regular Member • Posts: 362
Are you guys using GEMs for these shots to avoid "trailing"?
I was out in southeast asia with a beautiful dark night and when doing 30sec exposure pics, I start to see stars trailing. I notice your pics minimize that so I was wondering if you're using a German Equatorial Mount or some other device? I appreciate the advise as I am very interested in getting into Astrophotography.
Also, any recommendations on a budget telescope to mount the NEX (NEX-7) for under $500? I will have a separate budget for a GEM of course. Thank you.
 teaberry's gear list:teaberry's gear list
Sony Alpha 7 II Sony 50mm F1.4 Sigma 120-400mm F4.5-5.6 DG OS HSM Rokinon 14mm f/2.8 IF ED MC
mike winslow
Re: Are you guys using GEMs for these shots to avoid "trailing"?
a simple single axis motorized mount .. trying to think of the name, but something like OM-1.. it comes in a tabletop and tripod. something less than $100
It's not very accurate, but will be much better than nothing.  The last time that I was out with a lens on the astro camera, I had the guider on my FSQ,  on a temma mount, so going several minutes was easy.
A single axis will track the rotation of the earth, and even with an eyeballed polar alignment, you should see a dramatic reduction in trailing, especially in such a wide field.  You'll need to refine as you go..  pretty much get the north star centered in your FOV.
The other thing that you can do, which is free, is shoot shorter subs, then stack them.  There is freeware out there, but I havent tried them, and I'm not sure if they handle our image sizes well..  Google image stacking if you're not familiar, but it also gives you a better signal to noise ratio over a single image.  You might also want to think about doing dark frame subtraction, but I think that the camera does this with the long exposure NR under settings.
The rule for star trailing exposure length is 600/focal length gives max exposure in seconds before star trailing is objectionable.
Perhaps even 500/focal length. So that gives you around 35-45 seconds for a 14mm focal length (full frame equivalent).
As most cameras only allow a max of 30 second shots before you have to start mucking around with add-ons (why do they do that - they spend huge amounts to provide some obscure menu item and a basic function of the camera is overlooked for year and years) it tends to mean 30 seconds it tops.
So 30 seconds ISO3200 or 6400 at F2.8 if the lens can handle it (most can't) will give you a bright exposure. Long expsoure noise reduction on a lot of the time (unless its cold and it tends not to be needed then).
This image using a 16mm shows that lens is useful. Samyang 8mm F2.8 fisheye works well for this type of shot as well.
So you must have been using a longer focal length lens like a 50mm which will show star trailing after about 10 seconds of exposure.
Vixen Polarie is the most popular portable mount. Its tiny, its well made, it $400, its easy to use and it works well. It runs off batteries. It will hold above its rated capacity. It can handle a D800E and 14-24m lens which is heavy. Just make sure you have a pair of pliers to tighten up the tightening screws snug enough.
Orion ED 80 is a popular scope that is fantastic bang for your buck. Quite a high performer for a low price. Polarie would not handle that though. You'd need a GEM. Skyatcher EQ 6 is popular.
Greg.
teaberry
Thank you Greg and Mike, here is a sample of where I think some sort of EM would have helped...
I had no idea what I was doing, but it was such a beautiful night in Southeast Asia one night, I decided to take my cheap Slingshot tripod, remote, and the 16mm with the wide-angle converter. I'm sure you will cringe at the equipment, but I do think it could have produced better results if I had a more stable tripod and/or equatorial mount?
Any advise is appreciated. It was a 55sec exposure.
teaberry
Another pic. What could I have done to get sharper round stars?
This is another shot that I would have loved to have more round and sharper stars.
RustierOne
RustierOne Senior Member • Posts: 3,268
- has distance mark
thanks
Nice Milky Way image - thanks for sharing!
As for a good manual lens for Milky Way I have two suggestions depending on how much you want to capture in a single image. First the E-mount Samyang 8mm f/2.8 works great for nearly whole-sky shots. Here's an example:
Sony NEX-5N w/ Samyang 8mm f/2.8, ISO 1600, 2-1/2 minute exposure, tracked
Now if you want to shoot much more narrow views, I recommend the M42 mount Mamiya-Sekor 55mm, f/1.4. It is from a 1970's Mamiya-Sekor film camera and can be gotten quite inexpensively. Stopped down to f/2.8 or f/3.5, it's sharp in the corners, which is rare for many lenses. Here's a couple of single shots of part of the Milky Way:
Sony NEX-5N w/ Mamiya-Sekor 55mm f/1.4 @ f/2.8, 2 minute exposure, tracked, M24 & Sagittarius
Sony NEX-5N w/ Mamiya-Sekor 55mm f/1.4 @ f/2.8, ISO 1600, 2-1/2 minute exposure, tracked, North American Nebula
Single shots with this lens can be assembled into nice Milky Way panoramas using the (free) Microsoft ICE program (Image Composite Editor). Here's an example:
Mamiya Sekor 55mm f/1.4 @ f/2.8, composited from scanned film exposures, Milky Way from Cygnus to Scutum
Both lenses are full manual with distance scale. Infinity focus seems to be right on.
Best Regards,
Russ
 RustierOne's gear list:RustierOne's gear list
Sony Alpha NEX-5N Sony Alpha NEX-7 Sigma 19mm F2.8 EX DN Samyang 8mm F2.8 UMC Fisheye Sony E 35mm F1.8 OSS +6 more
kcire
@rustier: nice milky way too
@greg: i'm only use the camera, lens and tripod with 400/focal length rule. with vcl-ecu1 attached it became 12mm so 400/12 = 33.33 seconds max
i don't know about GEMs... what's that?
@all : thanks for suggestion.
basically i love my 16mm and vcl-ecu1, the only cons are neverending focus ring and no distance mark.
probably i'll consider samyang, but don't know which one better between 8mm or 14mm
the price is quite high too...
and this is me... lighting by flashlight
lesnapanda
lesnapanda Forum Member • Posts: 71
Thats an amazing photo!
 lesnapanda's gear list:lesnapanda's gear list
Sigma DP2 Merrill Sigma dp0 Quattro Sony Alpha NEX-6 Sony E 16mm F2.8 Pancake Sony E 50mm F1.8 OSS +1 more
Re: Another pic. What could I have done to get sharper round stars?
Very nice. ISO 1600 or 3200 would have gotten a much brighter image and consequently allowed a shorter exposure time. ISO200 is too low and ISO400 also too low for this type of work. Its all in the ISO3200 - 6400 x 30 seconds at 14-21mm focal length type shot untracked on a tripod with long exposure noise reduction on or ISO1600-3200 on a tracked mount.
GEM= german equatorial mount - a type of telescope mount that has 2 axes that rotate to match earth's rotation and can point anywhere in the sky.
Greg.
Pal2012
Pal2012 Regular Member • Posts: 368
Thanks for sharing! And good question, though I am sure the Zeiss 24 would do very well maybe even the SEL35 but probably too narrow.
This was with the SEL16 / Nex5n and dirty air..
 Pal2012's gear list:Pal2012's gear list
Sony Alpha NEX-5N Sony a6000 Sony E 18-55mm F3.5-5.6 OSS Sony E 16mm F2.8 Pancake Sigma 120-400mm F4.5-5.6 DG OS HSM +4 more
kcire
Nice photo...
Would be more amazing if the sky is clear.
